Putting your version on GitHub sounds like great idea.
Guess that would be a fork.
But @n_ermosh did post a few months ago …. Maybe he would take pull request. If can figure that out…
Yeah was waiting to see if he's lurking about. Might have to figure out GitHub again - been ages since I pushed stuff there.
BTW am now adding AUGD and AUGS constant value printing (where consumed) so we can see the full 32 bit values after augmenting. We can't show the full AUG values in the AUGD/AUGS statements themselves because the instruction that consumes it follows later and has not been processed yet. I also still want to show the original unaugmented value so this code can be re-assembled if you generate it without the addresses and that's why the final augmented value is shown only after the comment starts. Hopefully we can ultimately lookup any matching symbol names at these address values too. That can help to figure out some data variable accesses when memory is read or written there.
Update: there is just one more missing item that the decoding of AUGS/AUGD stuff will also assist. The special augmented and unaugmented hub memory accesses using PTRx pointer index operations like: mov r0, ptra[##$2A332] and mov r0, ptra[123]
Right now these are not yet handled at all, either with augmented constants or without. I should add these which I think will complete the P2LLVM parser to accept all standard P2 instructions and aliases, although compile time expressions for calculating constants may still be limited - I've not looked into that.
The special SPIN2 language control directives like ORGH, FIT, RES etc won't be implemented though, as this assembler already uses its own (primarily GNU GAS compatible) directives.
@rogloh,
To put your changes up and make a pull request would mean you have to fork a copy, do a pull request against that copy, do the submodule updates, copy the changes in, do a push. That would make a version that we could pull down and test.
@iseries said:
@rogloh,
Thanks @iseries for the refresher. I'll probably do exactly that in the end. I just want to complete the last part to parse which is the pointer indexing stuff. Then I should try the pull request. One good thing is that nothing seems to have changed since I dragged my tree down in the first place so no additional merging needs to be done at this stage.
@rogloh glad thinking about putting on GitHub later…
Would be nice to have build instructions for Linux if possible. Guess my problem might be that Linux people are so used building stuff they don’t need much help whereas I’m mostly lost…
Also, don’t know if it can work here but some GitHub stuff appears to be automagically compiled be them if set up (?)
@Rayman said:
@rogloh Suppose if spin2cpp still works, then can add spin2 drivers to c/c++ code right?
Potentially, although you'd need to worry about memory layout and startup code etc. Not sure they'll be fully compatible at that level without changes in how you structure and launch the bundled application code. But it's a compelling solution if we could use both toolchains together, particularly for something like MicroPython which could make use of other SPIN2 based objects converted into C code.
Got a bit further on this and tested all the opcodes for the new P2 instructions I'd recently added to P2LLVM by comparing all the different possible {#}D/{#}S forms with the binary output that flexspin generates. This is the list:
Found a typo and fixed the SETDACS opcode before it became buried and would cause problems later. But one error wasn't too bad given this was a manual process typing it all in.
I did find a couple of things with the P2LLVM output that worked differently when I assembled the same file using flexspin and compared the outputs.
1) Relative branch distances are taken directly from the immediate value entered for P2LLVM, while flexspin wants a symbol or target address in order to compute its relative branch amount. If you enter an immediate it will just use that as the branch address amount in P2LLVM and it won't encode the same as flexspin which will take the number provided and figure out the distance from the current address to that address target and encode that value (unless the \ prefix is added, in which case it will use the address directly). It might be good to bring P2LLVM parser in line with how flexspin behaves by default at least when labels are not used as branch targets, or perhaps flexspin is doing it wrong.
2) Some aliases are being incorrectly matched when immediates are being used. For example: NOT D,#2 can incorrectly be matched as NOT D wc (alias form) because the #2 immediate S-operand in the NOT D, #S form is the same value as the encoded WC flag. It looks like effects flag operands need to have their own type and not get encoded as immediates in order for the aliases to work in all situations. For now until that is resolved (which needs additional effort) I'll just disable the affected aliases. I think it's this list of aliases NOT ABS NEG NEGC NEGNC NEGZ NEGNZ TEST ENCOD ONES
One other thing that I found is that the percentage symbol does indeed let you enter binary constants as it should after I'd enabled Motorola mode in the lexing. The $ prefix was working for hex but % was not working for binary when I tested it earlier. Turns out this was just because inline assembly also uses % as an escape character. To get the real % you need to use %%, although this is only needed for the inline assembler. The regular assembler that works with separate .s files only need a single % for binary number encoding (or can also use the 0b prefix, similar to 0x for hex). You can see both these prefixes now working in the captured log below. Unfortunately I don't think we can readily make the %% prefix represent two-bit quaternary numbers (base 4) as this is buried deep in the common lexing code used by all microprocessor targets which I certainly don't want to mess with. But as it's rarely used and we can easily convert those values into binary instead it shouldn't be a major deal to not have that feature implemented in P2LLVM.
