SX20 in a 14 Pin DIP — Parallax Forums
BeanBean Posts: 8,129
edited 2007-12-07 00:56 in General Discussion
I have a lifetime supply of leadframes on order. So I'm looking for projects to use them.
What do you think about an SX20 in a 14 pin DIP package ?
The SX20 is on the bottom to allow for labels for the pins.
Note that A3 is also connected to RTCC, so you can use that pin for either or.
EDIT:
· I·have changed it to try to get RB.0, RB.1, and RB2 so you can use the comparitor.
··I also added the pull-up resistor for·MCLR and a by-pass cap, so you can use it to make a stand-alone device.
EDIT2:
· I have made three versions.
··· One with 2 LEDs on-board.
··· One with a 128KB EEPROM on-board.
··· One with the OSC pins on the edge (all I/O connected to pins).
Bean.
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 12/2/2007 4:22:54 PM GMT
    edited 2007-11-29 22:29
    That looks like a great idea and would make a nice little adapter. What about putting it on a 16-pin DIP instead? That way you can bring out all the I/O, power, reset, and RTCC pins. Just leave pads for the programing adapter. If the 4-pin SIP won't fit on the edge just use a 2-pin SIP for the OSCx pins and you can make a little custom adapter to plug into the end of the key for programming. With that you can still use all the features of the SX20 chip. Routing the traces may be a chore but it should work.
    Robert
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2007-11-29 22:33
    Or a 18pin dip that is SX18 compatible?
    regards peter
    edited 2007-11-29 22:58
    I'm with Peter V! I still have a few SX18s... but the supply is running short.
  • kb2hapkb2hap Posts: 218
    edited 2007-11-30 12:26
    SX18 compatible, thats the way to go!
    DTQ
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2007-11-30 16:44
    Bean,
    I am curious to know why you did not bring all of the Port B pads out to pins but chose, instead, to bring three Port A pads out to pins. I can see an advantage to being able to use byte operations to affect all eight Port B signal pins at a time. You might have seen more of an advantage to bringing out three of the Port A pins. Was this to make it easier to support I2C, SPI, chip select and enable pins, etc. from a separate port? If so, I guess I do not see that as a significant advantage.
    Also, I do not see the logic in breaking up the Port B pins into two separate groups of three pins. I think a consecutive grouping would be a better option. I am wondering why you chose this configuration.
    I hope it does not seem like I am criticizing your design decisions. I am only seeking to understand your thought process with the hope that I may learn something I have not previously considered.
    I think a 14-pin version could be useful. (I am not sure how small the market might be.) However, it sounds like there is a bit of a cry for an 18-pin version. Heed the cry! wink.gif
    - Sparks
  • BeanBean Posts: 8,129
    edited 2007-11-30 17:35
    Sparks,
    I simple choose the pins and the order that could be connected the easiest. [noparse];)[/noparse]
    The 14 pin version was to allow me (and others) to sell programmed chips that do certain functions (PWM, Servo control, ect). So it has a by-pass cap, and /MCLR pulled up with a 47K resistor. Basically a plug in and go controller.
    I'm working on a SX18 version, seems like there is demand for it. But it won't be nearly as cheap as an SX18 chip.
    Bean
    edited 2007-11-30 19:36
    Hi Bean,
    Here is my design for a dip18. It is a tight fit. All traces are 12mil, pads are 60x40mil hole 28mil.
    Vias are diameter 40mil, hole 20mil. The chip goes to the bottom side.
    regards peter
    edited 2007-11-30 20:24
    Peter,
    Wow that certainly is nicer than the mess I've been working on.
    Nice job.
    Bean.
    edited 2007-11-30 20:28
    Feel free to copy the design. I still have 100+ SX18 chips
    so I will not get these boards manufactured.
    If you want I can send you the gerber files.
    regards peter
    edited 2007-11-30 20:32
    Peter,
    That's quite an elegant layout! Nicely done!
    edited 2007-12-01 21:05
    Terry, for a 14 pin version, I think I'd prefer holes for a resonator at the end, instead of bringing the resonator out to the side pins. Also, maybe tie mclr to Vdd via the pullup, but don't bring it to a side pin. That would free up three pins for i/o. Imagine that what you have as the bottom of the board is moved up to the top, and rearrange a little bit, that would put b0 to b7 on pin 1s thru 7 on the carrier, and would put the resonator on the pin 7,8 end. Power could be on pins 8 and 14 of the carrier, leaving 5 carrier pins for b8 and a0 to a4 (muxed with RTCC). That could be used with chip topside or could be flipped with pin renumbering.
