NEW PRODUCT ANNOUNCEMENT: SoundPAL, miniature sound player — Parallax Forums
edited 2007-11-18 00:52 in BASIC Stamp
The Parallax SoundPAL is a tiny module that plays canned and custom sound sequences. It is completely self-contained, including a microcontroller for generating the sounds and a small speaker for producing them. The SoundPAL interfaces easily to a BASIC Stamp and can play sounds while the BASIC Stamp is busy with other chores.
Features
  • Plugs into servo headers, and works with protoboards.
  • Virtually goof-proof power sourcing makes it nearly impossible to connect wrong.
  • Single-pin interface uses a simple serial protocol to define and initiate sound production.
  • Custom tunes and effects are simple to program using musical notation instead of frequencies.
  • Built-in control codes include repeats (1-254, plus infinite) and "subroutine" calls.
  • Comes preprogrammed with 24 different tune snippets and sound effects.
  • Onboard EEPROM permits saving custom sound sequences for later playback.
  • Autoplay feature permits playing a pre-designated EEPROM sequence with only a power supply.
  • Compact size: stackable side-to-side with additional units on 0.1" servo headers.
Price: $24.95
Addendum: Attached is an MP3 recording from the SoundPAL's speaker of one of its built-in sequences.
Addendum 2: Also attached is a larger zip with recordings of all the built-in sequences.
Post Edited (Phil Pilgrim (PhiPi)) : 11/7/2007 6:42:58 AM GMT
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-11-03 00:51
    Cool product, but it is a shame that the microprocessor is a ATTiny13 and not a Parallax Stamp. Curious as to why a ATTiny and not a PIC?
    just out of curiosity, why is Phil doing product announcements for Parallax?· Shouldn't that be the Marketing Department's job?
    Post Edited (Steve Joblin) : 11/3/2007 1:02:20 AM GMT
    edited 2007-11-03 01:29
    ATTiny13 for size (SOIC-8), no crystal needed for 9.6MHz operation, easy for manufacturer to program in situ, aaand ... I've just gotten used to programing them. smile.gif It's designed to interface to a Stamp, though, using SERIN and SEROUT.
    See note in other announcement about my participation in announcements.
  • Fe2o3FishFe2o3Fish Posts: 170
    edited 2007-11-03 18:00
    Phil,
    Any chance (> 0.0) that we could get a few sample sounds posted on the product webpage
    -Rusty-
    Rusty Haddock = AE5AE = rusty@fe2o3.lonestar.org
    **Out yonder in the Van Alstyne (TX) Metropolitan Area**
    Microsoft is to software what McDonalds is to gourmet cooking
    edited 2007-11-03 22:14
    In the top post, I've added a sound recording from the SoundPAL's speaker.
    edited 2007-11-04 21:41
    I've updated the first post with a zip containing all the built-in sound sequences. These are just the preprogrammed sounds, though. The variety of tunes and effects possible with the SoundPAL is virtually limitless.
    Post Edited (Phil Pilgrim (PhiPi)) : 11/4/2007 9:46:14 PM GMT
  • WhitWhit Posts: 4,194
    edited 2007-11-05 02:14
    Neat poduct! Thanks for the post Phil and the sound files.
    Whit+
    edited 2007-11-05 03:03
    Cute! Thanks Phil! 'preciate the effort!
    -Rusty-
  • hitswarehitsware Posts: 156
    edited 2007-11-05 03:09
    will it produce a sinewave ?
    edited 2007-11-05 06:45
    hitsware,
    All the tunes and effects are composed from square waves.
    edited 2007-11-05 16:40
    Phil Pilgrim (PhiPi) said...
    hitsware,
    Phil,
    Do you know how accurate and/or the actual frequencies produced ?·
    edited 2007-11-05 16:52
    The microcontroller on board the SoundPAL uses an internal RC clock, in order to keep the size as compact as possible. While the frequencies it produces are accurate relative to each other, there's no guarantee of accuracy relative to a fixed standard.
    edited 2007-11-06 00:22
    What ratios do you use for a scale ?
    I.E.
    I assume the clock is simply divided ?
    What divisors do you use ?
    Thanks. Nifty device [noparse]:)[/noparse]
    edited 2007-11-06 00:42
    The frequency ratio for adjacent notes in a well-tempered chromatic scale is eln(2)/12. The method used to generate the frequencies is the same used by the Propeller, with registers parallelling its FREQA and PHA registers — but done in software. Had I used integer dividers instead, the relative frequencies would have been off enough for the ear to detect.
