FlexProp: a complete programming system for P2 (and P1) - Page 60 — Parallax Forums
15758606263
  • Could it be that the function __builtin_frac is not implemented although it is in the documentation (c.pdf)? I get an error "unknown identifier _builtin_frac used in function call" when trying to do something like
        _pinstart (pinDrClk, MODE_DRCLK, 1, __builtin_frac(FREQ_DRCLK, CLK_FREQ));
    Do I need to #include something else additionally to "propeller2.h" to make it work?
  • __builtin_frac was supposed to be a builtin keyword to C, but somehow it's missing from the C keywords table. I will fix that in the next release (it's fixed in github now). Thanks for catching this!
    In the meantime you can work around this by defining a function like:
    unsigned myfrac(unsigned a, unsigned b) {
        unsigned r = 0;
        __asm {
            setq a
            qdiv r, b
            getqx r
        return r;
    which should usually expand to the same code as the builtin, at least on P2 (the builtin will also work in some other environments).
  • Christof Eb.Christof Eb. Posts: 1,554
    edited 2025-08-19 10:01
    Hi,
    is there something wrong with _cogstop() ? (version 7.4.1)
    I had crashes with it, while
       __asm {
       cogstop tos
    works.
    Christof
  • @"Christof Eb." said:
    Hi,
       __asm {
       cogstop tos
    works.
    _cogstop is defined with the same inline assembly, so it should generate the exact same code. Do you have an example where it doesn't? (You can always look at the .p2asm file, or the listing file id -l is given). Any details of the context or surrounding code?
  • Just playing around the other day, blinking an LED in its own cog. Cogstop didn't behave as expected, the LED started blinking erratically. This was FlexBasic.
  • @Mickster @"Christof Eb." Do either of you have any examples of these problems? cpustop works in the examples I've tried, so it's not obviously broken. Whatever problem you're having is somehow context dependent, and I don't have enough information to debug it.
  • Another riddle, perhaps related?
    #define TOS PR0
    // scaling: ( cos*10000 -- degrees*10000 )
            TOS= (int)(572957.795130823*acos((1.0*(int)TOS)/10000.0)); // works
    // TOS= (int)(572957.795130823*acos((1.0*TOS)/10000.0)); // did only work for positive arguments
    Why is this (int) before TOS needed?
    I have for cogstop:
    PRIMI(cogstop) { // ( COGnr -- )  stop the cog -- does not work
       _cogstop(TOS);
       _drop();
    PRIMI(cogstop) { // ( COGnr -- ) \ stop the cog
       __asm {
       cogstop tos
       _drop();
  • @"Christof Eb." To answer "why does this work but that not" questions like that, grab the .p2asm file the compiler generates for both versions and run them through a diff tool.
    Yes, I could dive into this question. At the moment I am busy doing other things. I do mostly not understand, how the compiler works or it's floating point library. It's a tool for me. So I would have to invest ???? time.
    My question was on another level. I asked (myself), why this (int) does change anything, as TOS alias PR0 already is a signed int32. In my opinion up to now (allways learning :# ), this (int) should not be necessary.
    Christof
    Oh, naturally it started to work now :D
    const _clkfreq = 280_000_000
    sub for "cog" blink()
       do
         pintoggle(57)
         pausems 200
       loop
    end sub
    sub blinkstub()
      blink()
    end sub
    dim mystack as byte(128)
    var cogid = cpu(blinkstub(), @mystack(0))
    print cogid
    pausems(4000)
    cpustop(cogid)
    Incidentally, this is the example that you provided to demonstrate the need for the stub procedure.
    Was this a temporary thing or a standard requirement?
    Craig
    define TOS PR0
    Most hardware registers are considered to be unsigned integers. In order to treat them as signed you have to explicitly cast them. PR0 to PR7 aren't exactly hardware registers, but they're still treated as such.
    I have for cogstop:
       _cogstop(TOS);
       _drop();
       __asm {
       cogstop tos
       _drop();
    TOS and tos are different identifiers in C, so these codes will do different things.
  • @Mickster The stub is no longer necessary on P2. It is still required on P1 (and will produce an error message in that case).
    Sure enough...tested :+1::)
    edited 2025-08-21 06:54
    define TOS PR0
    Hm, it is most important for my Forth compiler, that PR0...PR7 are sitting in cog ram and I see each cell of this memory space as a "hardware register", as all of them can do maths like a traditional accumulator. This is the way I can share the same registers between assembler in a Spin2 file and C.
