floppybot — Parallax Forums
floppybot
nofearsotnofearsot Posts: 25
edited 2005-06-28 05:41 in Robotics
The floppy bot is a robot which I build from a floppy disc chassis. I used a DEA Basic Stamp 2 system. In Cyprus there is a magazine which is give parallax parts. For this project I used 2 IR detectors, 2 IR led, 2 standard servos 2 light sensitive resistors and off course DEA Basic Stamp 2 system. I want to put a sonar, a grip and a TCS230 Color Sensor Evaluation Kit or a CMUcam Vision System for the Boe-Bot robot.
I programmed the robot if I press 1 on remote control,the robot follows objects. If I press 2, the robot avoids objects and if I press 3, the robot follows light. I have plans to program robot plays football. I want program robot to play football. The robot cost me about 70$
In about 2 months I will buy Crawler Kit
How can I upload videos
www.geocities.com/cdrombot
Post Edited (nofearsot) : 6/1/2005 4:57:47 PM GMT
  • PLJackPLJack Posts: 398
    edited 2005-06-02 04:08
    Now, there is a cool project.
    You say two servos. Does that mean you are not using the floppy stepper motor?
    Or are you just using the floppy chassis.
    Either way, great project.
    Jack
  • Tricky NekroTricky Nekro Posts: 218
    edited 2005-06-18 22:26
    Well I know the whole project because we are both registed in the same Greek forum about robotics...
    No he is using servos...
    Stepper motors are good but I don't know If the are drive able for a shift-register(Stepper Motors like the one in the CD-ROM drivers, although these motors have and possition sensoring)...
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
  • nofearsotnofearsot Posts: 25
    2048 x 1536 - 312K
    2048 x 1536 - 327K
