Need help getting started with Microsoft Robotics Studio 1.5 — Parallax Forums
Steve JoblinSteve Joblin Posts: 784
edited 2007-10-29 19:31 in Robotics
Don't know if I should post this here or in the Robotics forum, so appologies in advance.
I am trying to follow the Parallax text ( MSRS Bluetooth Boe-Bot® Robot (#28118) v1.2), but getting stuck at the first step [noparse]:([/noparse]
I've downloaded Microsoft Robotics Studio v1.5
When I run the Robotics Studio Command Prompt, I get a message at the top that says...
Setting environment to use Microsoft .NET Framework v2.0 SDK tools.
For a list of SDK tools, see the 'StartTools.htm' file in the bin folder.
I enter in CD samples\Platforms\Parallax\BASICStamp2, and press the enter key.· I then type BASICStamp2.csproj
but all I get is a pop-up saying that Window can't open this file and asks me to find a program that can...· It is as though it does not recognize files with a .csproj extension.
I don't think MSRS is installed correctly (as evidenced by the message I get when I run the MSRS Command Prompt.
Any ideas?
  • WhitWhit Posts: 4,194
    edited 2007-08-02 14:30
    Steve,
    This should be in the Robotic's area, I think (so someone may move it).
    There have been lots of posts about this on the forum. A search of the forum might help get you started. Andy Lindsay has helped a lot of people get started. He seems to be away doing classes for educators.
    The best way to search is http://search.parallax.com·(as opposed to the search button above) - see this thread for why -http://forums.parallax.com/showthread.php?p=562370 Using the search for the forum, I found this thread, for example.
    http://forums.parallax.com/showthread.php?p=655003
    Hope this helps. - Good luck getting it going.
    Whit+
    Post Edited (Whit) : 8/2/2007 5:54:12 PM GMT
  • LearnerNMLearnerNM Posts: 8
    edited 2007-08-02 18:07
    Steve,
    You will also need Visual C# Express or higher to open those files. Its free from MS.
    http://msdn.microsoft.com/vstudio/express/visualcsharp/
    Regards
    LearnerNM
    edited 2007-08-02 18:58
    This thread is being moved from the BASIC Stamp Forum to the RObotics Forum.
    Chris Savage
    Parallax Tech Support
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2007-08-02 23:36
    Just so you know, .csproj is a Visual Studio CSharp Project file.
  • Tom CTom C Posts: 461
    edited 2007-08-03 00:34
    Hi Steve,
    You also might want to fall back to MSRS v 1.0 as I think that there were problems with v 1.5 and the BoeBot GUI C# code.
    Just a thought.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-08-03 00:41
    Thanks all! I've removed MSRS from my system... I think I need to wait for it to mature a bit more before a newbie like me plays with it... It doesn't seem like it has taken off like I thought it would have... wonder why?
    edited 2007-08-03 04:45
    If you're just looking to mess around with some PC / Robot interaction, take a look at my post here:
    http://forums.parallax.com/showthread.php?p=663025
    It should give you some ideas.
    edited 2007-08-03 12:18
    Thanks much Kevin... unfortunately, I don't know C... what peaked my interest in MSRS was the VPL that is now included as part of version 1.5
  • edited 2007-08-06 23:09
    Steve,
    You can program in VPL with MSRS (1.0), and it does work with the Boe-Bot robot. Interested in giving it a go?
    Andy
    Andy Lindsay
    Education Department
    edited 2007-08-07 12:36
    Thanks so much Andy... I can't tell you how much I appreciate your willingness to help me out!· I think I am going to wait a bit... there are some books that are suposed to be available this fall... I think I want to wait a bit for some more documentation and for the product to gain a bit more momentum... I will likely ask for your help later this year or early next.
    Again, thanks so much (in advance) for your help [noparse]:)[/noparse]
    Steve
  • edited 2007-08-07 18:19
    Any time Steve.
    Looking forward to hearing from you when you are ready to get started.
    Andy
    Andy Lindsay
  • adiadi Posts: 7
    hallo there,
    had anyone a clue(reference) how to use Javelin Stamp(with demo board) with MSRS? confused.gif
    I found only some reference for boebot
    Thanks in advance,
    Adi
