fdserial between two propeller 'flip' modules.; A Reopening - Page 5 — Parallax Forums
1235»
  • bbrienbbrien Posts: 581
    edited 2025-07-16 21:03
    Sorry ,another bad on my part, I should have sent EQ@-B instead . please change the tx and rx pins to rx =5 and tx=6 Also check the download on the schematic it should have a "copy" at the end ,if not then download again. Thanks
  • Christof Eb.Christof Eb. Posts: 1,345
    edited 2025-07-17 09:43
    Oh, @bbrien,
    so once again no thank you but once again another single file and not an archive but needs a special serial and does not compile. And it scans some local knobs, instead of some serial connection to a handbox.
    Your threads seem to be something like a social experiment about the patience and the need of forum members to show off their competence?
    Or just count, how many idiots chime in?
    If this is not meant as a social experiment, then you can take the two archives of my post #121 as they seem to come near your goals.
    And do the steps, that I mentioned there.
    When you have
    • done these steps,
    • said something like thank you,
    • posted a detailed report on the steps,
    • added the necessary condensers according datasheets into you circuit and posted a foto showing them in reality,
      then I might try to help you again.
      Christof
  • MicksterMickster Posts: 2,813
    I don't get it. I'm not exactly a programming wizard but I created a class for fdserial in FlexBasic and without fuss, I was talking to four multi-dropped RP2040s at 921,600 Baud. Nothing to figure out or debug.
    edited 2025-07-18 23:12
    The devices have all of the required capacitors.
    I have already downloaded the two programs that you have modified.
    I have already loaded the devices with the new programs but am having problems with the simulator(red package), may have damaged the processor, waiting for new one. am setting up the big box in the meantime. Will report in a few days. " Thank you"
    2560 x 1920 - 970K
    2560 x 1920 - 1M
    2560 x 1920 - 1M
