First Attempt at a schematic - Page 2 — Parallax Forums
2»
    edited 2009-02-27 05:14
    wise thing to do. resister and caps are good place to start. i linked a real of caps that was $17 for 4000 caps. get twezers and try solderng to pads.
    Spark fun sells unpopulated boards by the bag that could be good for practice.
    Need to make your prop design easier or secure? Get a PropMod $50CAN has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module.
  • Greg LaPollaGreg LaPolla Posts: 324
    edited 2009-02-27 05:18
    I would like to use smt regulators on ds2760's and use smt caps and resistors on everything except the power supply.
    All the chips that I am using are smt so the pins are very small and very close together. Also I would like to fit this in a 3 x 3 or 3 x 4 inch board. The relays are very small about the width of a quarter so I wont be needing a lot of space for those.
    I only need to add one more 3 pin standoff for the 4x20 lcd display. I am struggling a bit with diptrace. I looked at eagle and it has a huge learning curve, maybe later.
    Greg
    edited 2009-02-27 05:26
    is this battery powered? switching is best for that.
    edited 2009-02-27 05:32
    Actually, the current system has a 12-14v dc door bell transformer in it to control the gas valve. I was thinking I could find a 6 or 7 volt dual transformer similar to the one I already have and pull one pin with 6 volts to run the prop board and pull 2 pins to get the 12-14 volts to run the gas valve. I am sure I will need to use a rather large resister on the 6 volt into the prop board to prevent feedback from t he 2 combined pins.
    Greg
    edited 2009-02-27 05:50
    opto isolators are a good safety precaution when using higher voltages.
    edited 2009-02-27 09:04
    Just remembered that I did not answer 1 of your questions. Some surface mount components use printed codes on them to show what they are some don't show anything. a lot of my 0603 resisters(wich i have about 100,000 of) have no markings at all. i keep them either on the reals(which is how you get if you buy by the 4000) or for those i use less often i keep in a grey perfectly sealed smd parts holder i found long time ago. keeping track of them and seperated is very important unless you want to meter them all out.
