REV A P2 Edge booting from flash possible? — Parallax Forums
Hi,
First time I've tried it on this board but am having problems booting an old REV-A P2-Edge board from flash. I can see the flash from my app when loaded and running from a RAM download and I can also write to it with loadp2 but it refuses to boot from flash for some reason.
I've got the pull up and down icon dip switches both set off, and flash enabled (serial + flash boot). Won't boot my app from flash. Also tried with the up dip switch disabled and down enabled (flash only boot), with the same result.
I measured P59 resistance to ground (out of circuit) being 10k when the down dip switch is enabled and 14Meg when disabled so I think the DIP switch is working. Measured P61 (flash CS) to be 300k to ground and 10k to the V56 IO pad.
I'm now wondering if there was some known issue in the early boards? Or perhaps there is a problem with my app - but it seems fine when loaded to RAM. I'll pare it down to just toggling a LED and try that too but I suspect it'll be the same. My current binary app image size is about 330kB so I know it fits.
I'm using loadp2 rev 0.77 to flash the P2-Edge with these settings.
loadp2 -t -flash xxx.binary
I know loadp can write to the flash as I also share the upper flash with data and I can see that data in flash if the app is run from RAM.
My RAM load works when I flashed the upper filesystem data at 1MB offset, but the boot from flash seems to fail. Also tried this out...
loadp2 -t -HIMEM=flash @0=z80.binary,@80000000=z80.binary,@80100000=/Users/roger/z80fs.bin
For testing I wrote a simple flash sector dump app which I loaded to RAM and can see my app in FLASH sitting at sector 2 onwards - sector 0 and 1 seem to have a small initial 1kB bootloader written to it which reads in the remaining app code starting from the 1kB offset in flash:
Sector 0
08 00 90 FD FC C2 47 EA 9C 43 05 00 3C 94 0C FC    ......G..C..<...
50 78 64 FD 3C 02 1C FC 58 78 64 FD 1D 32 60 FD    Pxd.<...Xxd..2`.
00 00 8C FC 0A 00 CC F9 02 00 20 F3 00 04 80 F1    ................
05 00 64 F0 00 34 20 F9 01 00 64 F0 3C 00 24 FC    ..d..4....d.<.$.
1F 06 64 FD 00 34 A4 FC 24 36 60 FD F5 05 9C FB    ..d..4..$6`.....
50 F4 65 FD 3C 00 0C FC 42 0F 80 FF 1F 00 65 FD    P.e.<...B.....e.
00 00 EC FC 00 00 00 40 00 00 F5 C0 00 00 00 00    .......@........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
Sector 2
00 00 00 00 01 EC 63 FD 02 00 00 FF 04 EC E7 FC    ......c.........
What am I missing? It has been a while since I tried flashing something on a P2 so perhaps I have forgotten something simple and I'm just doing something dumb, or maybe REV A flash booting is problematic...?
Could it be some initial clock setting that is normally patched by loadp2 or something like that? My flexspin based app does have _clkfreq set to 270000000, but no explicit CLKMODE setup otherwise. Although I didn't think it really patched the settings unless -PATCH option was applied anyway.
  • roglohrogloh Posts: 6,399
    edited 2026-06-01 08:59
    Ok, so it turns out that this LED test did boot from flash when I flashed it using this command:
    loadp2 -FLASH ledflash.binary
    so perhaps my 330kB is too big for reliable serial downloading, or perhaps there is a bad sector somewhere in the flash...hope not. I guess I'll try to add a CRC check or read back all the sectors and manually compare the source binary.
    CON
        _clkfreq = 100000000
    PUB main()
        repeat
            waitms(1000)
            pintoggle(56)
    I should also mention: I tried the app boot test after first removing the PropPlug (in case that was holding down reset) and then re-powering the P2-Edge, but always get the same problem with my main app not starting up.
  • evanhevanh Posts: 17,278
    edited 2026-06-01 10:24
    I've never used the multipart bundling let alone also burning it to flash. EDIT: Oh, oops, that was an alternate.
    edited 2026-06-01 11:37
    Ah-ha! The -FLASH option has to be all caps! I guess all of Loadp2's options are case sensitive then.
    Verbose without -FLASH option:
    P2 version G found on serial port /dev/serial/by-id/usb-Parallax_Inc_Propeller_P2-ES_EVAL_P23YOO42-if00-port0
    Setting load mode to CHIP
    Setting clock_mode to 12427f8
    Loading fast loader...
