Caster Wheel for Boe Bot — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-05-02 09:49 in Robotics
Hi,
The ball wheel that comes with the Boe Bot seems to slide when then robot is turning.
This limits the payload of the robot.
Is there a easy way to change it to a caster wheel?
www.fd.com.my
www.mercedes.com.my
  • SRLMSRLM Posts: 5,045
    edited 2009-04-30 04:14
    Probably, if you can find one. Keep in mind though that the heavier load would also have to be borne by the servos, which shouldn't get too much lateral stress.
  • william chanwilliam chan Posts: 1,326
    edited 2009-04-30 12:14
    Is the function of the ball wheel to keep to robot going straight ahead when the left and right servo motors are not accurately tuned?
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-04-30 14:56
    William,
    The ball does not provide enough friction on almost any surface to keep the robot straight if the servos are not calibrated. In fact, the ball is so slippery on most surfaces that I cannot think of any way it would cause enough friction to be a problem unless the robot was over weight as mentioned above. The amount of payload it would take to cause such a problem would also be an issue for the servos themselves.
    Chris Savage
    Parallax Engineering
  • WhitWhit Posts: 4,194
    edited 2009-04-30 15:37
    William,
    We all weighed in on this a while back - See this thread - http://forums.parallax.com/showthread.php?p=753679
    If you really want something else - check the ball caters at Pololu - http://www.pololu.com/catalog/product/66
    I stand by the proven sucess of the the original BoeBot design...
    Whit+
    Post Edited (Whit) : 4/30/2009 3:44:38 PM GMT
  • NinjaTechNinjaTech Posts: 8
    This ones from Kornylak Corporation Wheel Division.
    www.omniwheel.com
    Or, maybe find something smaller.
    They're 2 inches in diameter though but still a possible option.
    Post Edited (NinjaTech) : 5/2/2009 9:58:11 AM GMT
    340 x 291 - 16K