    Peter, I agree with others -- an elegant layout for an 18 pin design.
    Tracy Allen
    www.emesystems.com
    edited 2007-12-01 21:59
    Tracy, I don't want to remove the OSC1 and OSC2 pins because that will make programming and debugging alot more difficult.
    I do agree about not have the /MCLR pin though. I have added the MCLR pull-up (47K), a 0.1uF by-pass cap and a 20MHz resonator pads.
    So now there are 10 I/O pins, and you can still use RTCC (on RA.3), and the comparitor (RB.0, RB.1, RB.2).
    I have updated the pictures in the first post.
    The board is 0.350" high, so I'll have to bend the leadframes in slightly to get the 0.300" width. I just couldn't get it connected at 0.300".
    [noparse][[/noparse]Edit] Oops, found out that the leadframe clips will hit the SX package. Darn, I had to increase the·heigth to 0.390", well at least that gives me more room . I want to make two versions, one will use the 2 unused pins for·on-board red and green LEDs. The other will have an on-board I2C EEPROM.
    Bean
    Post Edited (Bean (Hitt Consulting)) : 12/2/2007 3:31:23 AM GMT
    edited 2007-12-02 07:28
    Bean,
    Would the chip interfere with the leadframe if it were on the top instead of on the bottom? Having silk-screened pin labels on top seems less important, and could be printed on a paper overlay.
    How about putting 2 holes on the end next to the resonator for programming/debug via a small header? I'm not letting up on the two clock pins, that could be used to get all 12 i/o to the outside.
    Tracy Allen
    www.emesystems.com
    edited 2007-12-02 16:13
    Tracy,
    · The leadframe connects to both the top and the bottom, so it wouldn't matter.
    · I made the board larger, and have 3 versions. One has 2 LEDs on the unused pins, one has a 128KB EEPROM on the unused pins, and one has all the I/O pins with the OSC pins on the end.
    · It's going to be a chore to bend the leadframes, but this is the first revision maybe I'll think of something clever later.
    · I have updated the pictures in the first post.
    Bean
    Post Edited (Bean (Hitt Consulting)) : 12/2/2007 4:23:22 PM GMT
    edited 2007-12-02 18:08
    Bean,
    Are you talking about the kind of lead frame you see on the BASIC Stamp modules, that wrap around the side of the board? Those do take a a lot of space. And it would be a royal pain to have to bend it in to fit 0.3"!
    I was thinking more in terms of PC pins, like the ones from Mill-Max. Some of them fit through a 0.020 hole and take only a 0.030 pad. Maybe Peter's SX18 design was planned around something like that? It is a bit of a pain to load the pins with good alignment, but it can be done pretty quickly with a simple alignment jig.
    I'm attaching my try at a 14 pin layout with the resonator next to the SX20 and the clock pins at the end for programming. The SX20 and resonator are on the top, and the mclr pullup and bypass cap are on the bottom. The pins CCW from lower left are B0, B1, B2. B3, B4, B5, B6-- X2, X1 --B7, V+, A0, A1, A2, A3, V-.
    Tracy Allen
    www.emesystems.com
    287 x 329 - 9K
    edited 2007-12-03 08:19
    Tracy, my idea was indeed pinheaders (diameter 0.6mm 0.1" spacing)
    Bean, attached is a 8pin dip design. Pins available are B0-B3, where B3 is also connected to RTCC.
    Also added pullup for MCLR and pads for onboard oscillator/resonator
    (I estimated oscillator pad sizes from your drawings).
    Edit: added a version 3, with onboard cap and sxkey connection.
    The idea is to have two 4x1 pinheaders on bottom·for insertion into DIP8 socket
    and one·4x1 pinheader on top for sxkey.
    Edit: added a version 4, removed OSC1, OSC2 and RB3 pins, added RA0, RA1 and RA2 pins.
    Edit: added an alternative bottom layer to V4, where RA2 connects to RTCC (instead of RA3)
    Edit: added a version 5 that has VDD and VSS pins changed to match EEPROM socket.
    regards peter
    Post Edited (Peter Verkaik) : 12/4/2007 9:01:58 PM GMT
    edited 2007-12-04 07:19
    Here to round out the pin counts is a possible SX20 to dip-16 layout. It brings out everything except the resonator, which is on board, but with provision for a 0.050 sxkey header at the end.
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 12/4/2007 7:24:08 AM GMT
    303 x 308 - 34K
    edited 2007-12-04 10:03
    Hey guys,
    you should consider using 4-layer boards with two inner supply layers, one connected to Vdd, and the other to Vss. This makes routing of the power signals much easier, and adds a nice "filter cap" against EMI. At least here in Germany, the price difference between two- and four layer boards is not that much. I'm using this technique for most of my new designs.
