Visual Studio Code supports P2 development on Windows, Mac, Linux (yes, RPi) - Page 9 — Parallax Forums
145679
  • Stephen MoracoStephen Moraco Posts: 459
    edited 2025-05-21 18:16
    @wummi , I've released v2.4.5 of the Spin2 extension with the updated SerialPort support. You should already be able to update to it. Let's see if this helps!
  • @Stephen, pnut_ts is now running. Thank you for fixing.
    I try the USB-Serial report and get:
    USB Libraries on Platforms Test Report for [macOS]
    Run :  Thursday, May 22, 2025 at 10:32:04 AM
        Tool :  VSCode Spin2 Extension v2.4.5
    Using library [serialport v13.0.0]:
    -- DEVICE -----
     Port: /dev/tty.debug-console
     Manufacturer: undefined
     Serial Number: undefined
     Location ID: undefined
     Vendor ID: undefined
     Product ID: undefined
    -- DEVICE -----
     Port: /dev/cu.usbserial-A9M9DV3R
     Manufacturer: FTDI
     Serial Number: A9M9DV3R
     Location ID: 08314000
     Vendor ID: 0403
     Product ID: 6001
    -- DEVICE -----
     Port: /dev/cu.usbserial-D30GTX1X
     Manufacturer: FTDI
     Serial Number: D30GTX1X
     Location ID: 08313000
     Vendor ID: 0403
     Product ID: 6015
      - (is PropPlug)
    -- DEVICE -----
     Port: /dev/tty.Bluetooth-Incoming-Port
    -- DEVICE -----
     Port: /dev/cu.usbserial-D30GTX1Y
     Manufacturer: FTDI
     Serial Number: D30GTX1Y
     Location ID: 08320000
     Vendor ID: 0403
     Product ID: 6015
      - (is PropPlug)
    Open device and get P2 Info:
     [ #1 - /dev/cu.usbserial-D30GTX1X,D30GTX1X ]
     [ #2 - /dev/cu.usbserial-D30GTX1Y,D30GTX1Y ]
    Found PropPlug S/N #D30GTX1X at [/dev/cu.usbserial-D30GTX1X]
     P2:
    VSCode Spin2 Extension by:
     Iron Sheep Productions, LLC
    The PropPlug at A9M9DV3R is not found, this is a FT232R USB UART, you not supported yet.
    But in the Toolbar no ProgPlug is shown. Plug:N/A
  • @wummi my code actually looks for vid/pid of 0403/6015 that’s why the device at 0403/6001 is not recognized as a prop plug. Is that device an official part from parallax?
    No this is a cheap Chinese USB-Serial Plug, but PNUT and Spin-Tool has no problem with it.
    I think it is no good Idea to look only for vid/pid of 0403/6015.
    For me it is good if you look for vid: 0403, because in my projects I only use FTDI USB to Serial Chips.
    But this is not the problem, my Plugs with vid/pid of 0403/6015 are also not shown in the Toobar.
    edited 2025-05-22 20:55
    @wummi, ok, we now understand what's happening!
    Please verify the following for me:
    • See if the two prop plugs are shown in settings as discovered and are available for use.
    • If you click on the toolbar item for the prop-plug selection, you can select one of the two prop-plugs.
    • Once you select one, it stays selected when you return to this project.
    • Lastly, remove (unplug) one of the prop-plugs and open a new project with spin2 code in it. The only prop-plug should be automatically selected for you in this case.
    Re: non-official prop plugs: I could add a setting to remove this PID/VID gate. This will allow you to use the other USB Serial when selected, but we don't know if these other devices will handle DTR toggling correctly, as they are untested. Are you sure you'd like this option added?
    they are not available, Toolbar always show:
    same with a new project and only one official prop plug.
    Yes please add this option, not all self made PCBs use the FT231X USB UART for programming and debug.
    And please allow toggling RTS to reset the P2 as an option, when you want to use the FT234XD USB to serial UART interface with
    the packaging (3mm x 3mm 12 pin DFN) for smaller PCB designs. The FT234XD has no DTR-Pin, only the RTS-Pin.
  • @wummi what i don't understand and we need to figure out is why the report says there are two propplugs and why the toolbar says there are none. That's inconsistent and broken. Can you show me what you see in settings:
    PropPlugs in settings
    I'll work on enabling the setting to open up the gate to allow non-propplugs, but I don't know how to predict (code for) the ability to toggle DTR/RTS on these foreign devices.
  • @Stephen here the initial Devices List
    I can add the Device manually
    Then the Toolbar changes to
    When I click Plug: Not Selected, the Device List is cleared and in Toolbar Plug: N/A is shown.