    Loading speedtest-flex.binary - 73524 bytes
    address=0x00000000 size=11f34
    device response to header: `s'
    chksum: eb OK
    ( Entering terminal mode.  Press Ctrl-] or Ctrl-Z to exit. )
    Verbose with -FLASH option:
    address=0x000fc000 size=2ac
    chksum: 3a OK
    chksum: eb OK
    highest hub address: 0x11f34 chksum: 0xea4be764
    address=0x80000000 size=400
    device response to header: `k'
    Sending blocks: .chksum: 8f OK
    sending F 0x00011f34 to device
    I get this output with verbose enabled:
    ❯ loadp2 -t -v -FLASH   z80.binary
    trying /dev/cu.usbserial-P9cwqjdx...
    P2 version G found on serial port /dev/cu.usbserial-P9cwqjdx
    chksum: 3a OK
    Loading z80.binary - 345448 bytes
    address=0x00000000 size=54568
    chksum: 97 OK
    highest hub address: 0x54568 chksum: 0xea47c130
    sending F 0x00054568 to device
    edited 2026-06-01 12:14
    Just ran this simple total byte sum test on the binary stored in flash. Doesn't look like there is a problem with the flash contents itself unless the initial loader is getting rejected by the P2 boot process.
    CON
    OBJ
        f:"ers_fmt"
        uart:"SmartSerial"
        flash:"SpiFlash"
    PUB main()
        uart.start(115200)
        send:=@uart.tx
        send("checksum=",f.dec(checksum()),13,10)
        repeat
    PUB checksum() :sum | i
        sum:=0
        repeat i from 1024 to $54567+1024
            if (i//512 == 0)
                flash.read(@buffer, i,512)
            sum+=buffer[(i & $1ff)]
    DAT
        buffer byte 0[512]
    Result was this:
    ❯ loadp2 -t reader.binary
    checksum=40231575
    Did the same computation over binary file with this same result
    od -v -An -tu1 z80.binary | awk '{for(i=1;i<=NF;i++) sum+=$i} END {print sum}'
    40231575
    Doesn't the first 1kB loaded need to sum to the 32 bit value of "Prop" or something like that for the P2 to boot from flash? I guess I can check that too...
    edited 2026-06-01 13:42
    Something very weird about loadp2 and the -FLASH option. I see some of this code sitting in the first sector but it doesn't seem to contain the "app_longs" value which is meant to be set by the programmer. Why is this value missing? What am I doing wrong on the command line ? @ersmith do you know? None of the longs after the "wmode" value seem to be present there. Isn't loadp2 meant to fill this in for us? EDIT: Ok I found this sector code is actually from flash_stub.spin2 and not flash_loader.spin2.
    Flash dump:
    Sector 0
    08 00 90 FD 30 C1 47 EA 68 45 05 00 3C 94 0C FC    ....0.G.hE..<...
    Here's the loader code from what I can tell...EDIT: no this is the loader code from the programmer (see post below).
    ' On entry, both spi_cs and spi_ck are low outputs and the flash is outputting bit 7 of the
    ' byte at address $400 on spi_do. By cycling spi_ck, any additional application data can be
    ' received from spi_do.
    ' Once all application data is in the hub, an application checksum is verified, after which
    ' cog 0 is restarted by a 'COGINIT #0,#$00000' to execute the application. If that checksum
    ' fails, due to some data corruption, the SPI pins will be floated and the clock stopped
    ' until the next reset. As well, a checksum is verified upon initial download of all data,
    ' before programming the flash. This all ensures that no errant application code will boot.
            org
    ' First, move application data in cog app_start..$0FF into hub $00000+
    loader      setq    #$100-app_start-1   'move code from cog app_start..$0FF to hub $00000+
            wrlong  app_start,#0
            sub app_longs,#$100-app_start  wcz  'if app longs met or exceeded, run application
        if_be   coginit #0,#$00000          '(small applications verified by 'Prop' checksum)
    ' Read in remaining application longs
            wrpin   #%01_00101_0,#spi_ck    'set spi_ck smart pin for transitions, drives low
            fltl    #spi_ck         'reset smart pin
            wxpin   #1,#spi_ck      'set transition timebase to clk/1
            drvl    #spi_ck         'enable smart pin
            setxfrq clk2            'set streamer rate to clk/2
            wrfast  #0,##$400-app_start*4   'ready to write to hub at application continuation
    .block      bmask   x,#10           'try max streamer block size for longs ($7FF)
            fle x,app_longs     'limit to number of longs left
            sub app_longs,x     'update number of longs left
            shl x,#5            'get number of bits
            setword wmode,x,#0      'insert into streamer command
            shl x,#1            'double for number of spi_ck transitions
            wypin   x,#spi_ck       '2  start spi_ck transitions
            waitx   #3          '2+3    align spi_ck transitions with spi_do sampling
            xinit   wmode,#0        '2  start inputting spi_do bits to hub, bytes-msb-first
            waitxfi             '?  wait for streamer to finish
            tjnz    app_longs,#.block   'if more longs left, read another block
            wrpin   #0,#spi_ck      'clear spi_ck smart pin mode
    ' Verify application checksum
            rdfast  #0,#0           'sum all application longs
            rep #2,app_longs2
            rflong  x
            add app_sum,x   wz  'z=1 if verified
    stop    if_nz   fltl    #spi_di addpins 2   'if checksum failed, float spi_cs/spi_ck/spi_di pins
        if_nz   hubset  #%0010          '..and stop clock until next reset
            coginit #0,#$00000      'checksum verified, run application
    ' Data
    clk2        long    $4000_0000      'clk/2 nco value for streamer
    wmode       long    $C081_0000 + spi_do<<17 'streamer mode, 1-pin input, bytes-msb-first, bytes to hub
    zeroa                       '(used by programmer as long 0)
    app_longs   long    0           'number of longs in application     (set by programmer)
    zerob                       '(used by programmer as long 0)
    app_longs2  long    0           'number of longs in application     (set by programmer)
    zeroc                       '(used by programmer as long 0)
    app_sum     long    0           '-sum of application longs      (set by programmer)
    x                       '(used by loader as variable)
    loader_sum  byte    -"P",!"r",!"o",!"p" '"Prop" - sum of $100 loader longs  (set by programmer)
    ' Application start
    app_start                   'append application bytes after this label
    edited 2026-06-01 13:37
    @evanh is your loadp2 flash_stub.h file in the loadp2 root folder area the same as this? I wonder if mine is somehow corrupted? This file is generated when I build loadp2 source.
