What would you want more of, cogs or RAM? - Page 18 — Parallax Forums
1151618202129
  • Fabian NunezFabian Nunez Posts: 29
    edited 2007-07-08 22:44
    This chip is definitely shaping up to something nice! All that I ask is that a PLCC version of the chip be made, so that I don't have to hand solder over 64 tiny pads 1mm or less apart. With a PLCC chip, I can solder a socket with a nice .1" spacing, and have a pretty high degree of certainty that I haven't shorted anything (and, because it's through-hole, a 100% certainty that the chip is properly lined up)
  • CJCJ Posts: 470
    edited 2007-07-08 23:05
    looks like the next propeller is going to make small grids of the current one obsolete, 4x4 gen1 = 1 gen2 approx.
    pocket supercomputer anyone?
    Parallax Forums - If you're ready to learn, we're ready to help.
  • HarleyHarley Posts: 997
    edited 2007-07-08 23:35
    Decided to update the previous listing. (to forum moderator - delete old one if desired)
    Again, the editor changed the formatting; may be because 'table' originally was in monospaced (iMac) Monaco font. I have left it as it pasted in.
                         Propeller, gen.2 info - rev: 8 Jul.2007
    Feature           Quantity            comments                         Forum pg/date/time
    Cogs             16                160 MHz, pipelined instr. /clock    pg1/25Nov06/12:32a
                                       (2 clocks for Hub instr);           pg1/25Jun06/12:52a
                                       512 longs/cog; w/full speed Hub     pg7/30Nov06/12:39p
        pg17/24May07/11:12a
        pg19/28Jun07/9:26a
        pg20/4Jul07/7:18p
    Memory                      RAM=256KB on-chip                                      pg17/24May07/11:12a
                    ROM=128K                                               pg20/4Jul07/8:36p
        pg20/4Jul07/7:18p
    I/Os            64                                                     pg17/24May07/12:50p
    Clock input     min - max freq ?
    PLL    speed       160 MHz max
    Packaging          QFP preferred                                          pg19/19Jun07/6:03p
                    QFN ?
                    LQFP ?
                    BGA ?
                    thru-hole DIP NO ?
    Other pins         3.3v (I/O) 4 ?     64 I/Os plus these totals 80 pins   pg2/25Nov06/11:26a
                    1.8v (I/O) 4 ?
                    Gnd     4 ?
                    Rst/ 1
                    BOE/ 1 ?
                    Clock 2
    16x16 multiply  1 ?                                                    pg19/23Jun07/3:59p
    Dev Sys onchip                      in ROM                             pg20/4Jul07/11:40p
    Availability   probably a year away                                    p3/25Nov06/1:10p
                   2 yrs, conservative                                     pg5/7Mar07/12:00p
                   between 1 - 2 years                                     pg15/7Mar07/12:08p
    Longevity      most likely for                                         pg8/5Dec06/6:01a
                   next 15-20 years
    'code name'    P-Chip 2                                                p15/7Mar07/12:08p
    legend: '?' = not yet defined by Parallax
    Beau Schwabe - IC layout engineer, Parallax                                            pg15/7Mar07/9:53p
    Harley Shanko
    h.a.s. designn
  • griddickgriddick Posts: 1
    edited 2007-07-27 21:16
    Just my .02$ on what to put into the large ROM space of the propeller V2.
    It would be excellent to have functions for creating on-screen(vga etc) widgets like tabs, buttons,sliders,text,simple graphics(gif),etc.
    Each widget could have associated event handlers to pick up on keyboard and mouse input.
    Since this would be needed for a development system anyway, why not make them available for general use?
    Something approaching the functionality of this would be great.
    www.amulettechnologies.com
  • evanhevanh Posts: 16,490
    edited 2007-07-28 13:05
    Fabian Nunez said...
    The 84 pin package would be needed to bring out all 64 I/O, that's a big package! Or maybe a 68 pin package with a slightly reduced I/O count would be a better config with PLCC.
