Need help getting started with Microsoft Robotics Studio 1.5
Don't know if I should post this here or in the Robotics forum, so appologies in advance.
I am trying to follow the Parallax text ( MSRS Bluetooth Boe-Bot® Robot (#28118) v1.2), but getting stuck at the first step [noparse]:([/noparse]
I've downloaded Microsoft Robotics Studio v1.5
When I run the Robotics Studio Command Prompt, I get a message at the top that says...
Setting environment to use Microsoft .NET Framework v2.0 SDK tools.
For a list of SDK tools, see the 'StartTools.htm' file in the bin folder.
I enter in CD samples\Platforms\Parallax\BASICStamp2, and press the enter key.· I then type BASICStamp2.csproj
but all I get is a pop-up saying that Window can't open this file and asks me to find a program that can...· It is as though it does not recognize files with a .csproj extension.
I don't think MSRS is installed correctly (as evidenced by the message I get when I run the MSRS Command Prompt.
Any ideas?
Any ideas?
This should be in the Robotic's area, I think (so someone may move it).
There have been lots of posts about this on the forum. A search of the forum might help get you started. Andy Lindsay has helped a lot of people get started. He seems to be away doing classes for educators.
The best way to search is http://search.parallax.com·(as opposed to the search button above) - see this thread for why -http://forums.parallax.com/showthread.php?p=562370 Using the search for the forum, I found this thread, for example.
http://forums.parallax.com/showthread.php?p=655003
Hope this helps. - Good luck getting it going.
Whit+
Post Edited (Whit) : 8/2/2007 5:54:12 PM GMT
You will also need Visual C# Express or higher to open those files. Its free from MS.
http://msdn.microsoft.com/vstudio/express/visualcsharp/
Regards
LearnerNM
You also might want to fall back to MSRS v 1.0 as I think that there were problems with v 1.5 and the BoeBot GUI C# code.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
http://forums.parallax.com/showthread.php?p=663025
It should give you some ideas.
You can program in VPL with MSRS (1.0), and it does work with the Boe-Bot robot. Interested in giving it a go?
Andy
Andy Lindsay
Education Department
Again, thanks so much (in advance) for your help [noparse]:)[/noparse]
Steve
Looking forward to hearing from you when you are ready to get started.
Andy
Andy Lindsay
had anyone a clue(reference) how to use Javelin Stamp(with demo board) with MSRS?
I found only some reference for boebot
Thanks in advance,
Adi
