Spin Tools IDE - Page 35 — Parallax Forums
Spin Tools IDE
1293031323335»
  • JonnyMacJonnyMac Posts: 9,809
    Regular debug statements in Spin Tools will appear in the console at the bottom of the screen. Graphical debug windows are identical to PNut/Propeller Tool.
    Advantage of regular debug statements in the console is that it's a scrollable window -- in PNut anything that scrolls off screen is lost.
    @macca Will you consider adding a toggle to turn off the flashing cursor in the terminal window when in character input mode? I have a display that is very dynamic and the flashing cursor sparkling all over the screen is very distracting. I prefer character mode of this program so I can have single-key commands.
    Thanks.
  • maccamacca Posts: 1,031
    @bob_g4bby said:
    I don't know much about Linux: I installed Spin Tools IDE 0.54.1 on Linux Mint, following the instructions on Macca's website:-
    1. Can edit SPIN2 files in Spin Tools
    2. 'Show Devices' identifies my P2 Eval board on /dev/ttyUSB0
    3. I can interact with Taqoz in the Serial Terminal
    4. A program with some debug statements, which ran under Windows Spin Tools, appears to load to the P2EVAL, but produces no debug results in the debug window. Other programs which opened graphical debug windows in Windows do not do so in Linux Mint. When compiling the blue lights flash on the P2 Eval briefly, as though the code is uploading.
    I'd appreciate any advice on how to fix this, please. (Still using Win10, but have dual booted Linux Mint as a precaution)
    That's odd.
    One thing you could verify is if the program actually is loaded and working by blinking a led on the board.
    If that works, could be some issues with the serial port, but right now I can't think of a cause, aside from adding your user to the dialout group, but that seems already working.
    If the program is PASM-only (no Spin code) remember to use asmclk or enable the clock setter option (in Preferences -> Spin2). It should not make any difference when debug is enabled since it should automatically set the proper clock mode.
    Also, just to be sure, the debug is enabled when you upload with the bug icon on the toolbar, or use one of the specific Tools -> Upload with debug menu items.
    Try to run spinide from the command line, if there are internal errors they may appear on the console (cd spin-tools then ./spinide).
    You can also try with the command line compiler spinc (replace the serial port device with yours):
    ./spinc -r -d -t -p /dev/ttyUSB0 Program.spin2
    The -t enters the terminal mode, you should see the debug messages but no debug windows (not supported from the command line).
    Always try with a small simple program.
    Yes, I'll add the option.
    If you are using ANSI mode, you can turn off the cursor with ESC[?25l unfortunately there isn't a code for PST.
    I was thinking to merge the terminal modes, codes are mostly compatible, except the CR that adds an LF with PST.
    I have to think about that.
    edited 2026-03-27 19:28
    I'm using PST mode. For the moment, just open PST so I can watch the data without all the distracting cursor sparkles. Thanks for add the option. I have seen terminals that will treat a CR as a CR or a CR+LF. Maybe that's worth considering, too.
    Off topic: Can Charles or Lewis beat the Mercedes this weekend?
    Yes, merging the terminal modes requires some configuration settings.
    I hope so, but honestly, I think the chances are low, at least until june or so...
    edited 2026-03-28 05:11
    @macca thanks for all the suggestions.
    "... working by blinking a led on the board." - This code blinks the 8 P2-EVAL blue LEDs when run without debug using the 'play' button. When running with debug ('bug' button) two lights briefly flash, but then the program does not run - no blinking lights. This is the code used:-
    pub go() | x
      repeat
        pinwrite(56 addpins 7, getrnd())
        waitms(100)
    "... if there are internal errors they may appear on the console " - No error messages appear in the console during and after spinide execution from the command line.
    "... You can also try with the command line compiler spinc (replace the serial port device with yours):" - Running ./spinc -r -d -t -p /dev/ttyUSB0 blink.spin2 produced in the console:-
    bob@bob-Z68X-UD3P-B3:~/spin-tools$ ./spinc -r -d -t -p /dev/ttyUSB0 blink.spin2
    Spin Tools Compiler - Version 0.54.1
    Copyright (c) 2021-26 Marco Maccaferri and others. All rights reserved.
    Compiling...
    blink.spin2
    blink.spin2: 1:11 : warning : method "go" local variable "x" is not used
    Program size is 9170 bytes
    Uploading...
    Propeller 2 on port /dev/ttyUSB0
    Loading binary image to hub memory
    9176 bytes sent
    Verifying checksum ... OK
    Entering terminal mode. CTRL-C to exit.
