NEVER say NEVER --> DIY PCB's — Parallax Forums
pwillardpwillard Posts: 321
edited 2007-09-27 13:53 in General Discussion
I read somewhere that it was nearly impoosible to get good results with Gootee's Toner Transfer method (http://www.fullnet.com/~tomg/gooteepc.htm)·for fabricating DIY pc boards.· Well, I just wanted to see if my 8 year old Lexmark Laser Printer and my PCB software·(Sprint Layout) http://www.abacom-online.de/uk/html/sprint-layout.html·could do it.
So what was I·doing?··· --> SSOP .65mm·pitch·SX28
How did I do?
Take a look.· Note: Due to shine and close up focus, some traces look like they touch... but that's just an optical illusion.· It works just fine.
Total Expense?·· About a $1.50 in materials.
BTW: I have much better results using Muriatic Acid (Cement etcher from Home Depot)· and Hydrogen peroxide (Pharmacy).· It etches much faster than Ferric chloride and it's not opaque.
There's nothing like a new idea and a warm soldering iron.
test.jpg 132.4K
  • DgswanerDgswaner Posts: 795
    edited 2007-08-12 22:58
    That's really good results, I need to guve that a try one of these times. I use the photo resist method and get great results. but it is a little more spendy.
    I am curious if you can provide some more info on the muriatic acid and H²O². do you mix the two together, or one after the other? some insite. before hitting Google would be preferred.
    thanks
    oops been a while since chemistry, Hydrogen per oxide isn't HO
    A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
    Post Edited (Dgswaner) : 8/13/2007 1:53:50 PM GMT
  • D FaustD Faust Posts: 608
    edited 2007-08-12 23:03
    This may some nieve, but how do you solder such small things without connecting one IO to another? Do you use a special iron/technique, or do you just have to have a steady hand?
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
  • pwillardpwillard Posts: 321
    edited 2007-08-12 23:27
    DG: 1 Part Muriatic Acid (Head away when your pour) 1st then 2 Parts Hyrdogen Peroxide... Gootee's site talks about it. ( $5 per gallon versus $5 a pint of ferric chloride)
    D FAUST: I use a clean, fine point tip on my ancient (Circa 1977) Weller WTCP200 and magic flux ---> Qualitek - Water Soluble Flux - HIGHLY NASTY... finger pump spray liquid... must wash off RIGHT after soldering. I'm not sure I'd have done as well without it. I just tacked a quick blob on each column of surface mount pads ans used the layer of liquid flux to thin coat solder from the pads out to the edges. The flux made it easy.
    edited 2007-08-12 23:40
    Is the H2O2 the 3% stuff that's sold as an antiseptic, or something more high-test?
    edited 2007-08-12 23:53
    So the key is flux and a fine tip. Flux is used for what? Sorry for my lack of knowledge. Wikipedia didn't help.
    END
  • Harrison.Harrison. Posts: 484
    edited 2007-08-13 00:14
    I have also had great results using the Gootee method. I made a simple usb to logic level serial converter using the FT232RL usb-to-serial chip (SSOP footprint). I was surprised how easy it was, especially since I had never soldered a surface mount chip in my life before.
    Making your own PCBs does take some time, but it is very rewarding. Almost anyone can do it, heck I was 16 at the time and was able to do it with little previous experience.
    Harrison
    Post Edited (Harrison.) : 8/13/2007 12:21:11 AM GMT
    1144 x 829 - 214K
    edited 2007-08-13 00:41
    Are there any good tutorials on the web for such things?
    END
    edited 2007-08-13 03:06
    It's certainly not pretty... but read that Gootee page I linked.· It's a good read about doing it yourself.· Until I tried it this way... my results were not so good.
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-08-13 04:18
    Scroll down about halfway. There's some tutorials on surface mount soldering.
    Sparkfun Tutorials
    - Rick
    edited 2007-08-13 04:41
    I'd seen that one a while back... my thinking... is that with enough good flux, you can skip the desolder braid. It worked that way in my case. I actually applied NO solder to the part only to the board. I re-flowed the solder under the pins and the flux did the rest.· Flux is to solder like a wetting solution is to water slide decal application or· think of·it doing to solder what that "spot free rinse" agent does to the water on your car at the car wash.· You can skip using it, but your results are so much better and cleaner if you do use it.· So in my mind, flux is wetting solution for solder.
    Post Edited (pwillard) : 8/13/2007 4:55:40 AM GMT
    edited 2007-08-13 11:34
    END
  • crgwbrcrgwbr Posts: 614
    edited 2007-08-14 16:08
    Phil Pilgrim (PhiPi) said...
