Video Basics
Beau Schwabe
Just going through some of my "Nuts and Volts" and found an article that some might be interested in that
could pertain to the Propeller for a custom video application.
January 2005
www.nutsvolts.com/toc_Pages/jan05toc.htm
Nuts and Volts: Anatomy of a video signal ; VIDEO BASICS by Keith Jack
Beau Schwabe
IC Layout Engineer
January 2005
Beau Schwabe
IC Layout Engineer
Just tossing my two bits worth into the bit bucket
KK
You can also check a local library... I would scan it in and post it myself, but I don't want to get into unauthorized reprinted
material issues. You can also do a Google search for.... "Keith Jack" Video ...Which I believe pulls up one of the books
already referenced about video in the "Propeller chip" forum.
http://www.video-demystified.com/
The article in Nuts and Volts is a very condensed version. Personally I wouldn't waste $$ on a back order magazine, but if
you know what specific issue you are looking for and know where to find it (i.e. the library) then it might be worth a look.
Beau Schwabe
IC Layout Engineer
KK
·1+1=10
Later!
kenjj
·1+1=10
Video DeMystified certainly looks like an excellent reference.· Seems to be a must get for anyone that really wants to use video as a hacker.· Seems to include all the formats.
Post Edited (Kramer) : 3/22/2006 9:33:42 AM GMT
I have read better explanations (easier to understand) in many electronic magazines and probably there would be good explanations on the internet too.
www.ntsc-tv.com
The information there is very thorough and easy to understand. The only thing I had to look elsewhere for was how to modulate the broadcast signal. This site should be all you need.
BTW, to generate the broadcast, you take the baseband and AM it so that the bottom of the sync pulse is maximum amplitude and the white level is minimum amplitude.
Chip Gracey
http://www.burnworld.com/dvd/primer/ntsc.htm
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"Sometimes it is better to remain silent and be thought a fool, than to speak and remove all doubt."
I happen to be one of the less than 1% that don't own a TV. I find I waste signifcant amounts of time when one is around and by going without, I read more and think more clearly. I hate to admit it, but I sometimes cannot talk coherently on the telephone while watching TV.
Of course if it really is the best solution, I may make the ultimate sacrafice as the cost of a TV is about the same as another monitor.
Hi, Chip!
Could you please confirm that the mentioned URL is still has a value?
The site looks weird and out of real condenced technical info, so I'd prefer to read Video Demystified...
Regards, Vladislav
