@macca
1. I update MacOS to 26.2 and the Multi-Line selection of text is still not working.
2. Do you find the issue with complex structs I reported in #869
@wummi said:
@macca
Yes, I found and fixed the issue with your complex structure, I'm going to do a release later today that should also fix the text selection issue (hopefully, can't verify myself).
Apologies if this is already raised. With Spin Tools IDE 0.50.0, I get
when hovering over .sine1, .sine2, .sine3 labels in column one, but not when hovering over label SINE. Here's my code:-
DAT { PASM2 code }
org
SINE
' Fill BUFFER with an i-q sinewave - triggered by ATN
waitatn ' wait for the go-ahead
getct _cyclestart ' mark the start time
rdlong ptrb, ptra[BUFFERPTR] ' set ptrb to point to BUFFER
push ptrb
mov _sigbuffsize, ##sigbuffsize
sub _sigbuffsize, #1
shl _sigbuffsize, #3
add ptrb, _sigbuffsize ' ptrb points to last sample in the BUFFER
rdlong _real, ptrb++
rdlong _imag, ptrb
mov _sampleangle, ##binangle
mov _binangle, _sampleangle
pop ptrb
mov _sigbuffsize, ##sigbuffsize-4 ' make allowance for preload
wrfast #0, ptrb ' set up FIFO for writing to BUFFER
rep @.sine1, #4 ' preload the cordic engine
setq _imag ' for 4 samples
qrotate _real, _binangle ' 4 x 14 = 56, the cordic processing time
add _binangle, _sampleangle
waitx #6 ' pad to be a 14 cycle loop
.sine1
rep @.sine2, _sigbuffsize ' this is a 14 cycle loop
getqx _realresult ' read back result from cordic
getqy _imagresult
wflong _realresult ' write real result into BUFFER
wflong _imagresult ' write imag result into BUFFER
setq _imag ' send another rotate to cordic
add _binangle, _sampleangle ' prepare angle for next sample
.sine2
rep @.sine3, #4 ' read the last 4 results out
getqx _realresult
getqy _imagresult
.sine3
getct _cycles
sub _cycles, _cyclestart ' mark the finish and calculate
debug(UDEC_LONG(_cycles)) ' the execution time (18456 cycles)
jmp #SINE ' and go wait for another cycle via a relative jump
This release updates the SWT library to the latest Eclipse 4.38 release that should fix the MacOS text selection issue.
Some bugfixes, including the complex structure example posted by @wummi, the mouse hover issue above and the parameters range check on some PASM instructions.
Added font selection for the file browser, objects tree and overview panels (all shares the same preference), in Preferences -> General -> Font, the default should be the OS theme default.
For MacOS users, I have updated the Github runners to MacOS-15 becase the previous x86_64 version was deprecated, and in few months the x86_64 runners will be dropped so I won't be able to produce x86_64 Mac builds, hope this doesn't cause any problem.
Other changes:
Update to Eclipse SWT 2025-12 (4.38)
Fixed long-align check on structure members
Added nested structure members suggestions
Fixed structure size update and circular references
Thank you, Marco. The outline is much easier for me to read using Consolas and a slightly bigger size.
A niggly thing... It would be nice if there were more contrast between the icon colors in the object tree. Would it be possible to use the folder icon colors from Propeller Tool? I poked around your GitHub repository and found that those icons are 16x16 PNGs. In the spirit of imagining you saying, "Help me help you" (great line from the movie, Jerry Maguire), I downloaded the object tree icons and made versions that use Propeller Tool colors. They're a bit simpler with less shading, but I think this will help the contrast so that identifying local versus library files will be easier.
Thanks for considering, and thanks, again, for the update. I'm sure I speak for of a lot of forum members when I say that we sincerely appreciate everything you're doing with Spin Tools IDE, and being open to user requests.
I have added your icons, seems good to me:
I'll use them in the object tree only, the file browser still uses the current icons to be consistent. Maybe it would be good to better highlight the spin files, however I would like to keep the color gradient style.
Just for info, I'm using the Fugue Icons from https://p.yusukekamiyamane.com/ there is also the PSD source, however it doesn't import correctly with Gimp (even the latest version 3.x has problems).
No problem -- it's a visual thing for me. Here's an example where better contrast would be helpful.
A bit of a chuckle... in that same post I was going to ask if you could show the file location by hovering over an element in the object tree -- but it's already there!
@macca
DAT { PASM2 code } org SINE ' Fill BUFFER with an i-q sinewave - triggered by ATN waitatn ' wait for the go-ahead getct _cyclestart ' mark the start time rdlong ptrb, ptra[BUFFERPTR] ' set ptrb to point to BUFFER push ptrb mov _sigbuffsize, ##sigbuffsize sub _sigbuffsize, #1 shl _sigbuffsize, #3 add ptrb, _sigbuffsize ' ptrb points to last sample in the BUFFER rdlong _real, ptrb++ rdlong _imag, ptrb mov _sampleangle, ##binangle mov _binangle, _sampleangle pop ptrb mov _sigbuffsize, ##sigbuffsize-4 ' make allowance for preload wrfast #0, ptrb ' set up FIFO for writing to BUFFER rep @.sine1, #4 ' preload the cordic engine setq _imag ' for 4 samples qrotate _real, _binangle ' 4 x 14 = 56, the cordic processing time add _binangle, _sampleangle waitx #6 ' pad to be a 14 cycle loop .sine1 rep @.sine2, _sigbuffsize ' this is a 14 cycle loop getqx _realresult ' read back result from cordic getqy _imagresult wflong _realresult ' write real result into BUFFER wflong _imagresult ' write imag result into BUFFER setq _imag ' send another rotate to cordic qrotate _real, _binangle add _binangle, _sampleangle ' prepare angle for next sample .sine2 rep @.sine3, #4 ' read the last 4 results out getqx _realresult getqy _imagresult wflong _realresult ' write real result into BUFFER wflong _imagresult ' write imag result into BUFFER .sine3 getct _cycles sub _cycles, _cyclestart ' mark the finish and calculate debug(UDEC_LONG(_cycles)) ' the execution time (18456 cycles) jmp #SINE ' and go wait for another cycle via a relative jumpEnjoying using the IDE, however, Bob
Will look at it.
Released version 0.51.0
Other changes:
Full change log:
https://github.com/maccasoft/spin-tools/compare/0.50.0...0.51.0
@macca
Thanks for Vers. 0.51
The Problems with MacOS 26.x text selection and complex structs are fixed.
Thank you!
Excellent!
I agree. Grazie! Grazie! Grazie!
Again, thank you so much for this great tool!
