@wummi , I've released v2.4.5 of the Spin2 extension with the updated SerialPort support. You should already be able to update to it. Let's see if this helps!
@wummi my code actually looks for vid/pid of 0403/6015 that’s why the device at 0403/6001 is not recognized as a prop plug. Is that device an official part from parallax?
No this is a cheap Chinese USB-Serial Plug, but PNUT and Spin-Tool has no problem with it.
I think it is no good Idea to look only for vid/pid of 0403/6015.
For me it is good if you look for vid: 0403, because in my projects I only use FTDI USB to Serial Chips.
But this is not the problem, my Plugs with vid/pid of 0403/6015 are also not shown in the Toobar.
See if the two prop plugs are shown in settings as discovered and are available for use.
If you click on the toolbar item for the prop-plug selection, you can select one of the two prop-plugs.
Once you select one, it stays selected when you return to this project.
Lastly, remove (unplug) one of the prop-plugs and open a new project with spin2 code in it. The only prop-plug should be automatically selected for you in this case.
Re: non-official prop plugs: I could add a setting to remove this PID/VID gate. This will allow you to use the other USB Serial when selected, but we don't know if these other devices will handle DTR toggling correctly, as they are untested. Are you sure you'd like this option added?
@wummi, ok, we now understand what's happening!
Please verify the following for me:
they are not available, Toolbar always show:
same with a new project and only one official prop plug.
Yes please add this option, not all self made PCBs use the FT231X USB UART for programming and debug.
And please allow toggling RTS to reset the P2 as an option, when you want to use the FT234XD USB to serial UART interface with
the packaging (3mm x 3mm 12 pin DFN) for smaller PCB designs. The FT234XD has no DTR-Pin, only the RTS-Pin.
@wummi what i don't understand and we need to figure out is why the report says there are two propplugs and why the toolbar says there are none. That's inconsistent and broken. Can you show me what you see in settings:
I'll work on enabling the setting to open up the gate to allow non-propplugs, but I don't know how to predict (code for) the ability to toggle DTR/RTS on these foreign devices.
@Stephen here the initial Devices List
I can add the Device manually
Then the Toolbar changes to
When I click Plug: Not Selected, the Device List is cleared and in Toolbar Plug: N/A is shown.
DTR/RTS select:
In Spin Tools IDE we can select:
Implement like this:
@Stephen, I did some more tests.
My main computer is a Mac Studio M2-MAX with MacOS 15.5.
On this no Prop-Plugs are found.
Now I change to a Macbook M1-PRO with MacOS 15.5.
I install a new VSC, then node.js and pnut_ts.
I copy the project vom the Mac Studio to the Macbook.
ctr-opt-cmd-U shows the same Devices as before.
But no Plugs are shown in the ToolBar.
Same problems on both Macs.
Then I change the VSC Language from German to English, no success.
What next?
Can you disable the automatic generation for the Device-List.
Then I can manuel edit the Device-List and try to select one from this Devices.
When this works, I can try to download to the P2.
@wummi thank you for all of this information. Give me a couple of days to make the setup tweaks.
As an aside, I'm a Mac user as well (Mac Studio M2 Ultra, MacOS Sequoia 15.5), but I don't understand why this is all working for me and not for your Macs.
If you can think of any possible reasons why, I'm all ears ;-)
@Stephen, does the device handling use node.js?
I use newer versions of node.js, vers 22 and vers 23.
But I thought node.js is only required for Pnut.ts.
The Spin2 VSCode extension is written in TypeScript and uses NPM Packages for serialport and other services.
VSCode appears to have its own Node.js environment but doesn't expose it directly to extension authors.
This may be very few users doing this, but I should at least share my testing results ;-)
If you are a Mac user running Apple Silicon and are also using Parallels Desktop to run Windows...
With the release of Spin2 v2.4.5, which includes updated serial port support, the Spin2 extension now works under Windows running in Parallels Desktop.
(The Node Serialport team finally released a build for Darwin-x64+arm64.)
@wummi embarrassingly, I found the problem. Sigh...
My environment has propplugs with attached P2s. They are found correctly.
When I don't have the P2s attached and powered up, they are not found.
This is NOT how I intended this to work.
I'm fixing the detection code now and will release it shortly. I've also added the new vendor-only match and reset controls for FTDI devices.
I'm looking forward to your testing with the new version once it's released.
@Stephen, Spin2 Extension v2.4.6 is working now .
It finds all Prop-Plugs and I can select one in the Toolbar.
But when I try do download a bin-File with shift-control-D i get:
* Task wird im Ordner VSC ausgeführt: "" VSC.bin
zsh:1: permission denied:
* Der Terminalprozess "/bin/zsh '-l', '-c', ' "" VSC.bin'" konnte nicht gestartet werden (Exitcode: 126).
Is an external Loader-program needed?
And where to get one for MacOS on Apple Silicon CPU?
BTW, the Spin-style inline ASM feature of FlexProp confuses the systax highlighting:
I don't know if that can be fixed at all since the code is detected as C and not Spin.
You are right since it's C i can't do anything since the highlighter for spin2 is enabled by the .spin2 file type by VSCode.
