2x16 LCD gone black
Fellow Stampers..
I have been using the parallax 2x16 lcd (with backlite, off) in a small application with a BS2PE. Recently the display has turned all black when I turn it on. Is there a reason for this? Is the display finished? As far as I know circuit has not changed, voltage source is good. I have also reloaded·the program on Stamp.
Thanks, John
Thanks, John
good luck
jc
If you don’t see the text at first, try adjusting the LCD contrast by turning the pot labeled “Increase
Contrast” with a screwdriver. Turn it in the direction of the arrow to make the characters show up darker the other direction for lighter.
There's nothing like a new idea and a warm soldering iron.
underneath after mounting. Surprisingly is was cranked all the way to one end and I had been using it for over a year with no problem.
Thanks All,
John
Plus, if this ever happens to me - I might just remember this - well maybe...
Whit+