It most likely is useful but last time I wanted to use it I think I had issues with requiring some extra python software module that apparently collide with my Mac's own versions when I tried to install them. So I stopped there.
It's pretty amazing what can be done with this LLVM toolchain if you mess about with it enough. By fighting/arguing/persevering with a google AI for several hours I was finally able to get the disassembly listing to produce the labels needed for branch targets. OMG that was a whole process in itself, but it finally appears to be working.
In the listing it is now making labels for each branch target in HUBRAM and referenced address in the code and automatically printing them after the tjz and jmp instructions. I've still got my own comment string being printed alongside that shows the target address and was used to help validate things but that is sort of redundant now. Relative branch addressing seems correct too.
I was also hoping to enable this --visualize-branches ASCII art feature that would look something like this, but it apparently came in on a later version of the toolchain and is not supported by P2LLVM. P2LLVM is based off LLVM 14.
ps: Still don't like the pattern above with a TJZ falling through after the test by skipping over the following JMP. If the target is close enough it should be able to just do the reverse test condition and only branch with a single instruction and continue through otherwise avoiding a branch penalty in one of the cases. That's another optimization that needs to be added in time. There's plenty of others too including a conditional branch without the prior compare operation to set flags, by instead setting Z directly off the memory reads, ALU operations. It also avoids TJZ since you can do if_z JMP xxx and purely use absolute addressing (for this external memory scheme I have in mind).
Was able to fix the alias mismatching problem mentioned earlier by creating a new type for the WC/WZ/WCZ effects flags instead of treating it like an immediate. I think that is sorted now. Once I've tested all the new instructions I'll do the GitHub thing.
I also keep thinking about other possible P2 specific optimizations as I know there is scope for a lot of improvements. By asking an AI about it, there could be potential for hub scheduling improvements with LLVM which would be good. Here's a snippet of a conversation I had with this AI regarding hubexec memory access and pipelines, offering suggestions to me.
Point 3 is plain wrong. A data access can't interrupt the FIFO because the FIFO always has priority to hubRAM. Second, the FIFO stays well ahead of the cog's needs so any data accesses will never stall execution due to FIFO empty.
The FIFO can interrupt a data access though. FIFO reads of hubRAM are done in bursts of 6 longwords at a time - after initial filling that is. It would be difficult to predict I suspect.
As for state tracking of the data addresses, the biggest win is not in the absolute address but in the address delta of two accesses vs execution time.
Ok, I see the point you are making @evanh . The 9-26 cycle time for a memory read during hub exec is not really the RDxxxx doing its read causing a FIFO stall which needs reloading after the RDxxxx operation completes, but it's the intermittent FIFO accesses delaying the RDxxxx for a burst of 6 longs, at which point the read finally gets its go, but also has to wait for the hub rotation to align to its address after that (and maybe another FIFO read burst...?). 26 cycles worst case is up to 10 more than normal in COGEXEC mode, perhaps that accounts for more frequent FIFO access (immediately after a branch stall for example).
I can see it's far more complex to model that. I would hope there is some scope for improvements though if it can work out the amount of time between two accesses to allocate to non HUB instructions in between (at least when it knows the addresses). It could know the address delta to be zero if it does a read, a modify and write back to the same variable in memory which is a common thing to do in C, either on a global data item or a local in the current stack frame.
One other thing I was asking it about was using SKIP to effectively "jump" over sequential blocks of code vs the branch penalty in hub exec. That one seems quite doable, as a last step optimization once all instructions are fixed in place. Branches take 13-20 clocks in hub exec so we can get up to 5 instructions jumped via a SKIP instead of a conditional short JMP and still gain clocks in all cases. Only applies to forward jumps of course.
I did that, hand crafted of course, to gain myself a third execution condition in sdsd.cc's block read routine. It contains limited branches - A subroutine for CRC processing and the data block count loop were it. C flag used to remember if start-bit found. Z flag used to remember if CRC passed. And skipping used for first and last data block handling because CRC processing is buffered/lagged into the following block.