    Cog0  INIT $0000_0000 $0000_0000 load
    Cog0  INIT $0000_0F64 $0000_1860 jump
    The two debug lines got through OK and the 8 blue LEDs flashed properly.
    I added a counter to the program:-
    pub go() | x, counter
      repeat
        waitms(100)
        counter := counter + 1
        debug(udec(counter))
    When running using SPINC as above, the expected debug lines were displayed + the blue leds flashed
    When the above was tried under Windows 10 in a command window, the expected debug lines were displayed + the blue leds flashed
    So SPINC behaves normally in Windows 10 and Linux Mint.
    I don't have a lot of time invested in Linux Mint, so don't mind switching to another distro - what are known to work with Spin Tools IDE? Alternatively, I'm quite willing to try more experiments to get the IDE working under Mint - I'm using version 22.3, which is not that old. It's a 'would-like' for me, not a 'must-have'
    Cheers, Bob
    edited 2026-03-27 23:59
    Are you clicking the DEBUG icon on the toolbar?
    This is what I get when I run that bit of code (Windows 10 Pro).
    edited 2026-03-28 05:14
    Yes @JonnyMac , just to confirm:-
    When running spinide:-
    Clicking the 'Upload to RAM with Debug' button on the toolbar under Windows 10, I get the same as you + all the blue leds flash - normal operation
    Clicking the 'Upload to RAM with Debug' button on the toolbar under Linux Mint v22.3, no debug display is produced and no blue leds flash - abnormal operation
    Clicking the 'Upload to RAM' button on the toolbar under Windows 10, all blue leds flash - normal operation
    Clicking the 'Upload to RAM' button on the toolbar under Linux Mint v22.3, all blue leds flash - normal operation
    When running spinc from a terminal window, using './spinc -r -d -t -p /dev/ttyUSB0 blink.spin2' as per @macca 's hint:-
    Under Windows 10, the blue leds flash and the expected debug is displayed in the terminal window
    Under Linux Mint v22.3, the blue leds flash and the expected debug is displayed in the terminal window
    pub go() | x
      repeat
        waitms(100)
    Well... if I'm not wrong, that program also toggles the prop-plug serial pins (62 and 63), at least for me, when run without debug I also see the prop-plug led flashing. Oddly, that doesn't happens with debug, it randomly flashes the two leds on the P2-EC board but nothing on the prop-plug.
    That's weird, spinc and spinide are basically the same, except the UI.
    I'm using Ubuntu 24.04LTS, but is not a fresh install, I don't remember if I had to do something special with a fresh install.
    I vaguely remember an issue with ModemManager that attempted to get control of any serial device, had to add an udev rule to get rid of it.
    Checking the /etc/udev/rules.d directory I see a number of rules that includes the FTDI vendor id 0403, the most relevant, to me are these:
    70-snap.snapd.rules:754:ATTRS{idVendor}=="0403", ENV{ID_MM_DEVICE_MANUAL_SCAN_ONLY}="1"
    77-bitscope.rules:7:ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ENV{ID_MM_DEVICE_IGNORE}="1"
    The first should have been installed by the system as it uses snap packages, the other is for the BitScope Micro device.
    Check if you have at least the snapd rule installed, or uninstall ModemManager (should be package name modemmanager).
    edited 2026-03-28 09:28
    The /etc/udev/rules.d directory contains one file - '70-persistent-cd.rules'. (Why is it that Nemo, the file manager doesn't display folder 'etc' even when told to display hidden files - Aaaagh?!)
    Sorry for the blunder in the led flash program. I've modified it to flash 4 LEDs only now, so the debug link can't be disturbed:-
      repeat
        pinwrite(56 addpins 3, getrnd())
        waitms(100)
    I uninstalled modem manager and rebooted just in case that was needed.
    The issue with Spinide remains, no 'Upload to RAM with Debug' functionality with this Linux Mint.
    Since everything works under Windows 10, I'm quite happy to set this aside for now.
    Many thanks for the hints and tips.
    Cheers, Bob
    edited 2026-04-01 04:10
    @macca Would is be possible for the for the Program Information dialog to show the memory usage of the selection from the file tree. ATM it shows the project usage -- it would be really nice if we could click through the files to see their contribution to the overall size.
    It would be nice if the selection would change the memory usage display to reflect the object selected.
    Thanks for considering.