    unsigned char flash_stub_bin[] = {
    0x08, 0x00, 0x90, 0xfd, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x3c, 0x94, 0x0c, 0xfc, 0x50, 0x78, 0x64, 0xfd, 0x3c, 0x02, 0x1c, 0xfc,
    0x58, 0x78, 0x64, 0xfd, 0x1d, 0x32, 0x60, 0xfd, 0x00, 0x00, 0x8c, 0xfc,
    0x0a, 0x00, 0xcc, 0xf9, 0x02, 0x00, 0x20, 0xf3, 0x00, 0x04, 0x80, 0xf1,
    0x05, 0x00, 0x64, 0xf0, 0x00, 0x34, 0x20, 0xf9, 0x01, 0x00, 0x64, 0xf0,
    0x3c, 0x00, 0x24, 0xfc, 0x1f, 0x06, 0x64, 0xfd, 0x00, 0x34, 0xa4, 0xfc,
    0x24, 0x36, 0x60, 0xfd, 0xf5, 0x05, 0x9c, 0xfb, 0x50, 0xf4, 0x65, 0xfd,
    0x3c, 0x00, 0x0c, 0xfc, 0x42, 0x0f, 0x80, 0xff, 0x1f, 0x00, 0x65, 0xfd,
    0x00, 0x00, 0xec, 0xfc, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0xf5, 0xc0
    unsigned int flash_stub_bin_len = 108;
    Update:
    Okay now I'm more confused than before. There seems to be two different flash loaders. One seems to be bundled with some programming code (flash_loader.spin2), and the other is standalone (flash_stub.spin2). The latter is what is in my flash by the looks of it.
    Update2: I checked the total 32 bit sum of the first 1kB in flash. Results in checksum=706F7250 which is "Prop" so it look like the P2 should boot this. Starting to wonder if maybe my own app is somehow locking up if flash is already enabled after boot or something like that since it also uses flash. I'm going to try modifying it to not read flash and just blink a LED instead like that other short test app I wrote.
    Update3: Nope, disabling flash in my app doesn't help. Still no boot. I'm at a loss now. Power draw from flash boot perhaps...?
    edited 2026-06-01 14:14
    After it is built I manually copy the resulting binary "loadp2" into a stand-alone directory in my exec path. Nothing else is copied from the build and the build directory is ignored after. I only look at again when updating with git pull. Last build was August 2025, v0.077.
    Content of flash_stub.h
  • ersmithersmith Posts: 6,285
    I think you've already figured this out, but for reference in case someone stumbles across this thread: the boot ROM will only boot the first $400 bytes of the flash, so in most cases that needs to contain a second stage boot loader. In loadp2 we have two variants of this second stage bootloader:
    flash_loader.spin2 is used to write the data if -FLASH and -SINGLE are both given, and it contains its own second stage boot stub confusingly also called Loader (it's near the end of flash_loader.spin2). IIRC it's the old flash loader and was kept as a backup. For regular -FLASH we prepend the stub in flash_stub.spin2 to the binary and write it to flash using himem_flash.spin2, which is the new mechanism for writing stuff and is intended to be compatible with things like the hyperflash (although as yet there is no himem_hyper.spin2). The himem mechanism is also used for loading ELF files to flash (or potentially to other kinds of external memory) for execute in place. At the moment AFAIK only the riscvp2 toolchain supports producing such ELF files.
    Thanks Eric. Good to know about -SINGLE selection.
