Spin Tools IDE - Page 31 — Parallax Forums
Spin Tools IDE
1252627282931»
  • dgatelydgately Posts: 1,643
    @macca said:
    On MacOS, I don't know if it works (sorry, my testing on MacOS is very limited), it certainly needs some more implementations but I think most needs an actual executable instead of a shell script, with all the signature issues this involves.
    Also implemented drag and drop files to the editor, if you have Spin Tools IDE open, drag a source file from a File Exporer (or the corresponding applet on your OS) and drop to the editor area to open it.
    on MacOS, the "Open With" option (Control click on a .spin2 or .spin file) now shows Spin Tools IDE as an available app for opening the file... Yay!
    And, yes dragging & dropping a spin file into the editor panel works! Dropping a spin code file on the Spin Tools IDE icon in the MacOS Dock, works as well!
    Thanks for all the hard work!
    dgately
  • JonnyMacJonnyMac Posts: 9,575
    edited 2026-01-10 01:24
    Found what may be a small "gotcha." If one clicks on a filename in the tree view, the editor tab changes, but the outline pane doesn't switch to it. I have to manually re-sync by selecting another tab and then going back.
    Toggle Outline View does not refresh the contents of the outline.
    1918 x 1038 - 121K
  • maccamacca Posts: 971
    That's great!
    Are the files opened in the same Spin Tools IDE instance or do they open a new instance each time ?
    I ask because on Linux and Windows I had to implement a dedicated handler to open the files in the same IDE instance.
    I see, I'll fix it soon.
    They open in the same instance!
    dgately
  • ke4pjwke4pjw Posts: 1,275
    Thank you so much @macca ! Being able to open spin2 files in Spin-Tools directly from the file Explorer is a godsend. Again, thank you so much!
    If you decide to make a build for Windows on ARM64, let me know. I will happily test for you! I have a Snapdragon Windows machine.