    DTR/RTS select:
    In Spin Tools IDE we can select:
    Implement like this:
            if (DTR_Reset_enabled) {
               await this.setDtr(true);
               await waitMSec(2);
               await this.setDtr(false);
            if (RTS_Reset_enabled) {
               await waitMSec(2);
               await this.setRts(true);
               await waitMSec(2);
               await this.setRts(false);
  • @Stephen, I did some more tests.
    My main computer is a Mac Studio M2-MAX with MacOS 15.5.
    On this no Prop-Plugs are found.
    Now I change to a Macbook M1-PRO with MacOS 15.5.
    I install a new VSC, then node.js and pnut_ts.
    I copy the project vom the Mac Studio to the Macbook.
    ctr-opt-cmd-U shows the same Devices as before.
    But no Plugs are shown in the ToolBar.
    Same problems on both Macs.
    Then I change the VSC Language from German to English, no success.
    What next?
    Can you disable the automatic generation for the Device-List.
    Then I can manuel edit the Device-List and try to select one from this Devices.
    When this works, I can try to download to the P2.
  • @wummi thank you for all of this information. Give me a couple of days to make the setup tweaks.
    As an aside, I'm a Mac user as well (Mac Studio M2 Ultra, MacOS Sequoia 15.5), but I don't understand why this is all working for me and not for your Macs.
    If you can think of any possible reasons why, I'm all ears ;-)
  • @Stephen, does the device handling use node.js?
    I use newer versions of node.js, vers 22 and vers 23.
    But I thought node.js is only required for Pnut.ts.
    The Spin2 VSCode extension is written in TypeScript and uses NPM Packages for serialport and other services.
    VSCode appears to have its own Node.js environment but doesn't expose it directly to extension authors.
  • NEWS
    This may be very few users doing this, but I should at least share my testing results ;-)
    If you are a Mac user running Apple Silicon and are also using Parallels Desktop to run Windows...
    With the release of Spin2 v2.4.5, which includes updated serial port support, the Spin2 extension now works under Windows running in Parallels Desktop.
    (The Node Serialport team finally released a build for Darwin-x64+arm64.)
  • @wummi embarrassingly, I found the problem. Sigh...
    My environment has propplugs with attached P2s. They are found correctly.
    When I don't have the P2s attached and powered up, they are not found.
    This is NOT how I intended this to work.
    I'm fixing the detection code now and will release it shortly. I've also added the new vendor-only match and reset controls for FTDI devices.
    I'm looking forward to your testing with the new version once it's released.
  • @wummi ok, Spin2 Extension updated: Spin2 v2.4.6 should be avail to you now.
    Looking forward to hearing of your test results.
  • @Stephen, Spin2 Extension v2.4.6 is working now .
    It finds all Prop-Plugs and I can select one in the Toolbar.
    But when I try do download a bin-File with shift-control-D i get:
     *  Task wird im Ordner VSC ausgeführt:  "" VSC.bin
    zsh:1: permission denied:
     *  Der Terminalprozess "/bin/zsh '-l', '-c', ' "" VSC.bin'" konnte nicht gestartet werden (Exitcode: 126).
    Is an external Loader-program needed?
    And where to get one for MacOS on Apple Silicon CPU?
  • @wummi, I'm looking at this along with your highlight/crash issues. More soon.
  • BTW, the Spin-style inline ASM feature of FlexProp confuses the systax highlighting:
    I don't know if that can be fixed at all since the code is detected as C and not Spin.
    You are right since it's C i can't do anything since the highlighter for spin2 is enabled by the .spin2 file type by VSCode.
    If this is a spin2 file compiled by flexspin and this syntax is used I might be able to highlight this syntax correctly.
    My goal for the Spin2 extension is to be the first class highlighter for full PNut/PNut_TS syntax
    • a secondary goal to do much later is add flexspin support for spin2 only.
    meanwhile, until the seconday goal is achieved i've added minimal flexspin support which is enabled by a setting.
  • NEWS
    I've just released v2.5.0 of our spin2 extension.
    Users of VSCode get automatic updates, so you all have these updates already!
    Here's a recap of what's new:
    v2.5.0 # Complete our Spin2 Toolchain Story
    This update adds pnut-term-ts use as a downloader when using pnut_ts as a compiler. This now provides us with a debug window support on all platforms.
    • optionally, a new setting allows pnut-term-ts to be used with the flexspin compiler
    NOTE: Please make sure you have pnut-term-ts v0.9.5, or later, installed per our installation instructions so that pnut-term-ts is correctly found. Also, verify that it was found by VSCode by looking in the Spin2-specific settings.
