48x84, Small Graphic LCD w LED backlight. — Parallax Forums
Clock LoopClock Loop Posts: 2,069
edited 2014-11-29 10:39 in General Discussion
********************PROGRAM and SCHEMATIC UPDATED 01-20-06, LOOK AT LAST POST*****************
SX-B program available too.
84x48 Graphical Dot LCD's with Back L.E.D., and Useable Keypad. LCD is serially addressed using the SHIFTOUT command.
**NO WIRES**
http://forums.parallax.com/attachment.php?attachmentid=39336
----FRONT
BACK
Without Wires.
http://forums.parallax.com/attachment.php?attachmentid=39343
With Phone Case
http://forums.parallax.com/attachment.php?attachmentid=39342
This is in NO WAY an offer from anyone at parallax, they DO NOT offer support for these LCD's.
Programming help is offered here, from me! But these LCD's are so easy to use, I doubt you will need support.
If you have any questions, or want one, send me a Private Message.
For more info on the USE of the LCD Go here.
http://forums.parallax.com/showthread.php?p=555533
To get an idea of the size of the LCD, if you take 2 BS2 chips and put them side by side, the LCD is about that big.
They are not Big, but they are cheap, and can be used in PAIRS for larger viewing area.
Attached is a program that will display "Parallax Rules" on your LCD when wired up like the attached schematic.
Meh. Nothing here, move along.
Post Edited (BPM) : 6/1/2009 5:04:33 PM GMT
    edited 2005-11-07 02:45
    Coming soon will be schematics and programming to get the vibrator, speaker, and keypad parts to work.
    And in the end one big schematic to get all devices to work from as little as possible wires coming from the BS2. (using shift registers) 74hc595(serial in parallel out) & 74hc597 (parallel in serial out).
    edited 2005-11-22 02:24
    ***PROGRAM UPDATED 11-24-05 FOR BETTER KEYRESPONSE, POWER BUTTON OPERATION, BACK LED OPERATION***
    *** SCHEMATIC ALSO UPDATED TO INCLUDE POWER BUTTON, and BACKLIGHT.***
    The program makes the LCD and LED turn off when you press the PWR button.
    This brings the ampere draw to only 1.3ma in the OFF state.
    In the ON state, the LCD and LED draw 70 ma, most of that being the LED, the LCD draws 2.8ma in the ON state.
    ***PROGRAM UPDATED 11-22-05 FOR BETTER KEY RESPONSE, NO MORE INCORRECT KEYPRESS DETECTIONS***
    The keypad code and schematic is done.
    Here...
    The provided code will display what button is pressed in the very middle of the display. When you let up on the button, the display also clears.
    The schematic uses a 595, and a 597(aka 165).
    Post Edited (BPM) : 11/25/2005 3:00:50 PM GMT
    888 x 941 - 35K
  • clcl Posts: 1
    edited 2005-11-24 17:26
    in the picture with the blue wires soldered onto the phone circuit board , im trying to figure out which pins are which. i cant find that info in your pictures, or the datasheet. there are 9 pins on the lcd, but i dont think i can solder directly onto them, so im gonna solder where you did. do you have a picture with pin info? thanks a lot
    edited 2005-11-24 18:04
    Sure, I thought I provided that info here, I must have deleted it accidently when updating the program and schematic.
    Heres a GIF that will tell you the proper pinout, this is a closeup of the connector.
    And the definition of each pin:
    Every BOLD item are the ones you will use to get the LCD light on, and the LCD working to display intro code “Parallax Rules” when running NokiaLCDv1.bs2
    PIN - DESCRIPTION
    K1 - ROW0 Keyboard matrix row 0
    K2 - ROW1 Keyboard matrix row 1
    K3 - ROW2 Keyboard matrix row 2
    K4 - ROW3 Keyboard matrix row 3
    K5 - ROW4 Keyboard matrix row 4
    K6 - COL0 Keyboard matrix column 0, used for flip identification (i dont use this)
    K7 - COL1 Keyboard matrix column 1
    K8 - COL2 Keyboard matrix column 2
    K9 - COL3 Keyboard matrix column 3
    k10 - COL4 Keyboard matrix column 4
    11 - Signal1 Flip interrupt, not used
    12 - VF_IN Flash in
    13 - VF_OUT Flash out
    14 - VBATT Battery voltage 3.0-5.1V --- Provides 5v for back LEDs, Connect to regulated 5v thru 22ohm protection resistor!