    A few minutes later... Maybe I knew this subconsciously, but I just checked and found Propeller Tool does this. Can we match that feature accounting for unused method removal so we know the actual memory impact in context of the application?
    @macca: Very small thing for a future bug-fix release. p_invert_out is a P2 symbol, but not recognized by the editor color highlighting.
    @macca: Would consider adding a "Clear Bookmarks" item to the bookmarks menu(s)? Thank you.
    Yes
    There is P_INVERT_OUTPUT but missing P_INVERT_OUT, I'll fix it.
    I'm a bit quiet in this period because I'm working on some long overdue extensive updates for Spin Tools, even if I don't answer immediately, I'll consider all requests.
    Thank you very much.
  • evanhevanh Posts: 17,181
    edited 2026-04-10 23:47
    The original P_INVERT_OUTPUT symbol controls the pad-ring logic. They do control the same thing of course but the reason why P_INVERT_OUT wasn't a symbol from the start would've been because the hardware docs describes Output as distinct from OUT. OUT is the cog's bit state of the pin, at the cog. Whereas OUTPUT is what arrives at the pad-ring. There is a number of stages and intermediate logic, including the smartpin, between the cog and the pad-ring.
    I guess what I'm saying is P_INVERT_OUT probably wasn't the wisest of additions.
    According to Chip's doc's, one is an alias for the other.
    Yes, that came along later. A bad choice IMHO.
    edited 2026-04-12 05:10
    @macca I had and odd error in Spin Tools during a late-nigh coding session. Instead of this:
      time.set(-500)
    I entered:
      time.set := -500
    The IDE told me I had errors, but it didn't show them, in fact, all of the annotations were removed from the annotation strip. Only the name in the editor tab was red.
    @JonnyMac said:
    I entered:
      time.set := -500
    P1 code, right ? P2 seems to report the error correctly.
    Will fix it.
    edited 2026-04-13 14:14
    P1 code, right ?
    Yes. Sorry I wasn't specific before.
    Would you consider showing elements included in a project via the file directive in the object tree? Propeller Tool does this.
    Those elements are not displayed in Spin Tools.
    That said, I did verify that they are included in the archive when created.
  • pilot0315pilot0315 Posts: 993
    edited 2026-04-19 23:32
    The latest spin tools I think it is 54, serial terminal would only open full screen. I am usinga 58 inch screen and had to painfully reduce it size every time.
    Started over completely now no serial terminal opening on any of the versions. Had to mess with microsoft as usual running windows 11 pro. Told it to run anyway. I can see that there looks like a serial terminal on the task bar but cannot access it in any version of spin tools.
    Any suggestions.
    I hate windows.
    Martin
    When opening propeller tool the tool says that the comport is occupied. I know this is the spin tools serial terminal. Closed spin tools gui and that I know closed the serial terminal that I cannot find.
    edited 2026-04-20 00:57
    The current version of Spin Tools is 0.54.1
    Suggestions:
    1. Shut down Spin Tools
    2. Go to your user folder and delete the file called .spin-tools (you may have to enable showing hidden files)
    3. Restart Spin Tools -- it will rebuild your .spin-tools settings file
    Unlike PST, the Spin Tools terminal doesn't release the COM port when it loses focus; you have to close it manually
  • Did all that. I know that the comport is not released automatically. I have been using the newest version. The serial terminal when I had it working would always on version 54.1 open full screen and would not accept the adjustments to make it smaller.
    I have started from scratch 5 times.
    I am going to AGAIN delete everything in all files and hidden files and try again. Already in progress before your post.
  • I was in the middle of that for the 6th time. It finally stuck. Windows is a PIA. Learned how to fight it years ago. Even back in the DOS systems.
    That was fun.
    Somewhere was a ghost in the system that screwed this up.
    Make sure that you only have one instance running; Spin Tools can run multiple instances. Some like this. I don't. Hopefully, Marco can add a preference feature that disables running multiple instances of Spin Tools.
  • RaymanRayman Posts: 16,323
    edited 2026-04-20 21:42
    Spin Tools will lock the com port if Debug is running.
    I hit the play button (Upload to RAM) to set it free.
    (but this is without terminal enabled...)
    Or, just close Spin Tools for same effect...
    The COM port is released when the debug window is closed with the Tools -> Toggle Console menu or toolbar button (the button near the terminal icon).
    This is equivalent to the DEBUG_END_SESSION flag, it also closes all graphical debug windows.
    Optionally, it can also reset the Propeller, if configured in Preferences -> Console -> Reset Device on Close