If this is a spin2 file compiled by flexspin and this syntax is used I might be able to highlight this syntax correctly.
My goal for the Spin2 extension is to be the first class highlighter for full PNut/PNut_TS syntax
a secondary goal to do much later is add flexspin support for spin2 only.
meanwhile, until the seconday goal is achieved i've added minimal flexspin support which is enabled by a setting.
Users of VSCode get automatic updates, so you all have these updates already!
Here's a recap of what's new:
v2.5.0 # Complete our Spin2 Toolchain Story
This update adds pnut-term-ts use as a downloader when using pnut_ts as a compiler. This now provides us with a debug window support on all platforms.
optionally, a new setting allows pnut-term-ts to be used with the flexspin compiler
NOTE: Please make sure you have pnut-term-ts v0.9.5, or later, installed per our installation instructions so that pnut-term-ts is correctly found. Also, verify that it was found by VSCode by looking in the Spin2-specific settings.
If you see any issues with this new feature, please let us know by filing new issues at our code repo. (or email me directly.)
Upcoming: See follow-on work reported in Change Log. Of course, if you find issues between now and then, I'll try to get to fixing them, too!
Here are highlights of what's new:
v2.6.0 # Major feature additions, code navigation improvements, grammar fixes, and many diagnostic/highlighting corrections
PASM2 Hover Documentation: comprehensive hover help for 362 instructions, conditionals, effects, and streamer constants with context-aware display (AND in DAT shows PASM2 doc, AND in PUB shows Spin2 operator doc)
Include Directory Support: two-tier include directory system (central library paths and per-folder project includes) with auto-discovery, Tree View UI, and compiler -I flag generation
Struct-aware Go to Definition: navigate to struct field declarations through multi-level chains (e.g., pline.a.x)
Hover Type Annotations: all variables, parameters, and return values now show their type (BYTE, WORD, LONG, or struct type) in hover tooltips
New Code Navigation features
Language Version Support
Add v52 support: ENDIANL and ENDIANW methods (reverse-endian value conversion)
Add v52 support: DEBUG_END_SESSION constant for use in DEBUG
Add BACKCOLOR as recognized TERM debug display feed/update parameter
@Stephen, pnut_ts is now running. Thank you for fixing.
I try the USB-Serial report and get:
-------------------------------------------------- USB Libraries on Platforms Test Report for [macOS] -------------------------------------------------- Run : Thursday, May 22, 2025 at 10:32:04 AM Tool : VSCode Spin2 Extension v2.4.5 -------------------------------------------------- Using library [serialport v13.0.0]: -- DEVICE ----- Port: /dev/tty.debug-console Manufacturer: undefined Serial Number: undefined Location ID: undefined Vendor ID: undefined Product ID: undefined -- DEVICE ----- Port: /dev/cu.usbserial-A9M9DV3R Manufacturer: FTDI Serial Number: A9M9DV3R Location ID: 08314000 Vendor ID: 0403 Product ID: 6001 -- DEVICE ----- Port: /dev/cu.usbserial-D30GTX1X Manufacturer: FTDI Serial Number: D30GTX1X Location ID: 08313000 Vendor ID: 0403 Product ID: 6015 - (is PropPlug) -- DEVICE ----- Port: /dev/tty.Bluetooth-Incoming-Port Manufacturer: undefined Serial Number: undefined Location ID: undefined Vendor ID: undefined Product ID: undefined -- DEVICE ----- Port: /dev/cu.usbserial-D30GTX1Y Manufacturer: FTDI Serial Number: D30GTX1Y Location ID: 08320000 Vendor ID: 0403 Product ID: 6015 - (is PropPlug) -------------------------------------------------- -------------------------------------------------- Open device and get P2 Info: [ #1 - /dev/cu.usbserial-D30GTX1X,D30GTX1X ] [ #2 - /dev/cu.usbserial-D30GTX1Y,D30GTX1Y ] Found PropPlug S/N #D30GTX1X at [/dev/cu.usbserial-D30GTX1X] P2: -------------------------------------------------- -------------------------------------------------- VSCode Spin2 Extension by: Iron Sheep Productions, LLCThe PropPlug at A9M9DV3R is not found, this is a FT232R USB UART, you not supported yet.
But in the Toolbar no ProgPlug is shown. Plug:N/A
DTR/RTS select:
if (DTR_Reset_enabled) { await this.setDtr(true); await waitMSec(2); await this.setDtr(false); } if (RTS_Reset_enabled) { await waitMSec(2); await this.setRts(true); await waitMSec(2); await this.setRts(false); }@Stephen, I did some more tests.
What next?
NEWS
@wummi ok, Spin2 Extension updated: Spin2 v2.4.6 should be avail to you now.
Looking forward to hearing of your test results.
@wummi, I'm looking at this along with your highlight/crash issues. More soon.
NEWS
I've just released v2.5.0 of our spin2 extension.
NEWS
I've just released v2.6.0 of our spin2 extension.
New documents have been added to better describe all of our features. Start with this index VSCode Environment - Reading List
If you see any issues with these new features, please let us know by filing new issues at our code repo. (or email me directly.)