    This will allow 80ma max.
    60 75 100 mA For lights
    110min 300max mA For buzzer
    15 - UAGND Analog ground 0 V ---GND
    16 - PWRON Power on key --- PWR on button.
    17 - D/C Command/Data -- D/C Data / Command mode.(DON’T EXCEED 2.8v, use schematic)
    18 - SCLK LCD driver serial clock --- CLK, Clock line(DON’T EXCEED 2.8v, use schematic)
    19 - SDA LCD driver serial data --- Data line (DON’T EXCEED 2.8v, use schematic)
    20 - LCDCSX LCD CS driver chip select Low / Active connect to GND if not using.
    21 - LCDRSTX LCD driver reset --- RESET (DON’T EXCEED 2.8v, use schematic)
    22 - UDGND Digital ground 0 V -- GND
    23 - BUZZER Buzzer PWM control 0 - 2.85 V
    24 - VL Supply voltage 2.8V 300 uA -- Provide at least 2.5 volts REGULATED, DO NOT EXCEED 2.8volts
    25 - SPARE Not used in UI
    26 - LIGHT Illumination control --- Provide 5v here thru a 2kohm resistor for back LEDs
    ---IMPORTANT, DON’T USE SMALLER THAN A 1kohm brightness control.
    This gives your back LED 65ma of power. Adjust resistor to increase or
    decrease back led.
    27 - EARN Speaker neutral 0 1.78 Vpp
    28 - EARP Speaker positive 0 1.78 Vpp
    765 x 622 - 273K
    pins.gif 273.3K
    edited 2005-11-24 18:12
    cl said...
    A few tips for ya, use WIRE WRAP wire when your soldering to it. Its very thin and eaiser to keep it where you want it.
    Test the connectors next to the wire you just soldered to see if you accidentally bridged them. (I did this and could NOT see it) Didn't notice untill I started having funny keypad problems.
    If you can't get it the first 5 tries, keep trying. LOL. If you don't already have a desoldering pump, you might want to get one.
    If you don't have one of those, you can get the solder off the connector by heating it up, and then QUICKLY hitting the circuit board on its side on the table to kinda force the solder to jump off the connector. To be sure, you can take a razor and run the edge between each connector point to clear out any bridged solder. (if its not alot)
    Good Luck!
  • theyetheye Posts: 31
    edited 2006-01-01 02:47
    hey did you try it with another cell phone like ericsson, samsung or audiovox?
  • mediaprefectmediaprefect Posts: 31
    edited 2006-01-02 01:59
    re: BPM's suggestion:" If you don't have one of those, you can get the solder off the connector by heating it up, and then QUICKLY hitting the circuit board on its side on the table to kinda force the solder to jump off the connector."
    CAUTION His suggestion of using inertia to remove solder can be very dangerous to your eyes! I wear glasses and have many times over the years of desoldering used a similar method to remove solder from pins. I have also had to use my finger nail and alcohol to remove bits of flying solder and droplets of flux from my glasses. I may not like having to wear glasses, but I might have gone partially blind if not for my glasses due to flying molten solder(contact lenses don't count). Just think of how much that could hurt if it hit your cornea. Please remember to wear safety glasses whenever you solder especially if you do not wear glasses. It may seem like a nuisance but you only get one set of eyes.
    I'm not saying "don't do it" just be aware that the molten solder can bounce and travel a ways before it hardens and cools. It might not be you that is hit, it could be your little brother/sister (son/daughter) or best friend that is watching you. Watch out for others around you as well. BTW, the same warning goes for grinding etc.
    Learn from the mistakes and experiences of others, you don't have to make all the mistakes yourself, even if a mistake you make is ususally one of your best teachers.
    Enough of my boring warning.
    Happy New Year.
    edited 2006-01-05 22:48
    mediaprefect said...
    Happy New Year.
    GREAT POINT! Thanks for posting this.
    edited 2006-01-05 22:50
    theye said...
    I have not, due to me not owning any of those phones. If one could get the data sheet on the phones in question, along with details on how the display is used, and or the keypad is used, then one could do exactly the same as I have done here.
    With the right datasheets, you can re-hack almost anything. And remember by re-hacking, your recycling.
    edited 2006-01-05 22:57
    TO GIVE YOU ALL A HEADS UP. SX-operation soon.