I suppose that's actually four conditions. The main idea was to optimise worse case execution times the most. The only niggle I had was it meant adding two SKIPF instructions and two skip patterns.
@rogloh said:
... It could know the address delta to be zero if it does a read, a modify and write back to the same variable in memory which is a common thing to do in C, either on a global data item or a local in the current stack frame.
The +10 will be 8 for the extra rotation plus one if a word misalign ... plus one for something else.
Yeah, hubexec is always going to be a little erratic. But still predictable enough to make general optimising gains.
Maybe something that can be achieved here is to simply assume that the FIFO has filled already or won't otherwise interrupt the current RD (because the best case for HUBEXEC timing is still the same as for COGEXEC which means no FIFO access collided), and when we are writing back to the same address we just read from, then use a specific number of instructions between the RD and the next WR to that address. Or a similar approach if it RD's another item at some known address offset from a previous read. I know it won't always apply but if it applied often enough it may still give us some gains where other instructions can be executed in the wasted waiting time.
Great minds think alike! Although this was an easy one. It would also be easy to check too if simple relative jumps are being used. Just hunt for very fixed JMP #1, JMP #2 .. JMP #5 encodings (relative offsets shown), preserve the condition code and replace with an associated SKIP #mask in a last pass optimization when all instruction's addresses are locked in. Nothing gets shifted in memory, and any conditional branching would be preserved. Any given branch path should be able to work independently with their own associated SKIPs as the path taken through the code won't have to overlap/recurse the SKIPs in any way no matter what path is taken, they'll simply always be sequentially executed. It would work for JMPREL too in immediate form, while the register form is something I'm looking into for switch statement decoding...
In looking at the P2 code generated by the P2LLVM backend for MicroPython I am occasionally seeing some cases like this where JMP #4 is issued and would be a candidate for the conversion to SKIP mentioned above, however it appears that the code is not doing the best thing here which is to place a single conditional JMP instruction and fall through to the LBB9_10 label otherwise.
Because the conditional jump is shared with the unconditional jump instruction (only the IF_Z condition is different) the "isBarrier" value being set to 1 for both cases means the compiler will not let the execution fall through, and it will enforce the two jumps. We really need two "instructions" defined for JMP, one with isBarrier set to 1 and the other with it set to 0. It's a bit of work to change, but it probably should be done at some point to eliminate this inefficient double jump combo, although a SKIP replacing this JMP #4 would really help alleviate it also in the interim. Ideally it gets fixed the proper way, and I'm hoping it resolves the label generation for fall through cases so the extra blank lines and labels printed per function don't get issued - having all the extra blank lines in a function only seems to confuse things when reading through the code.
That's exactly what I want it to do. I'll try the change to create a conditional JMP branch instruction. My only concern is that it will have the same bit pattern as the regular jump (because conditions are specified separately) and there'll be a collision in the opcode generated when it tries to build the list of instruction encodings and sees two the same...and giggle AI says the same when I queried it, although it now has some suggested workarounds.
After digging about with P2LLVM, in the longer term what I'd really like to see working would be:
far more use of RDLONG reg, ptra[nn] for accessing stack frame arguments and other locals from the stack. There is some of this present in the code generated but not all accesses use it and some code still creates pointers manually by offsetting from the SP (PTRA) like this code below. In this case I would have liked to see it coded simply as RDLONG r2, ptra[-$64] . Even if we need to add an AUG because it is out of indexing range in a single instruction we'd still be ahead on clocks and instruction space, plus it makes the disassembled code far easier to understand when you see it directly indexing off the SP not some random register.
enabling (only) leaf functions to be called using CALLD LR, #\function and return with JMP LR instead of CALLA and RETA, saving hub memory accesses in hubexec mode. This instruction requires the "LR" to be PA,PB,PTRA,PTRB. Possibly PB could be useful for this, or even PTRB if not used for a base/frame pointer. It wouldn't need to be saved if this is a leaf function but it would prevent other uses such as for Fcache or use with external memory handlers with CALLPB (unless that saves it out first).
enabling a BP (base pointer) for functions that use alloca() to allocate dynamic memory on the stack. Apparently (according to AI) LLVM can do this and we only incur the larger stack frame and extra prologue/epilogue setup overhead for the functions that actually use alloca(), which would be perfect. The remaining typical functions can still just use the SP as PTRA and simpler stack frame for accessing locals/args/spilled regs from the stack. PTRB is ideal as the base pointer for this as it can also index locals and arguments from a fixed location, while PTRA as the SP can then be adjusted dynamically without affecting any of the stack indexing in the code.
