Structures, am I doing this right? — Parallax Forums
Since I am trapped inside for the foreseeable future due to weather, I started looking at using structures.
I save configs in memory with my light controller project as binary chunks of memory. I wanted to make sure I can do the same with structures without complications.
I verified that when an array of structures are instantiated, all of the needed memory gets allocated as a single block, even if no data is assigned. I put together a little test harness to help me understand how the structure is represented in memory. It appears to work and it makes sense.
Working doesn't necessarily mean correct, so I am asking advice on if I am I using structures correctly here? Basically this is a multidimensional array.
{Spin2_v52}
CON ' Constants
    _CLKFREQ = 160_000_000
  STRUCT nametype(BYTE namefield[32], BYTE unusedextrabyte)
VAR ' Variables
   nametype name[24]
   byte test
OBJ ' Objects
PUB main()
    STRCOPY(@name[0].namefield,@"namefield 1",12)
    STRCOPY(@name[1].namefield,@"namefield 2",12)
    STRCOPY(@name[2].namefield,@"namefield 3",12)
    STRCOPY(@name[3].namefield,@"namefield 4",12)
    debug(zstr(@name[0].namefield), uhex(@name[0].namefield))
    debug(zstr(@name[1].namefield), uhex(@name[1].namefield))
    debug(zstr(@name[2].namefield), uhex(@name[2].namefield))
    debug(zstr(@name[3].namefield), uhex(@name[3].namefield))
    debug("'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'.")
    debug("Total bytes for this sctructure: 33")
    debug("24 structures of nametype, named 'name' were instantiated")
    debug("Expected bytes: 792 (33*24)")
    debug("Measured total size of instantiated 'name' structures: ",udec_(@test-@name), " bytes")
Cog0  INIT $0000_0000 $0000_0000 load
Cog0  INIT $0000_0F64 $0000_1BFC jump
Cog0  @name[0].namefield = "namefield 1", @name[0].namefield = $18E0
Cog0  @name[1].namefield = "namefield 2", @name[1].namefield = $1901
Cog0  @name[2].namefield = "namefield 3", @name[2].namefield = $1922
Cog0  @name[3].namefield = "namefield 4", @name[3].namefield = $1943
Cog0  'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'.
Cog0  Total bytes for this sctructure: 33
Cog0  24 structures of nametype, named 'name' were instantiated
Cog0  Expected bytes: 792 (33*24)
Cog0  Measured total size of instantiated 'name' structures: 792 bytes
  • I have been enjoying STRUCTS since their arrival. roughly, yours looks about like I'd use them. but, I am no strong Spin coder.
  • RaymanRayman Posts: 16,397
    Guess would be nice if could do sizeof(name[0].namefield) for the STRCOPY bytes. Is there some Spin2 equivalent of that?
    Suppose could make the #bytes in namefield a constant and then use that.
    Sometimes nice to have things automatically adjusted in case you make changes later to #bytes in things....
  • ke4pjwke4pjw Posts: 1,324
    I just wanted to make sure the syntax was correct and get an understanding of how it places things in memory.
    Man, I SO wish I had this like 4 years ago.
    perhaps this is what you're looking for? Been playing with these a bit. seems like a "Pascal String" to me
  • That looks like what we're doing in NAVCOM, more or less, I think you're on the right track.
    The one thing to keep in mind when implementing this kind of data structure is unit testing is important to make sure your memory is doing what you want it to do. So while asking us is great, verifying it with unit tests is better. If you want some guidance for writing test code I'm happy to help when I'm less sick and less busy, just keep harassing me in this thread until I get around to it.