    This circuit will soon be coded into assembly to be ported over to the SX line of microcontrollers. I just purchased the SX tech kit so it will take me a bit of time to learn the language and the cpu, but I WILL post the code and schematics to operate the keypad and lcd using the SX processor and assembly language.
  • BeanBean Posts: 8,129
    edited 2006-01-06 01:03
    Unless your heart is really set on using assembly, you could use SX/B and the conversion would be much simpler.
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    "SX-Video OSD module" Now available from Parallax for only·$49.95
    http://www.parallax.com/detail.asp?product_id=30015
    Product web site: www.sxvm.com
    "I hope the goonwave is not vaporware"
    edited 2006-01-06 02:15
    Bean (Hitt Consulting) said...
    Bean.
    Heh, I am new to both, and I will prolly do it in both, or in SX/B and then see if I can understand/optimize the assembly.
    edited 2006-01-17 17:45
    See below for the SXB version. This will operate the above lcd/keypad circuit on a SX28. The power button turns off the LED backlight and also sets the lcd logic into power down mode. When in power down mode, the only button that works is the power button to turn it back on to normal operation.
    Post Edited (BPM) : 1/18/2006 6:11:14 PM GMT
    edited 2006-01-17 19:44
    BPM,
    Nice... One thing you do realize that you don't need to use "GOSUB" when you have declared your subroutines.
    So where you have "GOSUB Display" you can just use "Display".
    I think it makes it a little more readable. Like "Display" is actually a command.
    Bean.
    "Ability may get you to the top, but it takes character to keep you there."
    edited 2006-01-18 14:57
    Hey guys,
    I think that the Electronic Goldmine is selling these [noparse][[/noparse]or something very similar] for $2.99 each.
    Post Edited (Kramer) : 1/18/2006 3:00:44 PM GMT
    edited 2006-01-18 18:10
    BPM,
    Bean.
    Heh, yeah, I only use GOSUB to help me realize that those are subroutines (and to help the pbasic dudes) I looked into the GOSUB command and it doesn't seem to take any more assembly space up. I took GOSUB out for the subs that pass variables to and fro (it requires that I remove it)
    Attached is the same code above, but optimized ALOT. I made use of subroutine variable passing.
    edited 2006-01-18 18:17
    Kramer said...
    Hey guys,
    I couldn't find any LCD's for 2.99.... The closest I found for that price, for a graphic LCD was some lcd with no pinout, or datasheet. I.E. totally useless.
    These displays that I am offering are taken from cell phones. The displays are all the same, but are from similar cell phones.
    edited 2006-01-18 18:47
    I think Kramer was talking about this item:
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G15611&variation=&aitem=65&mitem=103
    "OEM NMEA GPS Module" Now available on ebay for only $17.49
    Product web site: http://www.allsurplus.net/Axiom/
    edited 2006-01-18 19:51
    Yea, this is very similar, but the ones I have don't have the cell phone electronics attached. I think the only way it would be useful is if you take the lcd off the board, and use the lcd alone. I would bet that the electronics on the board would interfere with the BS2, or SX.
    As I see it, the only usefull part on that board is the LCD, not the keypad. And thats if the LCD is one that you can find out the pinout for it.
    Or if you can HACK the connectors, and analyize them. (i could do it, but I have alot of the lcd/keypad's already and have no interest to get more)
    Still the keypad is totally useless because you can't seperate it from the boards logic, nor does it come with the rubber like buttons that show the key label.
    The boards I am offering also come WITH the cell phone case, and keypad. So it looks like a cellphone, i have found this usefull if you dont care what your projects interface looks like, you just what the display, and keypad input for cheap.
    I use the cell phone/keypad as a hot plugged display / data input for robots, or various sx / bs2 circuits.
    And actually I haven't even sold 1. But I don't care. I work a job. This is just a hobby. I was thinking of taking all my little displays (over 60 of them) and doing something massive with them.
    MWAHAHAHA
  • paysonbadboypaysonbadboy Posts: 81
    edited 2006-01-20 04:28
    BPM said...
    MWAHAHAHA
    LOL what did you do, by a box full of them off of ebay or something?
    http://www.paysonarizona.net/
    edited 2006-01-20 06:09
    paysonbadboy said...
    BPM said...
    MWAHAHAHA
    Actually yes, I was going to make something out of the displays. And I still am, I just have more than I need, so I offered them here.