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2007-11-06 02:09
    Will it also work with an SX chip OR is it specifically for the Basic Stamp 2?
    edited 2007-11-06 02:32
    What is the "RC" clock frequency ?
    Will it run with the original DOS bassed PBASIC setup ?
    Would you please post your MP3 samples unzipped ?
    Just MP3 ..... My unzipper is confusing me [noparse]:([/noparse]
    MegaRegards .......... mike
    I looked at the PDF
    It seems the context is simular to the PLAY command in QBASIC ?
    (with the 'duration modifiers')
    I've always used the SOUND which works the same but without the
    ability to que the notes and play them as backround.
    edited 2007-11-06 03:03
    T&E Engineer,
    It will work with any micro which can send and receive asynchronous serial I/O.
    hitsware,
    1. RC freq = 9.6MHz
    2. I've never used the DOS setup. But as long as there's a SERIN and SEROUT, I'd say yes.
    3. I can't post unzipped MP3s. The forum doesn't allow it.
    edited 2007-11-07 02:00
    T&E Engineer,
    hitsware,
    1. RC freq = 9.6MHz
    Thank You....
    I listened to some of the MP3 and everything is up in the midrange or treble ?
    How low of frequency will it put out?
    If you take off the piezo and replace it with a RCA jack ?
    Any idea why the MP3s are a no no ?
    MegaRegards [noparse]:)[/noparse]
    edited 2007-11-07 06:37
    The frequency response of small speakers peaks in the upper octaves. Although it's possible to simulate low frequency buzzing with the SoundPAL, the output volume will be below what you get with higher frequencies. That's just physics. The speaker, BTW is magnetic, not piezo. It's driven with an open-drain MOSFET and is remarkably loud for its tiny size. Replacing it with a jack would require at least an additional pullup, and possibly a series resistor for impedance matching, plus a cap for AC coupling.
    But the SoundPAL is all about miniature self-contained sound production. If you want to add a siren to your BOE-Bot, or rig up a gift box to play "Happy Birthday" when it's opened, the SoundPAL is your solution. But if you're looking to feed your stereo with tunes and effects, there are probably better ways to do it.
    'No idea why MP3s are verboten, BTW. But since zips are okay, it hardly matters.
    edited 2007-11-08 00:59
    Yea. Thanks [noparse]:)[/noparse]
    Looks like the most viable (for my purposes)
    chip from Parallax is the PWMPAL
    I've had pretty good luck with that but haven't
    quite got it to a groove[noparse]:)[/noparse] level ........ mike
    edit:
    actually if someone could figure out how to get rid of
    the horrendous glitches on FREQOUT .....
    I.E. maybe the pin would go open on transistions or ?
    Then the PicChip itself would serve 'my purpose' ......
    Post Edited (hitsware) : 11/8/2007 1:10:33 AM GMT
    edited 2007-11-09 16:19
    I just purchased one of these SoundPALs for experimenting with an SX-28 once I understand it well on a BS2 or BS2px.
    BTW: are the CON codes the same for a BS2px?
    (e.g. baud····· CON· $8000 + 84·· 'Communication baudrate is 9600 for BS2, BS2e, and BS2pe.
    reset···· CON· $8000 + 813· 'Reset baudrate is 1200 for BS2, BS2e, and BS2pe.)
    I hope the volume is decent and not too low for my professional developement board.
    How did you record these as MP3's ? - direct command within the SoundPAL or (just a microphone in Windows)
    edited 2007-11-09 17:08
    For the BS2sx (from the BASIC Stamp Syntax and Reference Manual, also found in the PBASIC Help file):
    baud  CON $8000 + 240   '9600 baud, inverted.
    reset CON $8000 + 2063  '1200 baud, inverted.
    To record the MP3s, I used a microphone feeding into Audacity.
    edited 2007-11-09 17:32
    OK I see it under the SERIN in the PBASIC help.
    So for a BS2PX (not sx) - I would use:
    baud· CON· $8000 + 396···· '9600 baud, inverted
    reset· CON· $8000 + 3313·· '1200 baud, inverted
    That's good. Thanks!
    edited 2007-11-09 17:55
    Oh, sorry, BS2px. I guess my eyes aren't working right. Yup, you've got the right constants now.
    Also check out the working SX/B equivalent to Phil's BS2 programs:
    http://forums.parallax.com/showthread.php?p=689074
