Spin Tools IDE - Page 23 — Parallax Forums
Spin Tools IDE
1202123252633
  • @wummi said:
    Hi maca,
    The upload with MacOS 15 is still not running:
    I look at the sources at GitHub and found the problem.
    in "spin-tools/spin-tools/src/com/maccasoft/propeller/devices/SerialComPort.java"
    in function "public void hwreset(Control control, int delay)"
    at line " serialPort.purgePort(SerialPort.PURGE_TXCLEAR | SerialPort.PURGE_RXCLEAR);" is the problem.
    The function "SerialPort.PURGE_TXCLEAR" need 500ms to execute on MacOS 15
    The function "SerialPort.PURGE_RXCLEAR" need not mutch time to execute
    "SerialPort.PURGE_TXCLEAR" is not necessary at this time, you can delete it.
    Uwe
    Is this something that varies for different OS versions ?
    I'm wondering if an "advanced setting" is required, to allow a user to override the TXCLEAR and RXCLEAR settings; hopefully that would allow all current (and future) MacOS variants to operate, without stomping on the settings for other OS users ?
    I remember going through a similar thing when adding the P2 WiFi programming code to the Parallax WiFi module. I can't recall the details, but do remember we had to settle on a compromise delay to suit the masses-which didn't seem obvious from a Windows standpoint, and was tricky for me as I didn't have a Mac at that time!
  • The 500ms Delay is on macOS 15 only.
    I think the TXCLEAR is not necessary at this Place.
    Or we can also change the order, first executive TXCLEAR / RXCLEAR and then toggle DTR to reset the Propeller.
    I think this will run on all Platforms and all macOS Versions.
  • maccamacca Posts: 1,000
    Ahhhh... can't believe it was that... thanks for looking at it.
    I'll do some tests but I don't think it needs any special setting. The TXCLEAR was added just to be safe but at that point the tx buffer is clear anyway.
    RXCLEAR is needed AFTER the reset toggle because when the Propeller is in the reset state the TX pin may float and the PC side may receive garbage preventing the upload to work correctly. This is mostly necessary for P1 that has a bit "weird" upload protocol, the P2 is bit more immune (if I'm not wrong, recent Edge boards have a pull-up on the RX/TX pins) but still better clear the input buffer anyway.
    The TXCLEAR may be issued before the reset toggle, but I don't think it is necessary.
    I'll do a new release tomorrow so I can fix an issue with the Raspberry Pi OS that I forgot to fix (actually I tought I have fixed sometime ago...).
  • I do some more Tests:
    1. DTR=ON --> DTR=OFF --> RXCLEAR --> TXCLEAR : do not work
    2. RXCLEAR --> TXCLEAR -> DTR=ON --> DTR=OFF : do work. First Reset Pulse is 1000ms long after open the Port, all next are short.
    3. DTR=ON --> RXCLEAR --> TXCLEAR --> DTR=OFF : do work. First Reset Pulse is 1000ms long after open the Port, all next are 500ms long.
    4. DTR=ON --> DTR=OFF --> RXCLEAR : do work. First Reset Pulse is 500ms long after open the Port, all next are short.
    5. DTR=ON --> RXCLEAR --> DTR=OFF : do work. First Reset Pulse is 500ms long after open the Port, all next are short.
    You can use #2 to #5, and I think this will also work on Windows and Linux.
    Uwe
    Released version 0.47.1
    • Removed PURGE_TXCLEAR, not needed and causes lags on MacOS 15
    • Fixed empty pull-down menu crash on Raspberry Pi OS
  • Great, thank you Macca.
    MacOS 15 can upload to Propeller 2.
    in Terminal, switch to the Monitor and TAQOZ runs now.
    Tools/Show Devices works.
    I found some more Compiler Errors, and will report this next Week.
    Uwe
  • Hi Macca,
    None of my current SPIN2 Projects can compiled with Version 0.47.1
    The next two programs shows the Errors.
    PNUT v51.1 compiles this without Errors.
    {TestSpinTools.spin2}
    {Spin2_v51}
    CON ' Constants
        _CLKFREQ = 160_000_000
        struct sTOPIC ( Str, Meth, Mem, crc )
        ADR = 0 addbits 19
    VAR ' Variables
        sTOPIC Topic                'topic is used
        ^sTOPIC pTopic              'pointer to struct not recognized
        long Meth
    OBJ ' Objects
        o1: "TestObj"
    PUB start() | halt, ^o1.sLIST x 'x ist used
        Topic.Str.[ADR] := @"/1/2"  'Bitfields on struct members not working
        halt := taskhlt             'taskhlt : Register which holds the HALT bits (in reverse order) {Spin2_v47}
        [x] := o1.start()
        x.Part[0].adr := @"Uwe"     'struct not recognized
        if [x] and Meth             'Error ??????