    Plus I wanted the ability to make projects with small displays and keypads to enter commands etc.... I have already integrated a keypad and display housed in the original cell phone. Works great, and its compact compared to most other keypads and lcd's. I wear the thing, so I needed it smaller, and portable. I also don't want to mess with custom cases, so having the cell phone case with it works great too.
    edited 2006-01-20 06:50
    BTW, the speed of this code on the BS2 is ok, but I was amazed at how much faster the SX/B running on the SX28 is. And I only have the SX28 clocked at 4mhz.
    I am glad I purchased the sx.
    edited 2006-01-20 09:19
    A am very VERY excited as using the keyboard and LCD as a RS-232 hack.
    The LCDs appear to be serial, which means minimal configuration. Even if the phone keyboard only provides a 12 button code, it all comes together as a nice interface for BasicStamps.
    Goldmine also has complete cell phones [noparse][[/noparse]with the external case and the battery holder] for $6.99. Maybe that would be worth the case and the battery holder.
    edited 2006-01-20 12:45
    BPM,
    If you used the SX to make a serial interface, then you would really have something.
    In my opinion it's too much code for the stamp to send the dot pattern for each character. If you could just send text and have commands to turn pixels on/off and maybe to draw a line that would be cool.
    Can you get more of the phone ? In my experience it's not worth selling a product unless you have 100 or more of them. But if you're doing it for the fun of it, then that doesn't really matter.
    Bean.
    edited 2006-01-20 13:26
    Kramer said...
    IF you do decide to buy, MAKE SURE you buy only one at first, you might not be able to use the parts like you think.
    If you can't find the datasheet for the LCD and or Keypad, 99% chance you won't get the lcd to work.
    BTW, I am selling my cellphone cases, with keypad, and lcd for 5$.
    edited 2006-01-20 14:04
    BPM,
    Bean.
    I prolly can get alot more of these. But I just don't think the demand is high enough to invest in. To make the cellphones usefull, adding a SX chip, with required support chips, and the board to solder it all too. The time to put it all together, and required equiptment.
    After all is said and done, the time it took to solder the chips onto the board, the price for the pcb's, and the sx + support chip....
    One would have to sell each cell-phone-hack for over 30$ to just break even. (keep in mind time - $$$)
    I think I'd rather just offer the phone as is for 5$. It keeps the price low, and keeps me from having to invest my own time into a possibly dead end venture.
    And I am only offering the phones because the pinout's, datasheets, and ALL required info to get it working, is fully available here and from me. (thats originally why I purchased over 60 of them)
  • ahanktcdahanktcd Posts: 8
    edited 2006-04-09 17:26
    This is great!! I just spend a mere 2 hours getting this up and running, I love it! I am going to work on numbers and symbols for it, unless you guys have that already? I'd like to make a little GPS or something. Anything useful needs numbers. Also, I saw the question about single pixels, is that possible? The 2005 SX design contest winner (2nd place) used this in his logic analyzer. I'm going to email him. http://www.parallax.com/sx/contest/contest_logic_analyzer.asp
    Thanks so much! I've had 4 in my desk for months wanting to interface them.
    edited 2006-07-14 22:43
    Actually if you look at my bs2 code, at the bottom, there are SUB's that contain the letters A thru Z.
    I even have the numbers 0 thru 9 if you want them.
  • Tcpip_v6Tcpip_v6 Posts: 15
    edited 2007-03-06 13:39
    I've attached a nokia 3310 display to a BS2· using BMp's schema and program. Now it seems that some lines on the display are missing (see attachment)
    Anyone an idea?
    410 x 308 - 14K
    edited 2007-03-09 04:10
    Tcpip_v6 said...
    I've attached a nokia 3310 display to a BS2 using BMp's schema and program. Now it seems that some lines on the display are missing (see attachment)
    Anyone an idea?
    Actually, after thinking of the way the code works, it looks like your display is damaged.
    Unless the BS2 is going too fast for the LCD.... But I highly doubt that.
    The only way you can test that is run this code..
    It inserts a pause after every 8 bits clocked out.
    I HIGHLY doubt that this is the problem.
    The reason I say its a bad display, is because that kind of visual error is common of damaged circuitry or lcd lines.
    I have seen alot of lcd's that are damaged and display stuff in even amounts.
    For you, it displays every other line. Without knowing how the inner circuitry is wired inside the lcd theres no way for sure to tell if this
    is a result of a bad display.
    My personal guess is your lcd was already damaged.
    Did you ever test it IN the cell phone? Or was the cell already dead?
