TV out (PAL)?
I've read that Propeller has TV output, but everything I've read says that's NTSC. As I live in the UK, I wonder if the Propeller can output to a PAL TV?
Also, how do I interface to a TV or VGA monitor (which pins, and what components are required)?
Cheers,
Simon
Post Edited (simonl) : 6/27/2006 12:43:42 PM GMT
Cheers,
Simon
http://forums.parallax.com/forums/default.aspx?f=25&m=126465&g=126467#m126467
What you need is a couple of resistors and a connector.
Take a look at the chematics of the Demo board for the details of which pins and resistors to use.
Don't visit my new website...
Chip Gracey
I´m using the tv spin with the composite input of a a
terratec cinergy xs usb stick.
NTSC: interlaced + non-interlaced works very fine
PAL:·· interlace seems to work - non-interlace - looks interlaced
········ but both pal modes with poor quality
Works PAL better if using different oscillator frequency + settings ?
I already asked the support of terratec to verify if there is a problem
with non-interlaced at their side -
Is there anything known about pal problems ?
rgds,