    I have used 3% before, it works very well. When you're done with the acid/H2O2 mixture, you can save it for a couple weeks. However, be sure that you put it in a light opaque container. Once I put 1.5 liters of the etch solution in a clear soda bottle with the cap on it. I came back in two weeks to find that several parts of my storage room had been damaged by shrapnel from an exploding soda bottle and that the shelf had been damaged from the etch solution pouring out of the bottle after it exploded.
    My Blog: Prog | Electro | Mech
    I would love to change the world, but they won't give me the source code
    People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows.
    I spent a minute looking at my own code by accident. I was thinking "What the heck is this guy doing?"
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-08-14 18:19
    I found a great site that has all kinds of details and "war stories" about making your own PCB's:· http://tech.groups.yahoo.com/group/Homebrew_PCBs/
    Lots of great info, techniques and quite an active community!
    Steve
    edited 2007-08-14 19:32
    I've been reasearching and lurking there on that Yahoo group a long time... it's a good group oddly enough. It has me thinking I want to find a reason to buy a heat laminator from OfficeMax and toss my clothes iron.
  • ghost13ghost13 Posts: 133
    edited 2007-08-15 00:26
    Is there a household copper etchant (like something you can buy in the market or mix two household chemicals together)?
    edited 2007-08-15 02:13
    Yes, that's what we've been talking about. Concrete Etchant from the hardware store (Muriatic Acid) and Hydrogen Peroxide solution from the pharmacy. the kind you might clean a wound with. 1 part acid, 2 parts peroxide. Needs no added heat like Ferric Chloride. Read Gootee's web page about it.
    edited 2007-08-15 02:29
    Ohhh. Ok - thanks [noparse]:D[/noparse]
  • David H.David H. Posts: 78
    edited 2007-08-20 18:19
    pwillard;
    I'm new to this, and am thinking of trying to make my own pcboard. What type of material do you use with your printer to transfer the traces to the bare board that are resistent to the etching solution?
    David
    There are 10 types of people in this world,...
    Those that understand binary numbers, and those that don't!!!
    edited 2007-08-20 19:27
    "The very BEST paper I've found (basically PERFECT!) is sold as Staples "Picture Paper" [noparse][[/noparse]Update: As of 04/2007 and earlier, the paper is now sold as Staples "photo basic" "gloss" for "all inkjet printers"]. It's available at Staples "office supply" stores, in the USA. (And also from their website, at http://www.staples.com .) [noparse][[/noparse]I almost can't believe that I didn't try that paper, before. It's one of the very FEW that I didn't try...!]"
    This comes from the first linked site.
    FYI·injet printers don't work, for reasons why, see pwillard's first link.
    END
    edited 2007-08-20 20:20
    Staples brand photo basic glossy photo paper... the cheap stuff, as spoken about on Gootee's site.
    I agree with the assessment. I use that paper now too.· The paper, once soaked for a few minutes in water, rubs·off from the backside by just using your thumb and some pressure.· You do not need to rub all of the paper off where·the toner is, just where·the toner·*isn't* since a little may stick to the toner. You are protecting the copper with the toner so paper on the backside of the toner has no impact.· When you can see all the copper that is not covered·by toner shining without paper over it, you are done and ready to etch.· I use light brushing with an old toothbrush to get the last stubborn bits.· The whole process of removing the paper from the backside just takes a few minutes.
  • Twisted PairTwisted Pair Posts: 177
    edited 2007-08-20 20:54
    I use the Press n Peel sheets, Laser Printer, Heat Table ( replaces hand held iron), and Ferric Chloride. I can't help but wonder if the Muratic acid solution is having some kind of long term damaging effect on the PCB material. Does anyone have an older board that has been etched in the muratic acid solution ? If so, were there any defects ? This solution would be great to use if there are no side effects from it's use.
    Twisted Pair....
    edited 2007-08-20 20:55
    Thanks, I'll check out the website and maybe try my hand at it.
    Thanks for the info.
    David
    edited 2007-08-20 22:11
    Many years now... no side effects. It's really almost the same as FECL, just a tad stronger.
    Watered Down Hydrochloric acid is known as Muriatic Acid.
    FYI: The stuff from Radio Shack --Ferric Chloride Solution-- (FECL) is in my opinion the waste product from a Steel Mill pickling process. What is that? It's a checmical process to prepare steel for fabrication after it's been in storage for a few days. They use Hyrdrochloric Acid baths to remove "RUST" from the sheet steel. The RUST becomes a solution with the HCL that eventually becomes FECL. You see, a side effect of Muriatic Acid solution, apart from etching concrete (being watered down HCL) is that it's really good at removing rust.
    I'm assuming that Radio Shack buys this Steel Mill Pickling WASTE product and ships it to stores as FECL as a less active acid for copper etching.
