Surface Mount
I've decided to go to surface-mount for my future PCBs, mainly to keep sizes down. My question is, what size resistors to use? Most of time time I use 1/4 or 1/8 watt through-hole resistors, because they are small. But these are usually just pull-up or protection resistors, and dissipate almost no heat. What size surface mount resistors do you guys recommend in these positions? It looks like they get so small that handling would be very difficult.
Has anyone tried the skillet reflow technique that Sparfunk recommends? Also, what about stencils? I use Advanced circuits student deal for my PCB ($33), but they don't seem have deals on stencils. Do you make your own stencil?
- Stephen
0201 1/20
0402 1/16
0603 1/10
0805 1/8
1206 1/4
1210 1/3
2010 3/4
2512 1
If you want a quick changeover from TH to SMT, start with either 1206 or 0805 packages. 1206 is widely used in SMT DIY kits because they are easy to solder by hand.
I use NIC components quite often, and here is selection guide for standard thick film resistors: http://www.niccomp.com/catalog/nrc.pdf
Depending on the type of resistor you use, you can get higher power ratings in a smaller package, but they will cost more. I have seen a 1 watt in a 1206 package.
The availability can also guide your design. A lot of designs I see are using 0805/0603 unless current or board real estate is an issue. You can get all standard values of 0805/0603 pretty much anywhere (digikey, mouser, etc).
~~ dRu ~~
At your age you probably still have a steady hand and good eyesight.
Too bad, one of the reasons I wanted to try SM was because most of the gyros and accelerometers out there are QFP, and I didn't want keep using Sparkfun breakout boards. Is QFN impossible without a machine?
This makes it impossible to remove solder bridges without desoldering the entire IC.
QFP, though, has no such problems.
(Thank you, Parallax, for releasing a QFP version of the Propeller. )
Don't visit my new website...
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Jay, reading and rereading your post about Sparkfun breakouts, etc., I'm at a loss parsing it for a reason to avoid QFP. Can you elaborate?
If your board is big enough to use 0805, that is about the best size. 0603's are quite doable also. 0403's are doable but without a stencil you will find it difficult.
I don't know why, but that skillet method seems like a bad idea to me.
Last project I used the no-clean pb-free paste from alldav. It seemed to work well, although not like good old lead. The water soluble lead free from alldav I would not recommend. I could not get consistent reflow and the joints looked bad.
Leon
Post Edited (Leon) : 2/6/2009 5:53:13 PM GMT
Also, I've just used my oven. I set it to about 350F, which is just hot enough to flow the solder, but not too hot to kill most chips. I put it on a pizza pan that has holes in it. Works great. The only problem, is sometimes the resistors tend to "tombstone" where the surface tension of the solder makes them stand up on end. I get less than 1 out of 10 do this, which is an easy fix by hand.
Phil, you say an IR oven is not that expensive. Is that "relatively inexpensive"? I looked all over, and everything I saw was a bit pricy. But I don't know what to look for.
And if it doesn't work, you can still make a quality pizza for about $3.
Leon
I paid about $100 for mine. It's metal (not plastic) and has a digital temp control and timer. It lacks a convection fan, though, which — from experience — I now consider essential for boards larger than a few square inches. Here are the features to look for:
1. Infrared (quartz) elements.
2. Accurate temperature setting, be it analog or digital.
3. Convection fan.
4. A built-in timer is handy for timing temperature profiles.
In reading the reviews for an oven, if you see something like "browns toast quickly and evenly", it will bear further investigation. Check out Target and Amazon.com. You should be able to find something that fits your budget.
VERY IMPORTANT: Once you've used the oven for soldering boards, don't reuse it for food! The same applies to a skillet.
If you select enlarge image you can see LED's for the temp gauge starting at 180 degrees,250,320,320,400,470 (hard to tell if I have the temps as shown because it's a little hard to read from the picture.)
Sanyo Digital Convection Toaster Oven:
*Twin convection outlets heat food evenly
* Digital convection oven with twin inlets
* 1,350 watts
* Full-width top and bottom quartz heaters
* 40-minute digital dial timer with lighted countdown indicators
* Five temperature control settings
* Easy-to-use digital controls
* Stainless steel finish
* LED's to show the oven temperature
Picture and a complete features list:
www.walmart.com/catalog/product.do?product_id=3875024
Aka: CosmicBob
products.howstuffworks.com/sanyo-digital-convection-toaster-oven-sk-vf7s-review.htm
From the review:
Pros: Digital touchpad controls, convection fan for even heat distribution, stainless-steel housing, 40-minute timer
Cons: Limited to five temperature settings, can't reset timer until unit shuts off
Good catch Phil. I didn't notice that at first. I considered them as indicators not limits. But if everything else met the required spec the temp settings could be modified.
Aka: CosmicBob
How about cooking up a programmable IR diode with enough wattage to make a small spot flow?
I can't do it, but I'm guessing it would take you about an hour[noparse]:)[/noparse]
Rich
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
Just some input [noparse]:)[/noparse]
www.circuitcellar.com/library/print/0704/Lacoste_168/
It BASICally or could be PROPerly bypasses the toaster's own sensing and control logic and runs the power through an external SSR.
Here is a pre-built retro-controller:
www.pcbunlimited.com/product_info.php?products_id=78
Tracy Allen
www.emesystems.com
That sounds like a good deal. I paid more for mine here in Hong Kong with similar features. There was another thread where I mentioned that I built my own controller using the Propeller. I just used the oven again over the weekend and it works great. The only kink I have in my system is the thermocouple or the thermocouple software. I hope I can figure this out in the near future when I get some spare time.
Using a toaster over without a controller is possible too, just be careful to not overcook the boards - I did that once when I took my eye off the oven and thermocouple "failed" send the temp too high for too long.
www.tdswieter.com
Phill,
How do you tell if a solder paste has gone bad?
www.fd.com.my
www.mercedes.com.my