    Actually, this idea could extend down to using a 32 pin QFP/24 pin skinnyDIP or something like that for cheaper/smaller options. Still using the same die with all 64 I/O internally available for IPC.
    Evan
    edited 2007-07-28 14:41
    And for future voting I'll vote for a 32 Cog version, even if it means reducing the hub RAM size. The more MIPS the merrier! [noparse]:)[/noparse]
    At this point, making the Hub's round robin indexing engine smarter might be in order also.
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-07-28 16:37
    evanh said...
    Please elaborate ...
    QuattroRS4
    'Necessity is the mother of invention'
    edited 2007-07-28 16:59
    QuattroRS4 said...
    Off the top of my head, adding a request bit for each Cog that goes true when that Cog is waiting for bus access and having a priority encoder applied to the index adder instead of just the existing +1 incrementing.
    Something like, index = encoder - index
    Evan
    edited 2007-07-28 17:10
    No, not quite right. [noparse][[/noparse]couple of edits later ...]
    Needs to have a barrel shifter of the pending bits, rotated by the index register value. The output of this shifter can then be priority encoded and added back to the index.
    Evan
    edited 2007-07-28 17:19
    This sounded a bit familiar .... I knew I read it somewhere..
    United States Patent 20070089112
    An apparatus for selecting one of N requestors of a shared resource in a round-robin fashion is disclosed. One or more of the N requesters may be disabled from being selected in a selection cycle. The apparatus includes a first input that receives a first value specifying which of the N requesters was last selected. A second input receives a second value specifying which of the N requesters is enabled to be selected. A barrel incrementer, coupled to receive the first and second inputs, 1-bit left-rotatively increments the second value by the first value to generate a sum. Combinational logic, coupled to the barrel incrementer, generates a third value specifying which of the N requesters is selected next.
    ··········· QuattroRS4
    Post Edited (QuattroRS4) : 7/28/2007 5:25:58 PM GMT
    edited 2007-07-28 17:24
    Ok, the purpose is to auto-skip any/all Cog cores that aren't waiting for service.
    Eg: Setup 6 of the 8 Cogs doing hardware like functions where they only access Hub memory to update it when the I/O conditions dictate. Leaving the remaining two Cogs to alternate say 90% of the Hub slices between them.
    Admittedly, this means variable results for main memory bandwidth from an individual Cog's pov.
    edited 2007-07-28 17:38
    QuattroRS4 said...
    Lol, typical. All the obvious stuff. No wonder there is so many complaints.
    I mean that is really basic stuff - One shift, one encode, and one add.
    Evan
    edited 2007-07-28 18:21
    Evanh,
    Yip - it's the way of the world as we know it !
    QuattroRS4
    edited 2007-07-28 18:31
    It would be interesting to know how many patents Parallax have enquired about. Since every single function inside the Propeller will be covered by older patents. Even the basic bit-shift for example!
    edited 2007-07-28 19:03
    This has been discussed a bit earlier in the thread, but one of the main advantages of the Propeller's hub setup is that the timing relationship of one cog to another is fixed once the cogs synchronize to each other including hub memory access. It make things like the video drivers much easier for example. If you add a priority scheme, you lose this. What has been discussed as a possible implementation is that of a settable hub access assignment. All cogs would have at least one hub access per cycle and the other 8 access slots could be assigned to specific cogs during program initialization (much as the clock mode can be reset, but not without affecting everything). This keeps the predictability, but allows cogs with low bandwidth needs to hub memory to contribute some of their resources to other cogs.
  • CardboardGuruCardboardGuru Posts: 443
    edited 2007-07-29 12:58
    [noparse][[/noparse]quote]Admittedly, this means variable results for main memory bandwidth from an individual Cog's pov.
    Yes, it's a trade-off between determinism and maxing out the MIPS. I'd guess for most scenarios that you'd use a propeller for, predictable response is more important than maximum throughput.
