TV out (PAL)? — Parallax Forums
TV out (PAL)?
simonlsimonl Posts: 866
edited 2006-09-27 10:49 in Propeller 1
I've read that Propeller has TV output, but everything I've read says that's NTSC. As I live in the UK, I wonder if the Propeller can output to a PAL TV?
Also, how do I interface to a TV or VGA monitor (which pins, and what components are required)?
Cheers,
Simon
Post Edited (simonl) : 6/27/2006 12:43:42 PM GMT
    edited 2006-06-27 12:44
    Well, for TV TEXT mode, it's very easy...
    http://forums.parallax.com/forums/default.aspx?f=25&m=126465&g=126467#m126467
    What you need is a couple of resistors and a connector.
    Take a look at the chematics of the Demo board for the details of which pins and resistors to use.
    Don't visit my new website...
    edited 2006-06-27 16:58
    For any object that uses the TV.SPIN object, there is a table of data which configures the TV.SPIN object at start time. There is a long within this structure called "mode". It's LSB can be set to 0 for NTSC or 1 for PAL.
    Chip Gracey
  • edited 2006-09-27 10:49
    Hello !
    I´m using the tv spin with the composite input of a a
    terratec cinergy xs usb stick.
    NTSC: interlaced + non-interlaced works very fine
    PAL:·· interlace seems to work - non-interlace - looks interlaced
    ········ but both pal modes with poor quality
    Works PAL better if using different oscillator frequency + settings ?
    I already asked the support of terratec to verify if there is a problem
    with non-interlaced at their side -
    Is there anything known about pal problems ?
    rgds,
