Proptool on linux under wine 1st step — Parallax Forums
BradCBradC Posts: 2,601
edited 2008-06-30 15:16 in Propeller 1
Now detecting serial ports.
<mumble mutter bloody registry mutter mumble>
Pull my finger!
    edited 2008-06-28 10:20
    Nice! How about sharing some .REG keys when you start feeling better...
    (A good tangle with the registry will do that to you.. [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card? - PropDOS
    Need a part? Got spare electronics? - The Electronics Exchange
  • BradCBradC Posts: 2,601
    edited 2008-06-28 18:50
    I'm actually building it into WINE so when WINE sees a port it builds the required reg keys. Not interested in doing it as a hack.
    Pull my finger!
  • evanhevanh Posts: 17,322
    edited 2008-06-29 02:42
    BradC said...
    Way to go! I've wondered how hard it would be to dig into supporting WINE. I've got a ton of PLC apps that never work with WINE just because of the comport issue.
    Thanks, and keep at it,
    Evan
  • AleAle Posts: 2,363
    edited 2008-06-29 09:41
    Sooo... when do I leave VMWare and start with Wine ?... so what is needed for the com port to work ?
    edited 2008-06-29 10:24
    It'll arrive along in the regular WINE updates if I'm reading Brad's comments correctly.
    Evan
    edited 2008-06-29 18:54
    Not to start with. I'll get it working and post some binaries and patches before I start the arduous fight to get stuff pushed upstream (did that several times years ago and it was hard yakka)
    Pull my finger!
  • vampyrevampyre Posts: 146
    edited 2008-06-29 22:53
    too cool. perhaps when its done you can post a patch somewhere for us who aren't patient enough to wait? ( i should read more carefully blush.gif )
    at the moment the prop is the only reason i still have windoze still on my machine.
    Post Edited (vampyre) : 6/30/2008 5:46:50 AM GMT
  • hinvhinv Posts: 1,272
    edited 2008-06-30 02:15
    Amen to that!
    That is one of the reasons I haven't done more with the prop. I have to reboot, and am not in my home environment. I like assembly, and I can do that under linux with pasm, but I have to leave all of the good spin code behind unless I run windows.
    Contrary to popular opinion, THIS is NOT a windows world!
    Doug
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-06-30 12:53
    I'll second that (third?)·rolleyes.gif·. I use Linux too, but I have W2K on dual-boot - primarily for the Prop. Linux for everything else. I have my wife and mother using Linux too.
    I keep my tiny laptop loaded with Windows only for Proptool now..
    Having an older laptop, I'd much rather have Slackware on it..
    OBC