getting rid of the double JMP on compare cases when one branch just skips over the other. It should simply just branch out in one case and fall through for the other. Also for any small code snippets being branched over it could also use the predicate if_z or if_nz etc to skip the small number of instructions not matching the actual condition (when the instruction count is < 6) or alternatively replacing it with a SKIP instruction could have the same effect and it avoids needing to recompute all the if conditions through the small snippet and also preventing any further flag use in that group, at the expense of the actual SKIP instruction itself. SKIP is certainly simpler to implement IMO as you don't need to worry about messing up flag state.
more use of patterns that take advantage of other P2 capabilities such as those using:
CMPSUB/INCMOD/DECMOD/ALTGx/ALTSx/ALTR/MUXZ/TESTN/MUL/MULS/SCA/SCAS/SUMC/NEGC
e.g. MUL could be useful for doing 32x8 or 32x16 multiplies instead of via the CORDIC, where faster. In C you often multiply by small constants and CORDIC use at all times seems like overkill for that.
we could use INCMOD for if (a) a--; else a=b;
and SCA for multiply-accumulate a+=(b * c)>>16;
CMPSUB for if (b<a) a-=b;
MUXZ for if (c) a=a|b; else a=a&~b;
etc
make use of the WZ flag available on most ALU operations if it's going to be followed by a CMP instruction rather than comparing with zero again.
a good example of this is the fairly common pattern if (a%b == 0) { ... } The CORDIC can already write the Z flag on the GETQY for the remainder being zero. We should try to use that where it helps.
The TJNZ and TJZ instructions do theoretically assist here for comparisons with zero and branching out in the same instruction but these instructions may need to be restricted if we wanted to support external memory caching given they are relative branches limited in range that may branch out of a cached row; absolute far jumps that can be intercepted would be needed instead. Obviously some special flag would be setup to control that feature so keeping TJNZ and TJZ available otherwise remains useful.
I made quite a bit of progress in the last couple of days of testing out the GETxxx/SETxxx/ROLxxx patterns and in adding capabilities for single bit testing with TESTB and logical testing with TEST (instead of needing to use the destructive AND), and I also introduced a lot more patterns using P2 native instructions to help eliminate other instructions to achieve the same thing by utilizing MUXZ/MUXNZ/MUXC/MUXNC/BITL/BITH/BITNOT/DECOD/ANDN/MOVBYTS/SUMC/SUMNC/SUMZ/SUMNZ/BMASK.
I tried adding a schedule file which LLVM can use to help order it's instructions, but once I did that it enabled deeper verification of machine instructions and all hell broke loose and it exposed some otherwise buried issues with the backend relating to conditional branching. I'm going to need to work my way through these to figure out what's going on. The good news is that if/when we can resolve these things then P2LLVM should be able to generate far better optimized code moving forward as it will have an idea of how many cycles each operation and branch takes.
@Rayman said:
Sounds good! Wonder how this will compare to the older P2 GCC? Maybe the fibo benchmark would say? Or, some other benchmark?
Guess it'd be interesting to compare with RISCV P2 and flexprop C as well...
Sort of hoping that ultimately I might see a few improvements on MicroPython in terms of memory use and performance. Just depends on how often and how many of the new instructions it can take advantage of, how much branching can be reduced, and if we can obtain a reduction in local variable use on the stack. An increase of GPRs from 32 to say 48 or 64 may potentially help out with that, although it will also take more clocks to preserve/restore more registers in stack frames once extra registers are in use, plus the increase of the stack itself.
One thing I noticed is that if it has to break up register blocks which are not contiguous while it saves/restores them then it generates multiple setq block transfers bursts. I'd expect that is a significant time waster waiting for further hub opportunities so it should just save off any intermediate registers even if it doesn't need to as it's just a couple more clocks in the original setq burst to do. In theory the register allocator is meant to keep all used registers together in a group anyways and this seemed inconsistent with that. I think it might be just the register arguments causing this effect and there were only 4 registers allocated for that in P2 LLVM initially so it should just save them all IMO rather than do an additional setq burst for both saving and restoring in the prologue and epilogue of the function.
