Cannot get program running after upload - Page 3 — Parallax Forums
13»
  • @macca Why not make the "normal" state of the control line(s) an option and forget about it?.
  • maccamacca Posts: 1,073
    Yes, not that easy... the serial interface was already changed a couple of times and every time is a pain because a fix on a place breaks something elsewhere, I need to investigate more on the issue.
    In the meantime, keep the terminal open.
    Also, if you can try with a prop-plug, you are not the first to use Spin Tools with a Mac and AFAIK others don't have this problem but I guess are using a prop-plug.
    Don't have one, and I am not feeling like paying 40 dollars for it
