Defender
I'm trying to do Protoboard/Demoboard compatibility for my Defender remake. But I don't have either of those boards. Can someone give this download a try to see if it works?
There's a video of it in action on a Hydra here:
www.youtube.com/watch?v=z535xcDGt9Y
You'll need a keyboard plugged in to operate it.
KEYS Are:
Enter to start (From Title Screen)
A,Z - Up/Down
Caps Lock - Reverse
Right Shift - Thrust
Enter - Fire
EDIT: Download changed to new version 016
EDIT: Download changed to new version 017
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
Post Edited (CardboardGuru) : 12/29/2007 5:25:29 PM GMT
KEYS Are:
A,Z - Up/Down
Caps Lock - Reverse
Enter - Fire
I'll test tonight using a Protoboard.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Also I have a new SpinStudio plug in module I was going to announce this weekend. The PropJoy module will let you plug 2 Atari style joysticks into a SpinStudio, or if you modify a ProtoBoard like detailed in the Propeller Cookbook, it can be plugged into that as well. I'll try it on that as well.
Did you strip out the joystick/gamepad routines in the Proto/Demo remake?
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Anybody heard of a Jamma interface for the Prop? I might be interesting to hook the Prop up to my arcade cabinet one day (if there are more games like this!). Of course, I already have a Mame PC hooked up to it, but this might be interesting to do anyway...
http://forums.parallax.com/showthread.php?p=685888
in the middle of the page i give some step by step instructions for getting #14 to work, some of these apply to #15. You can actually get this to work on the prop! While I wasn't able to get the keyboard working yet (probably have the wrong pins), it looks incredible.
I had to modify both of the files "EPM_Defender_Sound_Engine*_***" with the following adjustments to get the audio up and running.
PIN__AUDIO = %00000000_00000000_00000000_10000000
*to*
PIN__AUDIO = %00000000_00000000_00000100_00000000
CTRAVAL long %00110 << 26 + 7 'DUTY single-ended, APIN=7
*to*
CTRAVAL long %00110 << 26 + 10 'DUTY single-ended, APIN=10
My setup is a Protoboard with SpinStudio modifications, with a homemade NES controller on NES0
I've also set the Keyboard to 0.
Sweet Game! Yes, the new PropJoy device from Brian should work perfectly here.
OBC
If I launch BASIC first, I can spin it from Femto...
Weird..
I foresee a bugfix release of PropDOS soon...
OBC
Post Edited (Oldbitcollector) : 12/28/2007 10:57:39 PM GMT
I get video, but when the game starts, the ship starts flying to the left and upward. It doesn't respond at all to any input from the keyboard.
Later this evening after the kids are in bed I'll have to take a closer look, and also try to get it going with my new joystick boards that just arrived.
Brian
SD card Adapter
That's interesting feedback. The hydra uses pins 3-6 for the NES Gamepad. Have you got anything connected to those that might cause that left and upward movement? Other than that, there must be odd results coming back from the keyboard, because there's no other way the code would make the ship move.
How did you move from the Title screen to the game screen if you didn't have either a working gamepad or keyboard?
I get the same results. a message "system tests ok" or something similar, then after a second or 2 delay, it goes straight to the game. The ship immediately turns left and accelerates and ascends. No keyboard input required, and keyboard input does not change anything.
It skips by the title screen altogether.
I ran an older version 2 weeks ago on the same hardware and had no problems. I was using a prototype joystick board, so the keyboard code was commented out.
Brian
SD card Adapter
I needed to make the bit encodings
to make it fire on a one button Atari stick. As GP_START is the fire button, so shall the GP_A be.
great game! Now I've got to mod so the sound works
Brian
SD card Adapter
Some informations. At startup it's written TESTS INDICATE : UNIT OK and then it automatically start, the ship is getting up alone and nothing kill it.
Very great game, remember me all the quarters i've put on those machines 25 years ago.
The routine I've got for reading the Hydra gamepad returns a value with bits set for the different buttons. However, I'd forgotten that if there is no gamepad it returns a value of $FFFF, so any test for a button press returns positive. I've fixed that now.
Please try version 017 now attached to the first post. Press enter on the title screen to proceed.
There will be no sound for keyboard users, it's an either/or I'm afraid. And the game is not yet complete, so whilst you can kill the aliens, they can't yet kill you.
Thanks for the list of GP bitmasks. I'll set those up in the next release I do.
P.S. I know the best should be to buy an Hydra but I just buy the demo board and I have a lot to learn with it, the Hydra is on my wishlist.
Glad it's working. At last!
I'm sure you could add an NES controller, but I's not really my field. There's probably someone who's already done it that'll be along in a moment.
