Bamse, I'm really no good at doin sound effects besides, It'd have to wait til I get PropGFX out, as I wanna finish that now, as Coley already has a first batch of them ready to go out the door [noparse]:)[/noparse]
Baggers, sorry about that, didn't read your post correctly...
OBC,
I changed my code to this, hopefully you should be able to just uncomment the settings and recompile...
' Set up the processor clock in the standard way for 80MHz on HYDRA
' You will want to edit this to reflect your clock setup
' Also necessary is editing the pin definitions, and that's done in the driver itself.
_CLKMODE = xtal1 + pll8x
_XINFREQ = 10_000_000 + 0000
SOUND_PIN = 7 ' Pin used for sound effects, pin 7 on the Hydra
VCFG_PINGROUP = 3 ' Pingroup for video output, 3 on the Hydra
VCFG_PINS = %0000_0111<<24 ' The actual pins used to generate the video signal, bit 24 to 26 on the Hydra
' Use these settings for Demoboard/Protoboard
_CLKMODE = xtal1 + pll16x
_XINFREQ = 5_000_000 + 0000
SOUND_PIN = 10 ' Pin used for sound effects, pin 10 on the DemoBoard
VCFG_PINGROUP = 1 ' Pingroup for video output, 1 on the DemoBoard
VCFG_PINS = %0000_0111<<12 ' The actual pins used to generate the video signal, bit 12 to 14 on the DemoBoard
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
no worries Bamse [noparse]:)[/noparse] still very honoured though [noparse];)[/noparse]
'{ ' A comment at the beginning of this line signifies that his block is uncommented :) or uncomment it, to comment the block :) if you see what I mean
' Set up for 96MHz on HYBRID
_XINFREQ = 6_000_000 + 0000
SOUND_PIN = 7 ' Pin used for sound effects, pin 7 on the Hybrid
VCFG_PINGROUP = 3 ' Pingroup for video output, 3 on the Hybrid
VCFG_PINS = %0000_0111<<24 ' The actual pins used to generate the video signal, bit 24 to 26 on the Hybrid
Oh and Bamse, if you use the setup section I've put in the code section then people can just comment/uncomment the first { in the specific sections, and the '} take care of themselves [noparse]:)[/noparse]
Did you see my edits for both
' Baseband video on bottom nibble, 2-bit color, enable chroma on baseband
and
' Two color mode, same as 1 bit mode. ?
Will test in the morning
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC,
' Set up the processor clock in the standard way for 80MHz on HYDRA ' You will want to edit this to reflect your clock setup ' Also necessary is editing the pin definitions, and that's done in the driver itself. _CLKMODE = xtal1 + pll8x _XINFREQ = 10_000_000 + 0000 SOUND_PIN = 7 ' Pin used for sound effects, pin 7 on the Hydra VCFG_PINGROUP = 3 ' Pingroup for video output, 3 on the Hydra VCFG_PINS = %0000_0111<<24 ' The actual pins used to generate the video signal, bit 24 to 26 on the Hydra ' Use these settings for Demoboard/Protoboard {{ _CLKMODE = xtal1 + pll16x _XINFREQ = 5_000_000 + 0000 SOUND_PIN = 10 ' Pin used for sound effects, pin 10 on the DemoBoard VCFG_PINGROUP = 1 ' Pingroup for video output, 1 on the DemoBoard VCFG_PINS = %0000_0111<<12 ' The actual pins used to generate the video signal, bit 12 to 14 on the DemoBoard }}▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Experience level:
/Bamse
'{ ' A comment at the beginning of this line signifies that his block is uncommented :) or uncomment it, to comment the block :) if you see what I mean ' Set up the processor clock in the standard way for 80MHz on HYDRA ' You will want to edit this to reflect your clock setup ' Also necessary is editing the pin definitions, and that's done in the driver itself. _CLKMODE = xtal1 + pll8x _XINFREQ = 10_000_000 + 0000 SOUND_PIN = 7 ' Pin used for sound effects, pin 7 on the Hydra VCFG_PINGROUP = 3 ' Pingroup for video output, 3 on the Hydra VCFG_PINS = %0000_0111<<24 ' The actual pins used to generate the video signal, bit 24 to 26 on the Hydra '} { ' A comment at the beginning of this line signifies that his block is uncommented :) or uncomment it, to comment the block :) if you see what I mean ' Set up for 96MHz on HYBRID _CLKMODE = xtal1 + pll16x _XINFREQ = 6_000_000 + 0000 SOUND_PIN = 7 ' Pin used for sound effects, pin 7 on the Hybrid VCFG_PINGROUP = 3 ' Pingroup for video output, 3 on the Hybrid VCFG_PINS = %0000_0111<<24 ' The actual pins used to generate the video signal, bit 24 to 26 on the Hybrid '} { ' A comment at the beginning of this line signifies that his block is uncommented :) or uncomment it, to comment the block :) if you see what I mean ' Use these settings for Demoboard/Protoboard _CLKMODE = xtal1 + pll16x _XINFREQ = 5_000_000 + 0000 SOUND_PIN = 10 ' Pin used for sound effects, pin 10 on the DemoBoard VCFG_PINGROUP = 1 ' Pingroup for video output, 1 on the DemoBoard VCFG_PINS = %0000_0111<<12 ' The actual pins used to generate the video signal, bit 12 to 14 on the DemoBoard '}Oh and Bamse, if you use the setup section I've put in the code section then people can just comment/uncomment the first { in the specific sections, and the '} take care of themselves [noparse]:)[/noparse]
Return later to see if I can figure it out.
OBC
Paul Baker
