How am I supposed to use COGINIT in SPIN2 to control multiple cogs in parallel?
************Hello,
I am new to Spin2 and am having enormous difficulty. I am trying to use COGINIT **to turn on different LEDs in each cog, but I can't seem to get it to work. If anyone has the answer to my question, it would be a huge help.
Currently, my code looks like this:
**CON
_clkfreq = 200_000_000
****VAR****
long stack[8*32]
long cogida[8]
PUB main() | i
repeat i from 0 to 7
cogida[i] := coginit(i, @blink, @stack[i*32])
waitms(200)
if cogida[i] < 0
debug("coginit failed for cog", i, " : ", cogida[i], "\n")
repeat
waitms(1000)
PUB blink(pAddr) | mypin
mypin := 56 + cogid() 'LEDs 56 à 63
dirb[mypin] := 1
repeat
pintoggle(mypin)
waitms(300)
ooh and i work on P2X8C4M
Please format code inside ``` codeblocks so we can easily see indentation.
You have a couple of problems.
main
runs in cog 0, but the first thing it does is restart itself with your blink function, so nothing else inmain
runs. Perhaps makemain
only start cogs 1-7 and then call blink itself.Do you need to allocate cog numbers yourself when you can make coginit just use the next free one? Sorry, I'm on my phone and forget the constant you need to pass coginit to make it do this, but it's in the documentation.
You're going to have a bad time trying to flash LEDs on pins 56-63, since they're already used for programming. The biggest symptom you'll probably see is that it interferes with debug output.
For launching Spin2 cogs, you should be using
cogspin
(infact, I don't think@blink
with blink being a PUB/PRI function is even valid syntax??).coginit
is for launching ASM code only (this changed from Spin1!)Then why are you starting with something so obtuse? Learn the basics first, and if you want to prove to yourself that you can run the same code in multiple cogs, do it with two cogs to start with, and do make your code obvious. I copied your code from the forums and it doesn't run -- and it's not worth taking the time to fix. My version of a multi-cog blinker is easier to understand and more flexible than what you're attempting.
When in doubt, keep it simple.
Before deleting the file I looked one more time
This works
Note that pintoggle sets the direction bit for the pin so you don't need to do it manually. With Spin2's pin control commands there is almost no reason to deal with the direction bits directly.
For fun a quad version that uses cogspin and coginit.