OBC
I then tried it with PropJoy and an Atari stick, again, it works great.
I am almost certain that the same bitmasks would apply to the Hybrid if using a single button Atari joystick. Maybe separate the GP bitmask Defines from the other stuff...like the clock speed, keyboard and tv video pin info
I did the same modifications and now I've got sound! Thank you!
When I'm done working on the documentation, I will be announcing PropJoy. It'll allow you to plug Atari Joysticks into SpinStudio, Modified ProtoBoards or a Demoboard with some clever wiring. Stay tuned.....
Brian
SD card Adapter
Do you have permission for this "re-make"?
William's Defender source code will be. But since I haven't got nor have seen a copy, I can't have copied any of it.
William's Defender artwork will be, but mine only bears superficial similarities, they were all drawn from scratch, and none of them are even the same size, let alone identical.
The sounds are all created from scratch by Eric Moyer specifically for this project, inspired by the originals, but not copying them.
None of the text in the game is identical.
Copyright of the superficial look and feel of software applications was tested out back in the early days of spreadsheets, and again with desktop UIs and and has never stood up in court.
"Defender" the name is a word from the dictionary, and William's made no attempt that I can see to have it as a trademark. "Windows" is also a name from the dictionary. Microsoft tried to establish "Windows" as a trademark, and after some toing and froing in court, eventually settled out of court with Lindows, i.e. paid to stop them using a similar name to Windows rather than go on and lose in court. But that was years later. AFAIK Williams never even tried.
There's are multiple programs that are called "Defender", e.g. "Windows Defender".
My other game "Dodgy Kong" is so called because the combination of words "Donkey Kong" IS a trademark, and one that is current too. Though there's an interesting story behind that because Universal studio's believed they had "Kong" as their trademark because of the film, and sued Nintendo. But that failed in court, so I'm safe with that part.
So AFAIK, it's all fine. There's nothing I'd need permission for. It's all my own work plus Eric's, apart from the comboKeyboard driver, and because that's from Obex, I know I can use it as I wish.
Post Edited (CardboardGuru) : 12/30/2007 5:46:41 PM GMT
Yes, he's re-made it in "his" way, so it looks and plays similar, but is his homage so to speak of the classic arcade game, same as his dodgy kong "remake"
Yes, the original is copyrighted by Williams Games INC, or whatever their full title is, but this has been re-drawn, and re-coded by CardboardGuru, so therefore he owns copyright of his artwork, and source, and since he's not making any money off it,
I doubt williams will have a leg to stand on, as they're not losing money on this, in fact, if anything it will re-kindle peoples interest in the game, and if they were to say pass an olde arcade, with a defender game they might now be tempted to go in and spend 10p or whatever it is now to play it.
Also if it wasn't for us hardened retro gamers, Defender and the likes, would have been long forgotten.
Baggers.
If it is an infringment of copyright, surely anything on game is an infringment of copyright, as they use tile/charmap levels and paletted characters and "sprites" and joypads / controllers for input.
besides, if you don't like it, don't sweat about it, take a step down, and go read something else, and don't look at the games? to save yourself the hastle of getting into a tizzyfit about it.
he's just showing his ability to write a game, it's a learning process, making games, and by imitating the classics, it gets others to appreciate it more, and besides, there's NOT many original uncopyrighted games/ideas left in the world.
they've all been snapped up.
he's doing something he enjoys, coding, and bringing pleasure to those who appreciate it, without any exchange of currency, just a smiley and a well done, is enough to know he's put smiles on the faces of others with his YES "his" hard work. because he took "his" time to make the game, be it, a remake/clone of another game.
The method that Defender was created using reverse engineering is not only legal, but
has been used many time successfully with products you use every day. Had he actually
seen the source code to Defender then that would have been a different story.
A great historic example of this was the BIOS for the first PC clone.
Now back to Defender stuff...
Is it normal for the game to reboot the prop after beating the 1st level?
Also, wasn't there smartbombs in Defender? or am I thinking of another game?
OBC
I certainly do Rory. If you'd like to quote the law you think that's against and why, I'm all ears. I've given you my understanding of legality of the situation, I'd love to hear yours. As would the thousands of other people that do classic game remakes.
In "Who owns the codes here?" you posted at great length regarding your so-called rights to "your code", it is to laugh, and your expectations that your supposed rights to copyright should be assiduously respected, yet you trample the rights of others. ·Your "Defender remake" is a naked violation of copyright law just as any counterfeit is, all of your AFAIKs and "understandings" notwithstanding.
Baggers,
You go re-read it --·and then·practice it.