Also if we increase registers allocated to arguments from 4 to 8 it would help speed up the functions with more than 4 arguments as they won't have to write and read them from the stack. Ideally if we had 8 registers for arguments we'd probably want to allocate from registers r7 downwards to r0 for arguments and r8 upwards for locals, then we could group all the registers to be preserved in a single burst before calling the next function and there would be no gaps, but even having a few extra clocks to save these intervening redundant registers is surely going to be less than another setq+wrlong burst and similar setq+rdlong to restore per function call in the 4 argument register case. All these memory accesses in hub exec mode are quite expensive in clocks as they can be further delayed by the FIFO.
With some AI assistance (big nightmare) I was able to modify P2LLVM to now generate proper conditional branching that it knows are linked to flags set from prior comparison (via SDNPOutGlue) and can locate termination points in the conditional blocks. As a result the built in P2LLVM optimization passes can now convert the double branches we saw before into a single conditional branch and can also choose to invert the flags being tested if that forms a better path to jump over the if block. But hell only knows what else got broken in that process of modifying the code! LLVM could not do this before with the P2 because it didn't really know the branches could be optimized as there were no fully complete analyzeBranch/insertBranch/removeBranch methods implemented yet for the P2.
For example with this C function instead of two back to back jumps we had before (just ignore that unoptimized AND and followed by CMP as I've disabled my TEST instruction pattern for now):
void test_mask_set_constant(unsigned int x) {
if (x & 0x3F) {
volatile int check = 1;
it generates the following P2ASM with the test now inverted so if it's zero it branches over the if block, rather than enter into it, even though the original code generated two branches: one conditional jump to jump to the true case block, and one unconditional jump for the false case which jumped beyond it. These get flipped during the optimization automatically by LLVM to identify the faster variant:
00000aa8 <test_bit_set_constant>:
aa8: 61 a1 67 fc pusha r0
aac: 04 f0 07 f1 add ptra, #4
ab0: 20 a0 07 f5 and r0, #$20
ab4: 00 a0 1f f2 cmp r0, #0 wcz
ab8: 04 00 90 ad if_z jmp #$4 <test_bit_set_constant+0x18> ' <$ac0>
abc: 3f 03 6c fc wrlong #1, ptra[-1]
ac0: 04 f0 87 f1 sub ptra, #4
ac4: 5f a1 07 fb popa r0
ac8: 2e 00 64 fd reta
I've also planned for a custom pass to run once all instructions are fixed in their locations that looks for relative forward jumps in the range from JMP #4 through JMP #20 (skipping 1-5 instructions) which I can replace with a conditional SKIP instead to avoid the branch penalty with the hub exec FIFO. It's already calculating the correct masks when it finds them in range already, it just has to swap out the instruction to complete it. This should particularly help speed up any short if tests with just one block (no else block case) which is relatively common in C for simple if tests.
❯ cl -Os -mllvm -verify-machineinstrs=false main.c 2> log
Detected JCC or JMP : jump distance is 10 instructions
Detected JCC or JMP : jump distance is 5 instructions
A SKIP Mask would be 1f
UPDATE: Also I think I recall reading that if setup correctly for the target it can identify short blocks of code that can be predicated until the next CMP or other instruction uses the flags. So that's another potential area for optimization. It may alleviate the need for SKIP or the conditional branch itself. But this stuff is not at all easy to figure out in the LLVM code without AI trying to explain some of it (including its own untruths) - or at least start you out in the right areas to look. It's a mountainous codebase.
9c: 80 03 00 ff augs #$70000 >> 9 a0: 00 f0 07 f6 mov ptra, #0 ' ##$70000 a4: 0c 03 00 ff augs #$61800 >> 9 a8: 34 a1 07 f6 mov r0, #$134 ' ##$61934 ac: d0 a5 1b f2 cmp r2, r0 wcz b0: 04 00 90 cd if_c jmp #$4 ' <$b8> b4: 0c 00 90 fd jmp #$c ' <$c4>Update: there is just one more missing item that the decoding of AUGS/AUGD stuff will also assist. The special augmented and unaugmented hub memory accesses using PTRx pointer index operations like:
mov r0, ptra[##$2A332]andmov r0, ptra[123]Right now these are not yet handled at all, either with augmented constants or without. I should add these which I think will complete the P2LLVM parser to accept all standard P2 instructions and aliases, although compile time expressions for calculating constants may still be limited - I've not looked into that.
