USB SX-Key Update
Andre LaMothe has asked that we post an update on the SX-Key situation. Here it is:
The new USB SX-Key is very close to shipping.
Gunther, Peter, and I spent all last week working on it, since it had been recently re-designed by Gunther and the new clock synthesizer chip was posing some subtle issues. We got all the software straightened out, but it was still not working reliably. On Monday, Kevin and I discovered that the 20MHz crystal on the new Key was flakey, perhaps due to moisture absorbtion during cleaning. We replaced the crystal and it started working perfectly. So, we need to do a once-over on all the software to make sure everything looks straight (even though it seems to be working fine), and then solder on new replacement crystals to our current stock of 1,000 new USB SX-Keys.
I am hoping that we can start shipping again next week.
Chip Gracey
Chip Gracey
Is this the part you are using on the SX Key?· Have you tested large numbers of these?· Do you test every SX Key that you ship?·
My quantities are fairly small (a couple dozen per month) so I don't have really good data.· The failures started showing up around the time·Parallax switched over from the 250-12060 units.
Chris I.
Try adjusting the OSCxxx setting on the device line. Sometimes that fixes "flakey" resonators/crystals.
A 20 MHz resonator should work at either OSCHS1 or OSCHS2, but you might try OSCXT2 also.
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
Chris I.
I've seen some resonators fail after washing, as if their hermetic seal failed and they·absorbed moisture. I'm not at all fond of this new RoHS stuff, either, as it stresses components more and makes lousy solder joints. The old tin/lead system worked beautifully.
Chip Gracey
Thank you very much for the update.
--Bill
You are what you write.
There's nothing like a new idea and a warm soldering iron.
I'm still using my Serial SK-Key (and will keep using it) but may want to get one of these new USB versions for my other computer system once they are ready.
Robert
the SX-Key USB is strictly powered from the USB port with the target's Vdd NOT connected through to the SX-Key USB. This means that it can work with target systems with supply voltages below 5 V.
The average current consumption of the SX-Key USB is below 100 mA but when hot-plugged or due to the way the programming voltage is generated, peak loads do occur on the USB port. Most of the time during testing, I had the SX-Key USB connected to my laptop without problems. Nevertheless, a powered HUB inline with the SX-Key USB is a good idea.
Greetings from Germany,
G
About the crystal trouble we were having on the new SX-Key USB: It turned out that the crystals were fine -·the PCB layout was wrong! We had connected to the side pins of the 4-pin crystal, while we should have connected to the opposite corner pins. That it was working, at all, was a miracle, as we were probably coupled only through·5pF, through what was supposed to be the GND pin. No wonder it was acting flakey. A cut and a jump on the PCB fixed everything.
All that said, I don't know why you are having such problems with those resonators. It might be·a thermal/washing-induced problem, or something else. I don't know. We seem to be having good luck with the Transko resonators now, though.
Chip Gracey
We are making the small cuts and jumps to our inventory of 1,000 new Keys to fix the crystal problem. The firmware for the new Key is already done, thanks to all the work Gunther did. We are working with Peter Montgomery now to update the application software. It looks like it is going to be this week that we can start shipping again.
Chip Gracey
I am excited to hear that they will be shipping soon.
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
In the photo below Guenther is nearby and Peter is at the far end of the table.
I strongly protest your blatant use of product placement in this shot! I look like some sort of shill for Parallax.
You, my good sir, have clearly sullied my reputation with this flagrant abuse.
The fact that I already support Parallax as a company will in no way deter me from seeking some outrageous monetary compensation.
PeterM
Hah! Well, if we set out to hire a company model we probably wouldn't have chosen you either.
But at least the product selection around you helps improve the picture a bit!
Chris I.
thanks for publishing this picture, it really shows how hard we all were working on that project - I did not even have the time for shaving
Unfortunately, this picture does not show the third member of the team: Chip!
G
PeterM
Wow! You and your Dad sure look alike! The differences are almost completely invisible! [noparse]:)[/noparse]
Congratulations on the SX-Key (USB).
--Bill
Actually, Chuck told me that he read my book but was missing some details about the SX sleep mode. So I have one more item on my to-do list for the next edition.
G
Robert
Yes, you will be seeing a new SX-Key IDE that supports both the serial and USB SX-Keys. I expect to see that on the web by today or tomorrow. Peter Montgomery is travelling so we are trying to track him down.
Also, the new SX-Key USB began shipping today.
At this moment, I'd say a new order for an SX-Key USB would ship in a couple of days.
Managing an inventory like ours is fairly complex. Between changing costs, changing market plans, parts in progress, engineering changes and component obsolescence dealing with our 400+ for-sale items is a non-stop game of keep-up. Now that we've connected our internal business systems to the web we have a new set of considerations to manage.
As far as I know, there's no more hangups with the SX-Key USB.
Timothy D. Swieter
www.tdswieter.com
Chip Gracey