    If you see any issues with this new feature, please let us know by filing new issues at our code repo. (or email me directly.)
    Upcoming: See follow-on work reported in Change Log. Of course, if you find issues between now and then, I'll try to get to fixing them, too!
  • NEWS
    I've just released v2.6.0 of our spin2 extension.
    Here are highlights of what's new:
    v2.6.0 # Major feature additions, code navigation improvements, grammar fixes, and many diagnostic/highlighting corrections
    • PASM2 Hover Documentation: comprehensive hover help for 362 instructions, conditionals, effects, and streamer constants with context-aware display (AND in DAT shows PASM2 doc, AND in PUB shows Spin2 operator doc)
    • Include Directory Support: two-tier include directory system (central library paths and per-folder project includes) with auto-discovery, Tree View UI, and compiler -I flag generation
    • Struct-aware Go to Definition: navigate to struct field declarations through multi-level chains (e.g., pline.a.x)
    • Hover Type Annotations: all variables, parameters, and return values now show their type (BYTE, WORD, LONG, or struct type) in hover tooltips
    • New Code Navigation features
    Language Version Support
    • Add v52 support: ENDIANL and ENDIANW methods (reverse-endian value conversion)
    • Add v52 support: DEBUG_END_SESSION constant for use in DEBUG
    • Add BACKCOLOR as recognized TERM debug display feed/update parameter
    New documents have been added to better describe all of our features. Start with this index VSCode Environment - Reading List
    If you see any issues with these new features, please let us know by filing new issues at our code repo. (or email me directly.)
  • OK, I'm polling for suggestions.
    The spin2 extension has an object interface document generation capability. Its goal is to provide a document that presents an object's public interface so we can learn how to use it.
    I would like to extend this by adding constants (including structure definitions), but with all constants effectively public, this becomes noise rather than useful.
    So let me propose one method, then let's discuss alternatives...
    My thinking: have a comment marker as we do with {Spin2_v99} version tag that effectively says all constants below here are private, e.g., {Spin2_Private_Constants}, then my extension would only list constants that appear above this marker.
    Thoughts? Alternatives?
  • AJLAJL Posts: 531
    Could there be a pair of markers that allow the listing inclusion to be turned on and off, allowing public constants in separate blocks (e.g. per function within a single file)?
    Yes, that's very feasible.
    @macca , @ersmith , @cgracey any thoughts? about using markers for identifying public constants in our code?
    edited 2026-03-04 21:18
    NEWS
    UPDATE TO BUILD TASKS within VSCODE!
    I've just released v2.6.3 of our spin2 extension.
    v2.6.3 # Debug highlighting and task argument fixes
    • BUGFIX: Highlight DEBUG_END_SESSION and other debug control symbols correctly inside debug() statements (v52+)
    • BUGFIX: Preserve struct field references (e.g., name[0].namefield) inside non-display debug() statements -- index expression rebuild was truncating the dotted member access
    SPECIAL NOTE: We found issues running pnut-ts and pnut-term-ts (and the other compilers/tools as well). I've also published the updated tasks.json file content, which completes the solution to this problem. You will need to replace the P2 content of your tasks.json with the new content. (The content is identical on all three pages, so here's one of them: Adding P2 Tasks
    NOTE: Please make sure you have pnut-term-ts v0.9.18 or later installed per our installation instructions so that pnut-term-ts is correctly found. Also, verify that VSCode found it by checking the Spin2-specific settings.
    New documents have been added to describe all of our features better. Start with this index VSCode Environment - Reading List
  • maccamacca Posts: 1,026
    I don't have a documentation generator so I've never considered this issue, however it could be interesting for defining the visibility of an object's constants.
    I don't like much the idea of markers that define the begin and end of private constants, instead I like to have implemented at the CON block level.
    An annotation that defines the whole CON block as private to the object and not visible to calling objects.
    {Private}
    CON ' Private constants
        TEST = 1
    CON ' Public constants
    With public as default it should not break any existing code.
    The annotation concept could be extended to single constants, this makes it a bit more complicated, not sure it is worth it.
        OK = 0
        ERROR = -1
        {Private}
        TEST = 1 ' This is private
        PIN = 8 ' This is again public
    The annotations concept is taken from Java (and other languages) where it is used to define method overrides, unit tests, special behaviours, etc.
  • JonnyMacJonnyMac Posts: 9,773
    I'm failing to see the value in private constants. Can't that be solved with DEFINE and IFDEF?
    They can be used like PRI methods, constants that are not meant to be used outside the object itself (internal states, buffer sizes, smart pin configurations, etc.).
    Code editors with code assist like Spin Tools and, I guess, VSCode, can list only public constants.