    See why I think that the two chemicals are not so far removed from each other?
    Muriatic Acid is cheaper... and See Through... Much better for etching. It is, however, much stronger... and etches in 1/4 to 1/2 the time of FECL.
    This conclusion is merely a product of my own active imagination and some online research.
    pw
    Post Edited (pwillard) : 8/20/2007 10:16:21 PM GMT
    edited 2007-08-20 22:38
    PW,
    That's very interesting. I always thought that the ferric Chloride was a new mix made for consumers and etc. If we the consumers only knew how things were made we could make it ourselves and not have to buy it from the people that do know....I will try the solution. This solution will cut down on my etch times and as you mentioned, the cost....What could be better....By the way, what role does the Hydrogen peroxide play in the mix ? Agitation ?
    Thanks....
    Twisted Pair....
    edited 2007-08-20 23:23
    I'm not a chemist.
    But from what I understand, as long as you have an acid and an oxidizer the·mixture will eat the copper metal. The peroxide is the oxidizer and you just add a bit more peroxide·if the reaction·seems slow because if you get it wrong, it will not eat the copper and may even attack the toner.
    In my case, I get best results with 2 parts oxidizer (peroxide) to 1 part acid.· If the mixture is not quite right, it will produce no bubbles as all.· When it's right, it will produce a few bubbles... it may bubble quite a bit when you wipe with a paper towel.· That's all I do, by the way... wipe the surface with a paper towel a few times.· It's reacting to the paper towel, from what I can tell.
    Always wear protection.· I wear rubber gloves, and everything else is plastic.· I use a small diameter (1") short plastic tube with a wad pf paper towel in the end as a wiper.· I only ever wipe a board about 3-4 times during the etching process.
    edited 2007-08-21 00:16
    Ok PW,
    I will give it a try....I noticed in the photo of your PCB, that the copper traces had a solder coating on them to allow for easier soldering of components to the board. What do you use to accomplish that ?
    Twisted Pair....
    edited 2007-08-21 02:19
    Nothing but flux and solder...
    As I said in the thread, I used a good flux and let the iron flow coat the small amount of solder I added to the IC chip pads.· I know people have mentioned blobbing solder on and then using solder wick to clean up, but I just haven't had to do that, nor do I want to.
    There was a company (now sadly out of the business) called KEPRO that made a great·product called "room temperature immersion tin plating" solution.· It came pre-mixed and ready to use.· I much preferred that method of plating the the copper but if done carefully, solder can work too.
    I've tried the heat and·mix tinning·crystals but·either·I must have done it wrong or it's just that nasty to use.· My results were bad.
    I really dislike bare copper on DIY boards but I haven't figured out how to do a·solder mask·with conformal coating.
    FYI: My very first job out of high school was a summer job operating a wave flow solder machine.· That was as closeset I ever got to an EE job but have remained a die hard hobbyist regardless of the current trends.· There is something about the beauty of flowing molten solder that has stuck with me to this day.· I'm dating myself by·saying that FREON was·the preferred board cleaner... can you figure out about when that was?
    Post Edited (pwillard) : 8/21/2007 2:27:00 AM GMT
    edited 2007-08-21 03:29
    PW,
    You did a nice job laying on the solder to the traces. I have seen dry powder tin plate mixes on the market but haven't tried them or done any research on them. I'm not sure if the tin plating would be worth the extra time and cost. I use a silicon conformal coating called Final-L-Coat on my PCB's. It works fine but the bare copper is still visible as this coating is clear. I remember the company Kepro. To bad there gone now. I have ordered a few things from them in the past. I guess all good things must come to an end. In regard to the Freon dating, I think that I read an article in 1969 that talked about how the Saturn V rocket (the moon shot), components were made and in particular, how the Nasa designed computers were built. This article mentioned the PCB's and the freon that was used in the cleaning process. Now, who's dating who ?
    Thanks PW....
    Twisted Pair....
  • Blackbird455Blackbird455 Posts: 124
    edited 2007-09-24 16:07
    What is a good layout program that doesn't cost $827 ? Cam you use the free "pcb 123" software to do this?
    Noli nothis permittere te terere
  • BeanBean Posts: 8,129
    edited 2007-09-24 16:35
    For tinning boards I use a product called "liquid tin" MG chemicals sells it. http://www.mgchemicals.com/products/421.html
    It works great. Just put the board in it and it almost instantly turns silver (color). No mixing or anything, it's ready to use.
    It is very strong though. ALWAYS WEAR GOGGLES AND GLOVES.
    Bean.
    I know what I know, don't confuse me with the facts...
    www.hittconsulting.com
