Structures, am I doing this right? — Parallax Forums
Since I am trapped inside for the foreseeable future due to weather, I started looking at using structures.
I save configs in memory with my light controller project as binary chunks of memory. I wanted to make sure I can do the same with structures without complications.
I verified that when an array of structures are instantiated, all of the needed memory gets allocated as a single block, even if no data is assigned. I put together a little test harness to help me understand how the structure is represented in memory. It appears to work and it makes sense.
Working doesn't necessarily mean correct, so I am asking advice on if I am I using structures correctly here? Basically this is a multidimensional array.
{Spin2_v52}
CON ' Constants
    _CLKFREQ = 160_000_000
  STRUCT nametype(BYTE namefield[32], BYTE unusedextrabyte)
VAR ' Variables
   nametype name[24]
   byte test
OBJ ' Objects
PUB main()
    STRCOPY(@name[0].namefield,@"namefield 1",12)
    STRCOPY(@name[1].namefield,@"namefield 2",12)
    STRCOPY(@name[2].namefield,@"namefield 3",12)
    STRCOPY(@name[3].namefield,@"namefield 4",12)
    debug(zstr(@name[0].namefield), uhex(@name[0].namefield))
    debug(zstr(@name[1].namefield), uhex(@name[1].namefield))
    debug(zstr(@name[2].namefield), uhex(@name[2].namefield))
    debug(zstr(@name[3].namefield), uhex(@name[3].namefield))
    debug("'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'.")
    debug("Total bytes for this sctructure: 33")
    debug("24 structures of nametype, named 'name' were instantiated")
    debug("Expected bytes: 792 (33*24)")
    debug("Measured total size of instantiated 'name' structures: ",udec_(@test-@name), " bytes")
Cog0  INIT $0000_0000 $0000_0000 load
Cog0  INIT $0000_0F64 $0000_1BFC jump
Cog0  @name[0].namefield = "namefield 1", @name[0].namefield = $18E0
Cog0  @name[1].namefield = "namefield 2", @name[1].namefield = $1901
Cog0  @name[2].namefield = "namefield 3", @name[2].namefield = $1922
Cog0  @name[3].namefield = "namefield 4", @name[3].namefield = $1943
Cog0  'nametype' structure is a 32 byte array named 'namefield' + 1 byte named 'unusedextrabyte'.
Cog0  Total bytes for this sctructure: 33
Cog0  24 structures of nametype, named 'name' were instantiated
Cog0  Expected bytes: 792 (33*24)
Cog0  Measured total size of instantiated 'name' structures: 792 bytes
  • I have been enjoying STRUCTS since their arrival. roughly, yours looks about like I'd use them. but, I am no strong Spin coder.
  • RaymanRayman Posts: 16,051
    Guess would be nice if could do sizeof(name[0].namefield) for the STRCOPY bytes. Is there some Spin2 equivalent of that?
    Suppose could make the #bytes in namefield a constant and then use that.
    Sometimes nice to have things automatically adjusted in case you make changes later to #bytes in things....
  • ke4pjwke4pjw Posts: 1,281
    I just wanted to make sure the syntax was correct and get an understanding of how it places things in memory.
    Man, I SO wish I had this like 4 years ago.
    perhaps this is what you're looking for? Been playing with these a bit. seems like a "Pascal String" to me