@rogloh,
JMPREL LOC CALLD TJS TJNS TJV REP TEST TESTN CALLB BITxxx DIRxxx OUTxxx FLTxxx DRVxxx TESTP TESTPN TESTB TESTBN ALTR ALTB ALTI SETR SETS SETD COGATN XZERO CRCBIT CRCNIB WAITxxx SKIP SKIPF EXECF PUSH POP ADDPIX MULPIX BLNPIX MIXPIX ALLOWI STALLI TRGINT1 TRGINT2 TRGINT3 NIXINT1 NIXINT2 NIXINT3 ALTSN ALTGN ALTSB ALTGB ALTSW ALTGW SETLUTS SETCY SETCI SETCQ SETCFRQ SETCMOD SETPIV SETPIX SETPAT SETDACS GETXACC INCMOD DECMOD FBLOCK SETSCP SETINT1 SETINT2 SETINT3 GETPTR GETSCP CMPM CMPSUB RFVAR RFVARS SCA SCAS MUXC MUXNC MUXZ MUXNZ NEGC NEGNC NEGZ NEGNZ RCZR RCZL JINT JCT1 JCT2 JCT3 JSE1 JSE2 JSE3 JSE4 JPAT JFBW JXMT JXFI JXRO JXRL JATN JQMT JNINT JNCT1 JNCT2 JNCT3 JNSE1 JNSE2 JNSE3 JNSE4 JNPAT JNFBW JNXMT JNXFI JNXRO JNXRL JNATN JNQMT CALLPA CALLPBFound a typo and fixed the SETDACS opcode before it became buried and would cause problems later. But one error wasn't too bad given this was a manual process typing it all in.
NOT D,#2can incorrectly be matched asNOT D wc(alias form) because the #2 immediate S-operand in theNOT D, #Sform is the same value as the encoded WC flag. It looks like effects flag operands need to have their own type and not get encoded as immediates in order for the aliases to work in all situations. For now until that is resolved (which needs additional effort) I'll just disable the affected aliases. I think it's this list of aliasesNOT ABS NEG NEGC NEGNC NEGZ NEGNZ TEST ENCOD ONESOne other thing that I found is that the percentage symbol does indeed let you enter binary constants as it should after I'd enabled Motorola mode in the lexing. The $ prefix was working for hex but % was not working for binary when I tested it earlier. Turns out this was just because inline assembly also uses % as an escape character. To get the real % you need to use %%, although this is only needed for the inline assembler. The regular assembler that works with separate .s files only need a single % for binary number encoding (or can also use the 0b prefix, similar to 0x for hex). You can see both these prefixes now working in the captured log below. Unfortunately I don't think we can readily make the %% prefix represent two-bit quaternary numbers (base 4) as this is buried deep in the common lexing code used by all microprocessor targets which I certainly don't want to mess with. But as it's rarely used and we can easily convert those values into binary instead it shouldn't be a major deal to not have that feature implemented in P2LLVM.
❯ cat test.s .text mov r0, #%10101 mov r0, #$110 ❯ cl -c -o test.o test.s ❯ objd -d --print-imm-hex test.o test.o: file format elf32-p2 Disassembly of section .text: 00000000 <.text>: 0: 15 a0 07 f6 mov r0, #$15 4: 10 a1 07 f6 mov r0, #$110 ❯@rogloh Is the test suite of any use?
https://github.com/ne75/p2llvm/tree/master/test/src
2a5c: 04 de 97 fb tjz r31, <bb_mp_print_str_1> --+ 2a60: d3 a1 03 fb rdlong r0, r3 | 2a64: 04 a6 07 f1 add r3, #4 | 2a68: d3 a7 03 fb rdlong r3, r3 | 2a6c: 2e a6 63 fd calla r3 | 2a70: <bb_mp_print_str_1>: <-+ 2a70: d2 df 03 f6 mov r31, r2ps: Still don't like the pattern above with a TJZ falling through after the test by skipping over the following JMP. If the target is close enough it should be able to just do the reverse test condition and only branch with a single instruction and continue through otherwise avoiding a branch penalty in one of the cases. That's another optimization that needs to be added in time. There's plenty of others too including a conditional branch without the prior compare operation to set flags, by instead setting Z directly off the memory reads, ALU operations. It also avoids TJZ since you can do
if_z JMP xxxand purely use absolute addressing (for this external memory scheme I have in mind).Was able to fix the alias mismatching problem mentioned earlier by creating a new type for the WC/WZ/WCZ effects flags instead of treating it like an immediate. I think that is sorted now. Once I've tested all the new instructions I'll do the GitHub thing.