    Looking at the micro_sd_fat32_fs.spin2, I see there are a lot of constants and I guess most of them are not useful outside the object itself but the code assist will list them making difficult to find the really useful constants, private constants will not be listed, like PRI methods.
    The preprocessor can include or exclude portions of the source code, but doesn't change the visibility.
  • NEWS
    UPDATE TO BUILD TASKS within VSCODE! Please update your tasks.json file! (Fixed issues with white-space in tool paths)
    I've just released v2.8.0 of our spin2 extension.
    v2.8.0
    pnut_v53 compatibility
    New Features
    • Add OFFSETOF(struct.member) support for PNut v53 -- returns the compile-time byte offset of a member within a structure definition
    • Semantic highlighting for OFFSETOF() as a built-in function (same coloring as SIZEOF())
    • Hover documentation for OFFSETOF() showing syntax and description
    • Validate OFFSETOF() argument is a structure type; report error for non-structure arguments
    • Version directive gating: OFFSETOF() requires {Spin2_v53} directive
    • Quick Fix code action to add or update {Spin2_v53} directive when OFFSETOF() is used
    • Add MOVBYTS(value, order) as a Spin2 built-in function with hover documentation (byte reordering via base-4 pattern)
    • Add semantic highlighting for DEBUG_END_SESSION constant in PUB/PRI and CON blocks
    Fixes
    • Fix OFFSETOF(struct_type.member) and SIZEOF(struct_type.member) coloring -- struct type names (not just instances) are now recognized as valid struct references
    • Fix SIZEOF(obj.structType) and OFFSETOF(obj.structType...) validation -- external object struct types no longer flagged as invalid arguments
    • Fix DEBUG_END_SESSION not receiving any semantic coloring when used outside of DEBUG() calls
    NOTE: Please make sure you have pnut-term-ts v0.9.23 or later installed per our installation instructions so that pnut-term-ts is correctly found. Also, verify that VSCode found it by checking the Spin2-specific settings.
  • NEWS
    I've just released v2.10.4 of our spin2 extension.
    v2.10.x
    Scope nesting guides for PUB/PRI methods
    • Color-coded scope nesting guides in PUB/PRI method bodies with L-shaped closers at scope end
    • 6-level color cycling per nesting depth; active scope (at cursor) renders brighter
    • Per-theme guide colors for all 5 shipped themes
    • Enable via spinExtension.scopeGuides.enable (off by default)
      -or- enable Spin Extension > Scope Guides from within Settings
    v2.9x
    Spin2 document formatter with tab/space conversion and status bar indicator
    • Spin2 document formatter with section-aware column alignment for CON, VAR, OBJ, DAT blocks, method body indentation, PASM instruction alignment, keyword case normalization, and trailing comment alignment
    • Format-on-save support via spinExtension.formatter.formatOnSave, bypassing VSCode's dispatch to avoid conflicts with other formatters
    • configurationDefaults claiming editor.defaultFormatter for [spin2], and[spin] languages
    • Bidirectional tab/space conversion enforcing the user's whitespace preference
    • "Spin2 Spaces: N" / "Spin2 Prop Tool" / "Spin2 IronSheep" status bar indicator showing active tab/indent settings; click to switch profiles
    • Formatter test suite (1900+ tests) covering binary parity, idempotency, configuration variation, crash resilience, and real-world file validation
    • Formatter is disabled by default; enable via spinExtension.formatter.enable and spinExtension.formatter.formatOnSave
      -or- enable Spin Extension > Formatter and Spin Extension > Format on Save in settings
    This code formatting is, of course, a high-risk activity, since it is a whitespace-indented language. To mitigate this risk, along with the formatter, I developed a deep regression test system (currently 1900+ tests). This is documented in Formatter Regression Testing. Basically, no matter the elastic tabs or spaces layout chosen, the binary must compile identically after formatting; likewise, formatting the file a 2nd time must produce no further changes.
    Special Note: It just makes sense to be careful. Since this is our first release, despite all of the testing I've done, please protect your work on critical projects. Save the binary from your compile, format the file then recompile, if the .bin files are identical then the formatter is working well for your project. If you find any file that fails this test, please let me know immediately, and I'll get fixes in place as soon as we can reproduce the failure.
    I've also provided a User Guide for this formatter.
    Latest Tool Versions:
    • pnut-ts v1.53.2
    • pnut-term-ts v0.9.23
    SPECIAL NOTE: We found issues running pnut-ts and pnut-term-ts (and the other compilers/tools as well), and we reported them in our last release announcement. If you haven't updated your user tasks .json file yet, please do so.