    Help to build the Propeller wiki - propeller.wikispaces.com
  • Dennis FerronDennis Ferron Posts: 480
    edited 2007-07-29 20:27
    I agree. It's the fact that an assembly driver running in one cog has almost zero ability to mess up one running in another cog that is the genius of the Propeller. The isolation, the lack of interaction even on timing issues, is what allows someone to combine many different pieces of code and still have confidence that they'll work as well together as they did separately.
  • SkogsgurraSkogsgurra Posts: 231
    edited 2007-07-29 20:35
    That is also very true. And (an often overlooked) additional benefit is that you don't have to worry much about interrupt latency - or priority. That nightmare grows gradually and gets tough when you have five or six interrupt sources and can't really decide which has priority or how long it can wait, worst case. I have been into that several times. And I do not wish to go there again.
    Is there a T-shirt with a red heart and a propeller on it? I think that I would look good in one smile.gif
    edited 2007-07-30 17:06
    We plan on implementing wide data path fetching to overcome memory bandwidth issues of larger cog counts. This way we can maintain the determinism and improve the bandwidth.
    Paul Baker
    edited 2007-07-30 22:09
    That's the batch read / write scheme right?
    edited 2007-07-30 22:47
    Correct, I think the plan is for somewhere between 4 and·16 longs, don't remember the specific number off the top of my head.
    Paul Baker
  • hinvhinv Posts: 1,255
    edited 2007-07-31 01:53
    Yahoo!
    So we are talking about a 16 cogger with somewhere between 160MB/Second bandwidth for each cog all the way up to possibly up to 640MB/Sec/cog
    Very Cool, Lots of Cogs and bandwidth too.
    Any final word on Hub Memory Size? 128K? 256K? 512K?
    How about booting. For a quick boot is there the option to just load to the end of the program size, not the whole eeprom?
    Now I an see the demo boards for this thing are going to have DVI connectors, 100BaseT, 6 Channel audio, USB 2.0 etc! jumpin.gif
    And with 64 pins, strapping on an extra couple of megabytes of ram shouldn't be too tough!
    With that kind of bandwidth, maybe I could do a SCSI to MicroSD raid controller!
  • edited 2007-07-31 15:03
    You sound a little loopy, but that would probably·be possible with the propellor 2. but 640 MB a second sounds like a myth for the prop 2, If you want that speed, you'd have to do quite a bit of work to get it to do perfectly. right now I belive the fastest bandwith speed ever done on the prop 1 was about 6 MB per second. Still, it doesn't mean all that extra ram for programs and all those cogs plus a USB hardrive and whatever ethernet stuff you connect can't make it possible!
    I hope that they implement it, perhaps also support Png's Jpegs' and TNG's. So that you can browse the internet without seeing X's on all those images.
    But, I doubt that the demoboards are gonna have ALL that. But hopefully they will at least have the DVI connection and·a USB hardrive for storage incase of large programs.
    Realize that I am really a mad scientist··· and
    Don't forget it!
    http://raydillon.com/Images/Illustration/GameArt/WildIsle/WildIsle-Ink-ScientistClose.jpg
  • Lord SteveLord Steve Posts: 206
    edited 2007-07-31 15:06
    Will the single-cycle multiplier be the 16x16=32 bits variety?· Will there be a "long" multiply 32x32=64 bits?
    How many blowable fuses will be present?
    What's the real reason why we can't be treated to a Propeller with FLASH in lieu of that EEPROM?· If it's "the process", then why can't that be changed?· It does seem kinda silly that Parallax is of the opinion that dedicated peripherals is wasted silicon, yet all my precious non-volatile storage is being wasted on dedicated tables.· That being said, I enjoy working with it. [noparse]:D[/noparse]
    Ready to be flamed.
    edited 2007-07-31 15:29
    The multiplier is 16 x 16. There won't be a hardware 32 x 32 multiplier. You'll have to do that with a short subroutine.
