Help request for a BS1 project — Parallax Forums
luisr320luisr320 Posts: 3
edited 2009-03-19 17:57 in BASIC Stamp
Hello all.
I'm building a project to use on a aircraft simulator at a Flying School used for pilot training.
The original project started as a device which would the following:
When the pilot pushes the "Go-Around" push-button that is located in the throttle he would activate the "Heading" (HDG) and "Indicated Airspeed" (IAS) modes of the Auto-Pilot (A/P) instead of the original "Go-Around" mode. It would do this using relays to shunt both push-buttons on the A/P panel, one at a time and in a sequence of about 1 second for each action.
I started to build the circuit with 555 on monostable configuration but a new problem showed up: if the HDG mode or the IAS mode were already active, the project would turn those modes OFF instead of ON, which I didn't wanted to happened. This is because each push on those buttons cycle trough ON/OFF for each mode.
So this is where the Basis Stamp came in. From a project nightmare it turned in a fairly simple thing to do. One input pin of the BS1 would detect that the G/A push-button was pressed and would do the following sequence:
1- Check if IAS mode already active.
2- If IAS mode is already active goto next step and if not, make a ouput pin drive a relay trough a transistor, wait 1 second and goto next step
3- Check if HDG mode already active.
4- If HDG mode is already active loop to the beginning and do nothing and if not, make a ouput pin drive a relay trough a transistor, wait 1 second and goto next step
5- Loop to the beginning and check for G/A Push-button
A small routine waits for the pilot to release the G/A Push-button before restarting the loop.
The problem that I needed to solve was this: How do I check that the HDG or the IAS mode were already active or not.
Well, when these modes are active, an LED lights up on the AP panel for each one of them. So it would be a matter of making the BS1 check if those LEDs were lit or not.
Through another forum I got some very useful help and ended up using a comparator (a LM393) connected to both sides of the LED to compere the voltage drop. It worked perfectly.
My question to you is: how would you go about checking if the LED's are lit or not? The LEDs are driven from a 12 volts power supply trough a 3.3k resistor and are controlled by a CAN Bus system. Is there a KISS way to do this or using the 393 is a good solution?
The schematics of the circuit is attached.
Thank you
Post Edited (luisr320) : 3/19/2009 1:26:42 AM GMT
    edited 2009-03-19 00:47
    I'm sure you can make the 393 work, but here's a KISS solution for you to consider.· Basically your stamp's input pins are already comparators with a reference voltage of ~1.3V. Anything below ~1.3V is low, anything above is high.· You'll have to tie your Stamp's and LED-driving circuit's grounds together (both negative ground, of course). I'm assuming that your simulator system is simply driving the LEDs with either 0V (off) or 12V (on) through the 3.3K resistor. Hopefully the resistor goes to ground. If not, swap it with the LED and make it go to ground. Replace the 3.3 K resistor with a series voltage divider arrangement (2 resistors totalling 3.3K,·approximately two 1.7K resistors) so that you get no more than 5V at their junction WRT ground. Feed that voltage into your stamp input pin through a·220 ohm resistor for protection. When the LED is on, your pin will read high. When the LED is off,·the pin·will read low.
    BTW, 3.3K sounds too high for a series LED resistor. It would only let ~3 mA flow through your LED. Check that.
  • luisr320luisr320 Posts: 3
    edited 2009-03-19 01:21
    Thank you for your reply.
    The 393 works perfectly on the breadboard. I guess I'm just trying to get the KISS method.
    The thing is that the LED is part of a certified circuit which I don't want to change.
    The grounds are in fact common. The 3.3k resistance is part of a pack of 15 resistors for all the LEDs that are part of the A/P mode panel.
    I measured the voltage between the anode and the ground and got 12 volts when the LED is OFF. But when the LED is ON I get about 9.8V between ground the anode.
    The ground part of the LED goes inside the CAN control box.
    What does it mean to have 12V on the LED with it OFF and 9.8 with it ON?
    Here is the schematics of the simulator.
    Consider the LED's that are there as those to be monitored.
    Thank you.
    Seems like some measurement is amiss. Your resistor pack has a common lead to +12V (not common ground), then each resistor goes to an anode of an LED. The cathode of each LEDs get switched to ground (to turn them on) through connectors OUT_1 through OUT_4. Verify your LEDs anodes & cathodes, and check your on/off voltages again. I'm betting the voltages from an LED anode (which goes to a resistor) to ground (-12 volts) are ~2.2 volts on, and 12 volts off.