    I have for cogstop:
       _cogstop(TOS);
       _drop();
       __asm {
       cogstop tos
       _drop();
    Oh, sorry, of course there is
    // PR0–PR7 are in $1D8–$1DF
    #define tos PR0
    #define TOS PR0
    So after preprocessing, the compiler should see the same thing.
    I will try to provide full/real code later.
  • Perhaps you could modify the text somehow to reflect that it is really
    "extern register unsigned int"
    Global Register variables
    Global variables are normally placed in HUB memory, and local variables in COG memory (registers). The assembly backends permit variables to be declared as extern register, in which case they are placed in COG memory. Such variables cannot be initialized.
    extern register int *interpreter_pc;
    int fetch() {
    return *interpreter_pc++;
    Variables that are explicitly defined as extern register will have whatever type they are declared as, e.g. in
    extern register int *pc;
    has type int * (pointer to int).
    The builtin registers like _OUTA and _PR0 have type unsigned int. But they can be cast to any type you like.
    Ah, thank you for this explanation!
  • I've released FlexProp 7.5.1 both on my Patreon page and on github (see my signature for links). This is mainly a bug fix release, although there are many bug fixes since the last binary release (7.4.2), so it's probably worth updating.
  • Have FlexProp 7.5.1
    It would be really nice if I could :
    CON 'UUT data
        STRUCT UutDat(dispo,v3V3,v1V8,BYTE ArmStat[12],BYTE PICstat[12],BYTE WiMac[13],BYTE BluMac[13],BYTE Rf24,BYTE RfSubG)
    which yells:
    error: syntax error, unexpected identifier `UutStatus', expecting end of line or ','
    There are other ways I could do this, but this would be sooo nice. What am I doing wrong?
  • @"R Baggett" said:
    Have FlexProp 7.5.1
    CON   'UUT data
    which yells:
    Did you remember to start the file with {Spin2_v51}? The STRUCT keyword is only enabled for recent(-ish) versions of Spin2.
  • Thanks! I knew that... Soooo many changes to keep track of...
  • RaymanRayman Posts: 16,315
    @ersmith Couple debug questions...
    First, ZSTR doesn't seem to work like this, should it?
    debug("bitmap read into psram...", ZSTR(pFilename))
    It works words with Spin Tools but gives blanks here...
    Second, in a fairly complex code, it is getting broke when "BRK Debug" is enabled.
    Any clue as to why that would happen?
    It seems like one of the cogs isn't working...
  • evanhevanh Posts: 17,178
    edited 2025-12-27 21:01
    It works [with] Spin Tools but gives blanks here...
    Confirmed:
    Cog0  INIT $0000_0000 $0000_0000 load
    Cog0  INIT $0000_0404 $0000_0000 load
    Cog0  clkfreq = 10_000_000, clkmode = $100_099B
    Cog0  bitmap read into psram...pFilename = ""
    CON
        _xtlfreq = 20_000_000
        _clkfreq = 10_000_000
    PUB  tester()
        debug(udec(clkfreq),uhex(clkmode))
        repeat
    DAT
    pFilename
        byte    "test.bmp",0
    Hmm, doesn't work in Pnut either. I get a garbage string, I must be using it wrong...
  • JonnyMacJonnyMac Posts: 9,808
    edited 2025-12-27 21:33
    I think you need @ to create a pointer for zstr
  • are you using -g or -gbrk switch?
    The former is known to be a bit funny, the latter would be surprising, I'm pretty sure that worked?
    Thank you Jon. Now works in both Flexspin and Pnut.
    -gbrk is used
    Cog0  bitmap read into psram...(&pFilename) = "test.bmp"
    CON
    PUB  tester()
        debug("bitmap read into psram...", ZSTR(@pFilename))
        repeat
    DAT
    pFilename
        byte    "test.bmp",0
    @Wuerfel_21 Using the IDE, so not sure…
  • ahh, that.
    Incorrect hungarian notation tripped me up.
  • ersmithersmith Posts: 6,283
    As others have already mentioned, this depends on how exactly pFilename is defined. It may need a @ before it to work with ZSTR.
    I'd really need more context to try to guess what's wrong. In one of your other posts you mentioned using a conditional debug in assembly (like if_b DEBUG()). The hardware doesn't actually support that, and so it should produce an error in flexprop, but if it somehow gets through it'll do weird things.