Yes, this would be a good case to work on.
Previously: https://github.com/totalspectrum/spin2cpp/issues/181
JMP #1,JMP #2..JMP #5encodings (relative offsets shown), preserve the condition code and replace with an associatedSKIP #maskin a last pass optimization when all instruction's addresses are locked in. Nothing gets shifted in memory, and any conditional branching would be preserved. Any given branch path should be able to work independently with their own associated SKIPs as the path taken through the code won't have to overlap/recurse the SKIPs in any way no matter what path is taken, they'll simply always be sequentially executed. It would work forJMPRELtoo in immediate form, while the register form is something I'm looking into for switch statement decoding...In looking at the P2 code generated by the P2LLVM backend for MicroPython I am occasionally seeing some cases like this where JMP #4 is issued and would be a candidate for the conversion to SKIP mentioned above, however it appears that the code is not doing the best thing here which is to place a single conditional JMP instruction and fall through to the LBB9_10 label otherwise.
00001520 <.LBB9_8>: 1520: 01 c0 07 f1 add r16, #1 1524: d4 c1 5b f2 cmps r16, r4 wcz 1528: 04 00 90 5d if_nz jmp #4 <.LBB9_10> ' <$1530> 152c: 34 00 90 fd jmp #52 <.LBB9_11> ' <$1564> 00001530 <.LBB9_10>: 1530: e0 c5 03 f6 mov r18, r16 1534: 02 c4 47 f0 shr r18, #2I've tracked it down to these definitions:
// Patterns for various branch conditions and types of branch instructions // unsigned comparison // unconditional jump def : Pat<(br bb:$target), (JMP bb:$target, 1, always)>; def CMPrr : P2InstCZIDS<0b0010000, 0b0, (outs P2Implicit:$cmp), (ins P2GPR:$d, P2GPR:$s), "cmp\t$d, $s">; def : Pat<(brcc SETUEQ, P2GPR:$lhs, P2GPR:$rhs, bb:$target), (JMP bb:$target, (CMPrr P2GPR:$lhs, P2GPR:$rhs, always, wcz), if_z)>; let DecoderMethod = "DecodeJumpInstruction", isBarrier = 1, isBranch = 1, isTerminator = 1 in { def JMP : P2InstRA<0b1101100, 0b1, (outs), (ins reljmptarget:$d, P2Implicit:$cmp), "jmp\t$d">; // relative address jump def JMPa : P2InstRA<0b1101100, 0b0, (outs), (ins absjmptarget:$d, P2Implicit:$cmp), "jmp\t$d">; // absolute address jump. }Because the conditional jump is shared with the unconditional jump instruction (only the IF_Z condition is different) the "isBarrier" value being set to 1 for both cases means the compiler will not let the execution fall through, and it will enforce the two jumps. We really need two "instructions" defined for JMP, one with isBarrier set to 1 and the other with it set to 0. It's a bit of work to change, but it probably should be done at some point to eliminate this inefficient double jump combo, although a SKIP replacing this JMP #4 would really help alleviate it also in the interim. Ideally it gets fixed the proper way, and I'm hoping it resolves the label generation for fall through cases so the extra blank lines and labels printed per function don't get issued - having all the extra blank lines in a function only seems to confuse things when reading through the code.
That one is better served by changing the conditional execution to the second branch and then removing the first branch entirely.
00001520 <.LBB9_8>: 1520: 01 c0 07 f1 add r16, #1 1524: d4 c1 5b f2 cmps r16, r4 wcz 1528: 34 00 90 ad if_z jmp #52 <.LBB9_10> ' <$1560> 152c: e0 c5 03 f6 mov r18, r16 1530: 02 c4 47 f0 shr r18, #2That's exactly what I want it to do. I'll try the change to create a conditional JMP branch instruction. My only concern is that it will have the same bit pattern as the regular jump (because conditions are specified separately) and there'll be a collision in the opcode generated when it tries to build the list of instruction encodings and sees two the same...and giggle AI says the same when I queried it, although it now has some suggested workarounds.
Yeah, follow ARM solutions. Conditional execution is same arrangement there.
