P2 Smart Pin Diagram (Internals)? — Parallax Forums
JonnyMacJonnyMac Posts: 9,810
edited 2025-08-26 16:55 in Propeller 2
A friend reached out asking if I knew of a good diagram detailing the internals of the P2 Smart Pins. I have seen such diagrams mixed into various threads, but can't seem to find them now. My memory -- which could be faulty as I've been working long hours -- tells me that @evanh has produced nice diagrams. If I'm correct, I hope he'll copy them here so that they're easier to find for myself and others. Forgive me if I'm wrong about the diagram creator; whoever you are, your work is appreciated, and I hope you'll post that great work in this thread.
  • https://p2docs.github.io/pin.html#diagram
    Don't remember who originally made that.
    Though @ikskuh at some point wanted to make a nicer SVG version, I recall, but IDK where that idea went.
  • RaymanRayman Posts: 16,352
    Yeah, that was me. Based on @evanh text based drawing, as recall...
    edited 2025-08-27 00:02
    Copies from Ada's docs:
    Copied from Evan's link.
    ***   Guide of where WRPIN config bits are used   ***
    All cogs share the one-per-pin mode config registers.
    WRPIN   {#}D,{#}S   D/# = %AAAA_BBBB_FFF_PPPPPPPPPPPPP_TT_MMMMM_0
                                     ----------------------------------------------------------------- RND
                                    |        :                            COG_DAC (Streamers/Cogs)
                                    |        :          [=============]<----------------------------- cog0
                               Other|        :          [             ]<----------------------------- cog1
                                    |        :          [   DAC bus   ]<----------------------------- cog2
                                    |        :          [   select    ]<----------------------------- cog3
                                    v        :          [             ]<----------------------------- cog4
                           [=============]   : DAC_MODE [             ]<----------------------------- cog5
                           [  Flash DAC  ]<-------------[   (%P...P)  ]<----------------------------- cog6
                           [   Network   ]   :          [    (%TT)    ]<----------------------------- cog7
    [========]             [             ]   :          [  (%MMMMM_0) ]
    [        ]<------------[   (%P...P)  ]   :          [             ]<------------------------------ OUT
    [Physical]             [             ]   :  driveH  [             ]<---------------------------+-- DIR
    [  Even  ]             [             ]<-------------[ Logic Output]                            |
    [  Pin   ]             [  Pin Output ]   :  driveL  [             ] SMART_DAC[============]    |
    [========]      |      [=============]   :          [             ] SMART_OUT[            ]<---
                    |    COMP_DAC|  |Feed    :     |                             [            ]
                    |            |  |back    :     |                             [   Odd #    ]
                    |            v  |        :  OUT|      -1  -2  -3             [  Smartpin  ]
                    |      [=============]   :     |       |   |   |             [ (%MMMMM_0) ]
                    | PinB [  Comparator ]   :     |       v   v   v             [            ]
                  -------->[             ]   :     |    [=============]      A   [            ]
                 |  | PinA [   (%P...P)  ]   :      --->[ Logic Input ]--------->[---o----o---]-------> IN
                 |  +----->[             ]   :          [  (%A_B_F)   ]      B   [  (M == 0)  ]
                 |  |      [  Pin Input  ]------------->[             ]--------->[            ]
                 |  |      [ Sigma-Delta ]   :             ^   ^   ^             [============]
                 |  |      [     ADC     ]   :             |   |   |
                 |  |      [=============]   :            +1  +2  +3
                 |  |        |\              :          [             ]<----------------------------- cog1
                 |  +--------| |O--- Other   :          [   DAC bus   ]<----------------------------- cog2
                 |  |        |/     |        :          [   select    ]<----------------------------- cog3
    [========]   |  |      [             ]   :  driveH  [             ]<---------------------------+-- DIR
    [        ]<------------[             ]<-------------[ Logic Output]                            |
    [Physical]   |  |      [  Pin Output ]   :  driveL  [             ] SMART_DAC[============]    |
    [  Odd   ]   |  |      [             ]<-------------[             ]<---------[            ]    |
    [  Pin   ]   |  |      [=============]   :          [             ] SMART_OUT[            ]<---
                 |  |            |  |back    :     |                             [   Odd #    ]
                 |  | PinB [   (%P...P)  ]   :      --->[ Logic Input ]--------->[---o----o---]-------> IN
                 |    PinA [  Pin Input  ]------------->[             ]--------->[            ]
                           [     ADC     ]   :             |   |   |
                : Custom I/O Pad Ring :      :               : Synthesised Core Logic :
  • evanhevanh Posts: 17,202
    edited 2025-08-27 10:57
    If he's interested in lots of detail then there is also the, mostly complete, schematic of the pad-ring - https://forums.parallax.com/discussion/comment/1494131/#Comment_1494131
    And the sigma-delta ADC schematic is there too - https://forums.parallax.com/discussion/comment/1510744/#Comment_1510744
    PS: I'm digging these up from the old links topic - https://forums.parallax.com/discussion/comment/1479568/#Comment_1479568
