MIDIBEAT: exploring P1 vibe coding for: RGB LEDs, MIDI drums, rotary encoders, MAX7219 7-seg LEDs — Parallax Forums
TonySpinerTonySpiner Posts: 68
edited 2026-06-16 16:56 in Customer Projects
Hi, big shout-out to this forum!
I'm using various AI helpers to develop P1 code for my hobby project MIDIBEAT.
I'll post about it in this thread....
  • TonySpinerTonySpiner Posts: 68
    edited 2026-05-20 17:55
    MIDIBEAT1 is my Propeller 1 MIDI/drum/beat/step/sequencer/thingy project, I'm using it to learn P1 SPIN and to experement with Euclidean rhythm, as described by Godfried Toussaint.
    I'm using free AI agents to feedback on my code and help develop new P1 code for MIDIBEAT1. I have mixed feelings about AI at this moment but it seems to be working for me.
    The amazing user contributions in the Propeller1 OBEX make my tinkering possible, thank you all!
  • Attached is MIDIBEAT1's HMI input driver: 8_encoders_16_buttons_Claude_165.spin object.
    Could be revised further but seems to work fine. Mostly created by Claude, from JonnyMac's 74HC165 code and Mark Tillotson's encoder patterns.
    The input hardware is 8 rotary encoders and 16 push-buttons, spread across two PCBs each with 2x 74HC165 ICs, giving 32 raw digital inputs on 3 I/O pins.
  • Now working towards a HMI 16 digit 7-segment LED display +indicator LEDs
    Have you considered something like a Nextion touchscreen? Easy to use, and if you don't like a design you can change it -- unlike have to layout a whole new PCB. Working with the Nextion takes just one serial cog. I use them in work and personal projects. They're easy, they're fun, and they're reasonably priced.
  • I'm checking the Nextion site, very interesting products.
    Great tip Jon, thanks!
    I'm also playing with KiCAD PCB layout, MAX7219 is nice beginner project.
    edited 2026-03-23 18:50
    I'm a fan of the MAX7219 -- been using them since my BASIC Stamp days 25 years ago.
    If you decide to give the Nextion a try, I have P1 and P2 objects that make connecting to them easy with custom strings the Nextion (much easier than using their internal codes) and using text allows you to test your Nextion project with a simpler terminal.
  • @JonnyMac
    I just received a Nextion display for another non-P2 project. Are your P2 objects available somewhere? I checked OBEX but did not find them?
    Trapperbob
    edited 2026-03-23 23:19
    Let's not hijack Tony's thread -- make a new post in the P2 section and I'll provide code for you, @TrapperBob.
  • @TonySpiner
    Looked up the Euclidean Rhythm very interesting.
    edited 2026-03-24 18:03
    @pilot0315 said:
    @TonySpiner
    Cheers Pilot, MIDIBEAT1 is connected to a drum machine and making some interesting rhythms :) In the future I hope to post all the code and a video.
  • @TonySpiner
    Kool.
    edited 2026-04-06 15:02
    Thank you Pilot, I'm making some (slow) progress on MIDIBEAT1's MAX7219 PCB layout.
    Considering using dp segments as LED indicators.
    edited 2026-04-24 14:40
    edited 2026-04-24 14:27
    7-segment display PCB is working (for digit segments, dp LEDs still to be tested)
  • using the dp segments as indicator LEDs is working for transport, 2 more to be tested for use as encoder primary/alternate indicators.
    edited 2026-05-19 15:31
    The 2 "mode" indicator LEDs are working too :). Useful as I've decided not to use each rotary encoder's integrated push-buttons. I found that the primary values occasionally get accidentally nudged.
    Instead, I’m using only 2 (latching) buttons - one button selects the mode of the 4 KIT encoders, and the other button selects the mode of the 4 PERC encoders, (primary-mode is pattern, alternate-mode is MIDI).
    edited 2026-06-16 16:59
    Now testing MIDIBEAT with 2 MIDI ports!
    2 Propeller pins drive the active-low enable lines of the buffer IC to route the shared MIDI output to either Port 1, Port 2, or to both at the same time.
    Tested the outputs with 2 drum machines and the output routing seems to work. The port switching happens in the main loop - when a "PERC" (i.e. channel 2) drum hit is required. I added a delay before switching to allow any current MIDI message to complete before it's buffer output goes high-Z.
    edited 2026-06-16 18:36
    I've been playing with MIDIBEAT. Added 3 additional (off-board) buttons for transport functions and a made a small improvement in the LED ring behaviour.
    Now looking at Propeller Signal Generator object by Johannes Ahlebrand with a view to use it as the basis of an electronic drum audio generator.
    Some more testing with external MIDI gear, (using a +5V logic buffer IC for MIDI seems to be a good idea), the output routing using /EN signals works - so far.
  • ... also added USBC power in and a RaspberryPi psu, good value, seems solid.
