Structures, am I doing this right?
ke4pjw
Since I am trapped inside for the foreseeable future due to weather, I started looking at using structures.
I save configs in memory with my light controller project as binary chunks of memory. I wanted to make sure I can do the same with structures without complications.
I verified that when an array of structures are instantiated, all of the needed memory gets allocated as a single block, even if no data is assigned. I put together a little test harness to help me understand how the structure is represented in memory. It appears to work and it makes sense.
Working doesn't necessarily mean correct, so I am asking advice on if I am I using structures correctly here? Basically this is a multidimensional array.
{Spin2_v52}
CON ' Constants
_CLKFREQ = 160_000_000
STRUCT nametype(BYTE namefield[32], BYTE unusedextrabyte)
VAR ' Variables
nametype name[24]
byte test
OBJ ' Objects
PUB main()
STRCOPY(@name[0].namefield,@"namefield 1",12)
STRCOPY(@name[1].namefield,@"namefield 2",12)
STRCOPY(@name[2].namefield,@"namefield 3",12)
STRCOPY(@name[3].namefield,@"namefield 4",12)
debug(zstr(@name[0].namefield), uhex(@name[0].namefield))
debug(zstr(@name[1].namefield), uhex(@name[1].namefield))
debug(zstr(@name[2].namefield), uhex(@name[2].namefield))
debug(zstr(@name[3].namefield), uhex(@name[3].namefield))
debug("'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'.")
debug("Total bytes for this sctructure: 33")
debug("24 structures of nametype, named 'name' were instantiated")
debug("Expected bytes: 792 (33*24)")
debug("Measured total size of instantiated 'name' structures: ",udec_(@test-@name), " bytes")
Cog0 INIT $0000_0000 $0000_0000 load Cog0 INIT $0000_0F64 $0000_1BFC jump Cog0 @name[0].namefield = "namefield 1", @name[0].namefield = $18E0 Cog0 @name[1].namefield = "namefield 2", @name[1].namefield = $1901 Cog0 @name[2].namefield = "namefield 3", @name[2].namefield = $1922 Cog0 @name[3].namefield = "namefield 4", @name[3].namefield = $1943 Cog0 'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'. Cog0 Total bytes for this sctructure: 33 Cog0 24 structures of nametype, named 'name' were instantiated Cog0 Expected bytes: 792 (33*24) Cog0 Measured total size of instantiated 'name' structures: 792 bytes
I have been enjoying STRUCTS since their arrival. roughly, yours looks about like I'd use them. but, I am no strong Spin coder.
Guess would be nice if could do sizeof(name[0].namefield) for the STRCOPY bytes. Is there some Spin2 equivalent of that?
Suppose could make the #bytes in namefield a constant and then use that.
Sometimes nice to have things automatically adjusted in case you make changes later to #bytes in things....
I just wanted to make sure the syntax was correct and get an understanding of how it places things in memory.
Man, I SO wish I had this like 4 years ago.
perhaps this is what you're looking for? Been playing with these a bit. seems like a "Pascal String" to me
