Spin Tools IDE - Page 25 — Parallax Forums
Spin Tools IDE
1192021222325»
  • JonnyMacJonnyMac Posts: 9,376
    edited 2025-06-21 18:43
    My mistake, Marco -- I didn't look closely enough to see that "on" was part of a string, not a command. Sorry.
  • ersmithersmith Posts: 6,184
    @Rayman said:
    @macca That looks interesting... The debug terminal thing doesn't work with flexprop, all debug seems to go to same window, so must be some magic to make it work in Spin Tools IDE...
    The debug terminal is one of the few debug windows that does work with flexprop, see for example the flexprop/samples/debug/debug_tex.spin2 example. The magic that all of the IDEs use to redirect output is the backtick TERM command. WIthout that everything just goes to the default serial window.
    (You have to be using one of the flexprop internal terminal emulators for this to work; the external terminal emulators do their own thing and it's up to them how they handle backtick debug commands, but I have yet to see one that parses them :) ).
  • RaymanRayman Posts: 15,364
    Ok @ersmith guess should try that out.
    But don’t really have a problem with either of these gui. It’s just prop tool that doesn’t have an automatic terminal window…
  • wummiwummi Posts: 103
    @macca said:
    Released version 0.48.0
    I tested the new version and all the problems disappeared.
    Now I can compile all my projects and run them all.
    Thank you macca for your work.
    On MacOS I found some GUI issues:
  • maccamacca Posts: 894
    Excellent!
    Yes, white on light-gray isn't much readable... I'll try to fix these issue for the next release.
    edited 2025-06-23 18:21
    I updated my jm_debug_term object to allow the use of arbitrary colors that are available in Spin Tools 0.48.1. Note that when changing the foreground or background you modify color set 0, though it's not likely that a practical app would mix the use of the default color sets with arbitrary colors.
    If we could load the old IBM character font we could have text output like on the early IBM PCs and clones! :D
    Hopefully, @cgracey will add the ability to change the foreground and background colors in PNut. Would also be nice if zstr() worked in the debug terminal window, too.
