2x16 LCD gone black — Parallax Forums
2x16 LCD gone black
verobelverobel Posts: 81
edited 2007-08-24 00:33 in BASIC Stamp
Fellow Stampers..
I have been using the parallax 2x16 lcd (with backlite, off) in a small application with a BS2PE. Recently the display has turned all black when I turn it on. Is there a reason for this? Is the display finished? As far as I know circuit has not changed, voltage source is good. I have also reloaded·the program on Stamp.
Thanks, John
  • JC68JC68 Posts: 19
    edited 2007-08-22 16:48
    if this is a parallax serial lcd then you can put it in test mode and check for the parallax name to appear, confirming the lcd is good.
    good luck
    jc
  • pwillardpwillard Posts: 321
    edited 2007-08-22 17:35
    Paraphrasing from Parallax DOCS:
    If you don’t see the text at first, try adjusting the LCD contrast by turning the pot labeled “Increase
    Contrast” with a screwdriver. Turn it in the direction of the arrow to make the characters show up darker the other direction for lighter.
    There's nothing like a new idea and a warm soldering iron.
  • verobelverobel Posts: 81
    edited 2007-08-22 18:36
    I tried adjusting the contrast and it fixed the problem. I had forgotton that trim pot since it is hidden
    underneath after mounting. Surprisingly is was cranked all the way to one end and I had been using it for over a year with no problem.
    Thanks All,
    John
    edited 2007-08-23 13:51
    Perhaps it got bumped and affected your setting. Take care.
    Chris Savage
    Parallax Tech Support
  • WhitWhit Posts: 4,194
    This thread shows why two (or more) heads are better that one. It also shows that it is aways good to ask questions. John - glad you're up and running.
    Plus, if this ever happens to me - I might just remember this - well maybe... wink.gif
    Whit+
