Got stepper motor working. Cant get normal motor working?
OK.· I have another question for anyone interested in helping.·· I just want to move a DC motor forward.· No reverse.· I will set pin 4 high.
Using a ULN2003.
Could someone look at my setup and tell me if it is ok?
THANKS TO ALL for helping me.· Project is coming along fairly well.
Using a ULN2003.
The ULN2003 will ground the motor connection. So the other motor connection needs to to +12 not ground.
Bean
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"If I was king for just one day...I don't think I could screw things up any worse [noparse];)[/noparse]"
THANKS in advance!· (this one really has me puzzled.)· I am a beginner, but have some knowledge!
Jon Williams
I swear I am not one of those guys that forsakes research by just asking on the forum.· I'm doing this to learn, and I am doing the research.· Just can't figure out what I am missing...
I believe my second diagram is as the article shows....
Thanks again.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Make sure some else checks me out on this before you make any permanent changes and test this, but I think you have Vss and ground reversed in your wiring. As I remember, the ULN2003's usually supply a switched ground, rather than switched power. Thus, positive power goes directly to the motor, and the ground lead comes from the switched side of the IC.
Bruce Bates
Chris Savage