RDLONG reg, ptra[nn]for accessing stack frame arguments and other locals from the stack. There is some of this present in the code generated but not all accesses use it and some code still creates pointers manually by offsetting from the SP (PTRA) like this code below. In this case I would have liked to see it coded simply asRDLONG r2, ptra[-$64]. Even if we need to add an AUG because it is out of indexing range in a single instruction we'd still be ahead on clocks and instruction space, plus it makes the disassembled code far easier to understand when you see it directly indexing off the SP not some random register.enabling (only) leaf functions to be called using
CALLD LR, #\functionand return withJMP LRinstead ofCALLAandRETA, saving hub memory accesses in hubexec mode. This instruction requires the "LR" to be PA,PB,PTRA,PTRB. Possibly PB could be useful for this, or even PTRB if not used for a base/frame pointer. It wouldn't need to be saved if this is a leaf function but it would prevent other uses such as for Fcache or use with external memory handlers with CALLPB (unless that saves it out first).enabling a BP (base pointer) for functions that use alloca() to allocate dynamic memory on the stack. Apparently (according to AI) LLVM can do this and we only incur the larger stack frame and extra prologue/epilogue setup overhead for the functions that actually use alloca(), which would be perfect. The remaining typical functions can still just use the SP as PTRA and simpler stack frame for accessing locals/args/spilled regs from the stack. PTRB is ideal as the base pointer for this as it can also index locals and arguments from a fixed location, while PTRA as the SP can then be adjusted dynamically without affecting any of the stack indexing in the code.
JMPon compare cases when one branch just skips over the other. It should simply just branch out in one case and fall through for the other. Also for any small code snippets being branched over it could also use the predicateif_zorif_nzetc to skip the small number of instructions not matching the actual condition (when the instruction count is < 6) or alternatively replacing it with aSKIPinstruction could have the same effect and it avoids needing to recompute all the if conditions through the small snippet and also preventing any further flag use in that group, at the expense of the actual SKIP instruction itself. SKIP is certainly simpler to implement IMO as you don't need to worry about messing up flag state.more use of patterns that take advantage of other P2 capabilities such as those using:
if (a) a--; else a=b;a+=(b * c)>>16;if (b<a) a-=b;if (c) a=a|b; else a=a&~b;make use of the WZ flag available on most ALU operations if it's going to be followed by a CMP instruction rather than comparing with zero again.
if (a%b == 0) { ... }The CORDIC can already write the Z flag on the GETQY for the remainder being zero. We should try to use that where it helps.I made quite a bit of progress in the last couple of days of testing out the GETxxx/SETxxx/ROLxxx patterns and in adding capabilities for single bit testing with TESTB and logical testing with TEST (instead of needing to use the destructive AND), and I also introduced a lot more patterns using P2 native instructions to help eliminate other instructions to achieve the same thing by utilizing MUXZ/MUXNZ/MUXC/MUXNC/BITL/BITH/BITNOT/DECOD/ANDN/MOVBYTS/SUMC/SUMNC/SUMZ/SUMNZ/BMASK.
Fibo is a useless benchmark because it uses so little of the instruction set.
Use Coremark instead: https://www.eembc.org/coremark/
@RossH That reminds me... Of course, should compare to Catalina C as well...
void test_mask_set_constant(unsigned int x) { if (x & 0x3F) { volatile int check = 1; } }it generates the following P2ASM with the test now inverted so if it's zero it branches over the if block, rather than enter into it, even though the original code generated two branches: one conditional jump to jump to the true case block, and one unconditional jump for the false case which jumped beyond it. These get flipped during the optimization automatically by LLVM to identify the faster variant:
00000aa8 <test_bit_set_constant>: aa8: 61 a1 67 fc pusha r0 aac: 04 f0 07 f1 add ptra, #4 ab0: 20 a0 07 f5 and r0, #$20 ab4: 00 a0 1f f2 cmp r0, #0 wcz ab8: 04 00 90 ad if_z jmp #$4 <test_bit_set_constant+0x18> ' <$ac0> abc: 3f 03 6c fc wrlong #1, ptra[-1] ac0: 04 f0 87 f1 sub ptra, #4 ac4: 5f a1 07 fb popa r0 ac8: 2e 00 64 fd retaI've also planned for a custom pass to run once all instructions are fixed in their locations that looks for relative forward jumps in the range from JMP #4 through JMP #20 (skipping 1-5 instructions) which I can replace with a conditional SKIP instead to avoid the branch penalty with the hub exec FIFO. It's already calculating the correct masks when it finds them in range already, it just has to swap out the instruction to complete it. This should particularly help speed up any short if tests with just one block (no else block case) which is relatively common in C for simple if tests.
