RGB LED Array accessory for Eval type header - Page 2 — Parallax Forums
2»
  • RaymanRayman Posts: 16,367
    Hmm... Ok, guess overkill... Still if can strobe at 40*900/8 = 4.5 kHz... Maybe good as a flash for high speed camera...
  • TonyB_TonyB_ Posts: 2,278
    edited 2026-03-17 13:11
    @JonnyMac said:
    This code is the equivalent of pinwrite() after the signals from each stream have been moved into a parallel group.
    wr_outs                 testb     outs, #5              wc      ' lsb pin in outa or outb?
            if_nc           setq      outsmask                      ' mux pixouts into outa using outsmask
            if_nc           muxq      outa, pixouts
            if_c            setq      outsmask                      ' mux pixouts into outb using outsmask
            if_c            muxq      outb, pixouts
    SETQ does not have to be immediately before MUXQ, unlike most instances of SETQ. It can be a few or many instructions earlier, as long as Q is not changed in the interim. (Another SETQ is not required before the next MUXQ if the mask is the same and nothing else modifies Q.) Therefore the following code is possible:
    wr_outs                 setq      outsmask                      '
            if_nc           muxq      outa, pixouts                 ' mux pixouts into outa using outsmask
            if_c            muxq      outb, pixouts                 ' mux pixouts into outb using outsmask
    I wondered about that, Tony, but ended up duplicating what Chip does in the interpreter. The docs on setq are a little confusing; I interpreted them as saying that q gets reset after the next instruction.
    From the latest interpreter:
    ' PINWRITE(pins,val)
    pinwrite_       mov     w,x                     'w=val
                    setq    #2-1                    'pop pins and new top of stack
                    rdlong  x,--ptra                'y=pins
                    ror     y,#6    wc              'get outa/outb flag into c
                    bmask   v,y                     'make mask
                    rol     y,#6
                    rol     v,y                     'justify mask
                    rol     w,y                     'justify val
            if_nc   setq    v                       'mux val into outa using mask
            if_nc   muxq    outa,w
            if_c    setq    v                       'mux val into outb using mask
            if_c    muxq    outb,w
            _ret_   dirh    y                       'enable outputs
    Moments later....
    Okay, that works. Thanks for the feedback.
    Took a peek at the @JonnyMac gamma function today and can now see how this WS2812C version with 5 mA max is much better here (for most cases) than the WS2812B version at 12 mA max.
    First of all, you probably don't want full power, even with the C version, so probably limiting max to some value like 25 % or so. I mean, maybe there is a case for blinding brightness, but that is probably unusual...
    Anyway, when a limited max gets factored in with gamma, looks like the range of possible levels would be very limited with the B version...
  • ke4pjwke4pjw Posts: 1,321
    You should load the latest version of of Blitzen 24 for this. It would be neat to throw Jinx at it.
    Jinx looks neat but probably overkill for 8x8... Do have a 64x32 that would be more interesting for that though...
    edited 2026-03-23 15:14
    As Ray was kind enough to send me a board, I did! -- throw Jinx at it. Thanks for mentioning it, Terry. The only lighting controller I'd ever used before was version 2 of Vixen.
    I kind of muddled my way through Jinx, but did get it working. Now that it works I should probably read the Jinx docs!
    The first three elements of the Setup menu will get you there.
    Step 1: Define the matrix size. The only thing I did was change the dimensions.
    Step 2: Add an output device -- in this case we use serial via the Gledinator protocol.
    Step 3: Patch the matrix to the serial device.
    Click on Fast Patch and then select Linewise starting Bottom Left if your board is oriented connector left, pixels right like mine is (see video). Funny, I modified my driver this morning because I expected lighting control software would want to start in the upper left. There are other reasons to use the latest driver (in the archive), but we don't need to use the vertical flip feature I added when using Jinx.
    Since the code using the programming port, download the project first, then you can run data to it.
    IMPORTANT: Set the master level very low before clicking on Start Output to prevent drawing too much current from the USB port.
    See post #41 for the latest version of the Jinx player code.
    @JonnyMac Thanks for figuring that all out! Downloaded Jinx and can see being fun to play around with.
    Scrolling text needs some work though. Need to somehow get a font that actually works in there...
    Also, why can't text be black? Don't see any way to do that.. Maybe that's just a bad idea or something...
    edited 2026-03-23 14:28
    Got Jinx working! I guess it is neat even at 8x8.
    The one thing that took me a minute to figure out is that the "Start Output" on the menu is also a toggle button.
    Start Output needs to be turned off and then back on for changes to take effect, seemed like.
    The need to turn down the master (brightness) is a bit not so nice as it makes the preview window too dark to see.
    Maybe need to do this in the driver instead...
    edited 2026-03-24 01:26
    Cool.
    That isn't my experience -- I can select something different from the Channel 1 drop-down menu an it will immediately take effect.
    Easy-peasy lemon squeezy. There is a scaling method in the driver -- change your main code to this. I just tried it with the master level on Jinx set to 100% (fully right).
    pub main() | p_buf, b, color
      setup()
      repeat
        p_buf := @pixbuf0                                           ' point to pixel buffer
        repeat
          wait_sync()
          b := jinx.rx()
          if (b == $01)                                             ' header/sync?
            quit                                                    '  yes, exit to process stream
        repeat N_PIXELS                                             ' process pixel stream
          color.byte[3] := jinx.rx()                                '  red
          color.byte[2] := jinx.rx()                                '  green
          color.byte[1] := jinx.rx()                                '  blue
          color := rgb.scale_rgb(color, 13)                         ' limit to ~5%
          long[p_buf] := color                                      ' write adjusted color to buffer
          p_buf += 4                                                ' point to next pixel
    This is for testing. I will update the Jinx player code so the scale is set as a constant above the code.
    A few minutes later... Here's a code update that incorporates what I showed above using a constant called PIX_LVL instead of a literal value.
    edited 2026-03-24 12:23
    Thanks @JonnyMac
    Just tested. It seems like gamma is not behaving exactly right when using the master level...
    Can really see it in Metaballs effect.
    I didn't look but, maybe master level is applied before gamma instead of after? Hope it's that simple...
    Oops. Seems I had matrix as 64x64 and that was messing up gamma...
    Well, did something that messed up 1st pixel on first row. Probably something in "Fast Patch", but don't know.
    Reinstalled Jinx and all better. Must be saving settings locally because it didn't remember old settings...
    Looking at Metaballs again and maybe there is still a small gamma issue. Or, maybe just a difference between PC screen and array...
    That's definitely the case for me. It's close enough for experiments, but I think having to put the display at a low level to prevent drawing to much current from the Eval board makes it challenging to see what are low levels on the PC.
