P2BrightBall: P2+BW Camera as a Position Sensor, Balancing a White Marble
This is some fun experiment and work in progress. Goal is to control the path of the marble.
Hardware consists of a P2 Kiss Bord with attached BW Camera as 2-dimensional position sensor to detect a white marble on a black background. The marble runs on a plain, which can be tilted in two directions using 2 standard 180° RC servos. Mechanics is a labyrinth game.
Diameter of this glass marble is 13,77mm, weight: 3.35 grams
The usable size of the plain is 264mmx223mm
Vertical distance of the camera from plain: 390mm
Camera: https://forums.parallax.com/discussion/178031/connecting-a-bw-320x320-pixels-camera-arducam-hm01b0-to-parallax-propeller-p2-via-4-lines#latest but using resolution 160x160 Pixels
There is a 1W LED lamp close to the camera to avoid asymmetrical shadows.
There are some camera projects in the net to be found mostly using some sort of AI with complicated and slow picture analysis. In this case here we can "design the problem", so we are using a very dark background and a very bright marble. Also we know for example the size of the marble. The automatic exposure of this camera works well, so we can use an absolute threshold.
The idea is then to have a simple way of finding the marble in the picture to get a high update rate for the position. For sake of speed also the resolution of the picture is reduced.
This is, how the camera sees the marble in the top left corner:
The wooden frame is rather bright too, so this is cut away.
The very simple method to get the position is right now to consider every pixel with brightness > 210 as part of the marble.
pub calcBallPos() | index, line , val, n, nc, nl '###########################################
n, nc, nl:=0 , 0 , 0
repeat line from LMIN to LMAX
repeat index from CMIN to CMAX
val:= picBuf.byte[line*(164) + index+4] ' 4 border pixels
if(val>BBRIGHT)
'term.tx(grey95.byte[95 - 95*val/255])
n+=1
nc+=index
nl+=line
if(n>0)
colPos:= 10*nc/n
linePos:= 10*nl/n
The idea is to try a PID-controller or rather two of them for the 2 directions. At the moment I am trying to learn about the system. There is an interesting Autotune Method to set the PID parameters, which gets information about the system via a Relay test: https://pages.mtu.edu/~tbco/cm416/Atune.html
So with an angle amplitude of 9 degrees at the servo (at the plain it is less), we get the following behaviour:
Cycle time for this is about 4600ms and resulting amplitude is about 89 rows.
Cheers Christof
Looks like fun!
Wonder is a steel ball would be easier to control…
Yes, more inertia would be easier, if it has the same diameter.
My steel and brass balls only have D= 11mm. So they are only slightly more inertia. The camera can detect both.
Big problem is, that the ball hangs on minimal uneveness of the surface. The original game is very difficult for myself.
The PID controllers are working now and the Relay method has given good start values for the parameters. Now the system has to be tuned....