    Greetings from Germany,
    G
    edited 2007-12-04 14:17
    Peter I like your V4 except you should have connected RTCC to the A2 pin.
    Guenther, I wish ExpressPCB had an inexpensive 4 layer option. I would definately use it.
    Bean
    edited 2007-12-04 15:06
    Bean, I added an alternative bottom layer where RA2 connects to RTCC.
    (see V4 attachement of my previous post). I was thinking RA3 connected to RTCC would
    allow·to induce an interrupt without altering available I/O pins, the same
    can however also be done by toggling an unused RB pin.
    regards peter
    edited 2007-12-04 16:28
    Peter,
    You can induce an interrupt with any of the unused RB pins.
    RTCC is most useful in counting an external signal (if you use the RTCC prescaler you can count a signal many times faster than the SX clock).
    It's amazing how many cool DIP units can be made. I have order boards and they will be here Friday. Now if only I had my reel of leadframes I ordered....Argg...
    Bean
  • SailerManSailerMan Posts: 337
    edited 2007-12-04 16:52
    I'm dumb, What is a LeadFrame?
  • pwillardpwillard Posts: 321
    edited 2007-12-04 17:12
    On the stamp for example... the PINS that are soldered to the printed circuit board that act like a .100 spaced LEAD that plugs into your circuit or breadboard is a "lead-frame".
    There's nothing like a new idea and a warm soldering iron.
    edited 2007-12-04 18:25
    The are like DIP IC pins all tied together. You solder them onto the board, then break off the top and bottom to leave seperated pins.
    Here is my smallest 8 pin DIP layout. Pins 1 & 8 will have to extend above and below the PCB. SX-Key connects to the 4 pins down the right side.
    A3 (pin 6) is also RTCC, and OSC1(pin 8) can be used with an external clock or an external RC circuit.
    Bean
    705 x 585 - 84K
    707 x 581 - 78K
    edited 2007-12-04 20:04
    Guenther,
    I see what you are saying about the easier layout wit 4 layers. But the price here can be pretty steep for prototypes or short runs. Not too much for production though.
    I have a couple of questions for you about your 4 layer layouts, Where do you leave your exclusion areas, if any? For example, the X1 pin is sensitive, as are areas around a high speed input for something like sigma-delta. In a general purpose design it is hard to predict what each pin will be used for. and if a few extra pF to ground will be bad.
    As to EMC, how important do you think the 4 layer layout is for meeting CE guidelines?
    Tracy Allen
    www.emesystems.com
    edited 2007-12-04 20:22
    Where do you buy these from? Bean would you be willing to sell a few?
    edited 2007-12-04 21:04
    Bean, nice DIP8. Can't get smaller than that.
    I uploaded a version 5 (see my earlier post) that has VDD and VSS pins changed
    regards peter
    edited 2007-12-05 00:46
    Tracy,
    too bad to hear that prices for 4-layer prototypes are that much higher in the US than here.
    Actually, I usually don't leave any exclusion areas. You are right that the two inner layers add some capacitive load to signal traces on the top and bottom sides of the board. Although I made no measurements so far, I guess that such short and thin traces can only build up a minimum capacitive load against the nearest inner layer in an area of some pF at maximum. When you consider that a ceramic resonator attached to the X1 pin usually has a built-in capacitor of several pF between X1 and Vss, the additional trace capacitance can be almost ignored. The same is true for high-speed inputs for sigma-delta. Here, you usually have a capacitor of 0.1 µF between the input and Vss, and the same capacitor with 10 kOhm in series between the output. So, I think the additional "stray capacity" between the traces and the inner layers can be ignored again.
    IMO, the few extra pF between inputs and ground don't cause any trouble but - on the other hand - help to reduce generated EMI.
    When I did my first commercial SX-based hardware designs with SXes clocked at 50 MHz, I got in deep trouble when I had those boards checked for EMI conformity. It turned out that most of the EMI was generated by the supply traces, and the "filter caps as close as possible between the supply pins"-trick did not really work. After switching to the 4-layer design, the EMI problems were gone.
    There was a thread in this forum section regarding EMI a long time ago - unfortunately, it is older than one year, so I could not find it using the forum's search function.
    Günther
    edited 2007-12-05 01:57
    G
    edited 2007-12-05 07:16
    Bean,
    I reworked your DIP8 design to have pins A0/RTCC, A1, B0, B1 and B2.
    If you ever do a dip8 version, this is my favourite.
    regards peter