    The real reason we can't have on-chip flash memory is exactly what has been stated. The manufacturing process used for the chip cannot create the proper structures for flash memory. I suspect that it can't be changed because the tradeoffs in choosing a process would markedly increase the cost of the chip or require that some of the functionality be dropped.
    You may think it was silly to give up dedicated peripherals, but it was a well thought out design decision to not have dedicated peripherals and to use general purpose processors to implement any dedicated functions. You may not like it, but it was not lightly chosen. Designers get to make those kinds of choices.
    Again, it was not an option to have flash memory on-chip. On the other hand, ROM is made using the same kinds of structures as the rest of the chip and a certain amount of ROM was needed for the boot loader and the Spin interpreter. The dedicated tables are of two kinds: 1) font tables; 2) transcendental tables. The first goes with the other video-friendly features. The second has been a built-in feature of the Stamps since the beginning and is useful in robots and sensor processing. ROM is pretty cheap in terms of chip area, so, once some ROM had to be included, 32K was the next useful size boundary. What would you have put in there that would have been available early in the chip development?
  • datacpsdatacps Posts: 139
    edited 2007-07-31 18:35
    ······· I would like to be able to write code in SX/B for this chip. I need to use this chip for one of my applications but I don't know Spin or assembly. I would like to suggest that if you offer a PBASIC compiler for the propeller I think it would open the door for newbie’s like me.· Parallax has given me an opportunity to develop my own projects. I think if you provide ways to program all your chips in a basic environment it would open more doors for us all. I moved through the BS1 and BS2 pretty quick. I am using the SX chip now but I would like to use the Propeller chip to output a freq from 100 to 50mhz. I heard this chip can do what a DDS chip does but I can’t write in assembly or spin so I have to add a Co-processor to communicate to the DDS chip with 32 bit word in order to output ·the frequency I want.· I heard the propeller can do that. It probably won’t happen but I put in my 2 cents..
    edited 2007-07-31 18:53
    While it's always nice to be able to use the tools that you are used to, it doesn't always make sense. The SX does things very differently from the Propeller and, except for built-in basic functions, you can't just convert from one to another. A lot of things that are done easily with the Stamps or demonstrate functionality (like frequency synthesis) are already written for you as library routines or sample programs in Spin, possibly with some bits in assembly where needed. They're well commented and can often be used as is or with minor changes. You'll find stuff like this in the Propeller Object Exchange or included with the Propeller Tool.
    I think, particularly if you start with the tutorials from the Propeller Education Kit, that you can learn Spin fairly quickly, particularly starting with the examples that are close to what you need for your project. You could also use something like FemtoBasic which is a very simple interpreted Basic, but does allow access to the I/O pins and to the counters used for frequency synthesis.
    I don't think you'll see anything like PBasic any time soon. What resources are available at Parallax are best spent in development of teaching tools (texts, tutorials, further well documented examples) for Spin and assembly, let alone the development of future Propeller chips.
  • BaggersBaggers Posts: 3,019
    edited 2007-07-31 18:55
    Paul Baker (Parallax) said...
    Hi Paul, has it all been finalised?
    Or would something like load multiple bytes into longs be possible to add? ie read one long from hubram and put it into 4 longs in cog ram etc?
    That would come in handy too. [noparse]:)[/noparse]
    Just my 2p's worth.
  • edited 2007-07-31 19:07
    The Prop 2 is amazing...Infact it's essentially exactly what I've always wanted the prop 1 to be! [noparse]:o[/noparse]
    This prop 2·seems·to have more than enough power to generate a 16 bit sprite engine with scaling,rotation,parallax scrolling and 3d floormapping along with tiles...
    Don't forget it!
    Post Edited (Bob the Builder on a C64) : 8/1/2007 9:39:14 PM GMT
    edited 2007-07-31 23:55
    Hey Bob, the prop2 does make you kind of loopy just thinking about it doesn't it!