            'bla,bla,bla
    {TestObj.spin2}
    {Spin2_v51}
    CON ' Constants
        struct sPART ( long adr, byte len )
        struct sLIST(byte len, sPART Part[10])
    VAR ' Variables
        sLIST List
    PUB start(): ^sLIST Result
        return @List
    Tested 0.47.1 on macOS 15.3.2...
    Definitely better uploading to the P2. Even when I got a few "cant find a P2" dialogs, a press of the reset button and retry works!
    dgately
    Released version 0.47.2
    Bugfix release for the reported issues:
    • Added missing TASKHLT register / constant
    • Fixed exceptions from structure compiler
    • Implemented missing structure member bitfield
    • Fixed local var object structure pointer token marker
    • Fixed structure pointer pre/post increment/decrement and arguments
  • Hi Macca,
    All my current SPIN2 Projects can now compiled with Version 0.47.2
    But the compiled code is so buggy that non of my programs are running.
    PNUT v51.a can compile it and all the programs are running.
    Sorry, I give up with Spin Tools and wait for PNUT-TS for MacOS.
    The code snippet you posted above generates the exact same binary as PNut, I always use PNut binary as a reference and make sure that it generate the same code, however it is possible that some path don't generate the same code for some reasons, especially if you are heavily using the new features like structure and pointers with that weird and confusing syntax, if you want to share a code snippet that compiles but doesn't work as expected I can look at it and fix the issues. If you want I can also look at your whole verbatim source (privately if you can't share it, I can assure you that I'll not disclose it to anyone else).
  • evanhevanh Posts: 17,084
    @wummi said:
    ... wait for PNUT-TS for MacOS.
    Helping Macca would be more productive than just sitting around waiting.
  • Ok, I can try to find the problems and isolate them.
    And yes, I use the new features like structure and pointers extensive.
  • I found 3 more compile errors and which line the program crashes.
    After you find this Errors, I will test it with my programs.
    maybe there are more errors.
    {Spin2_v51}
    CON ' Constants
        struct sTOPIC ( Str, byte pos, byte key[1] )
    VAR ' Variables
        sTOPIC Topic[4]
    PUB start() | i, x
        Topic[1].key[0] := 55
        CompileErrors(@Topic[1])
        repeat 4 with i
            x := @Topic[i].Str              'this Line crashes the program
            debug(uhex(x))
            debug("loop ", sdec(i))
        debug("loop End")
    PRI CompileErrors ( adr ): ^sTOPIC p | x
        [p] := adr
        'x := p.key[p.pos++]         'compile Error
        x := p.key[p.pos]           'Workaround in two lines
        p.pos++                     '<-----
        debug(sdec(x), uhex([p]))   'Error x = 55
        '[p]~~                       'compile Error
        '[p]~                        'compile Error
        if [p] \ 0                  'Workaround but not working
            debug(uhex([p]))        'this line is not executing, but shoud be
        debug("End CompileErrors")
  • Just found a small "gotcha." I changed the font size for the editor and it seemed like the editor then mixed fonts.
    I ended up closing and re-opening the file to get everything tidy again.
    Released version 0.47.3
    Another bugfix release for the reported issues mainly on pointer usage.
    Took a lot of time to sort out all the syntax and it isn't yet 100% fixed, the reported snippets all compile binary exact as PNut, so I hope there are some less-used cases to fix.
    Some fixes requires more deep changes in the compiler structure so will take more time.
    Known issues so far:
    • Address of the pointer variable @[ptr] is not working (compile error)
    • Pointer pre-inc/dec inside an index like buffer[[++]ptr] doesn't cause errors but the increment is applied to the pointed value and not to the pointer, the post-inc/dec however buffer[ptr[++]] works (need a deep compiler change to fix).
    Changes:
    • More pointers / struct operations fixes
    • Fixed editor font change notification
  • Hi macca, i tested the new Vers. and found 1 Compile Error and 1 Runtime Error.
    Here the Test-Prog.
    {Spin2_v51}
    CON ' Constants
    VAR ' Variables
        sTOPIC Topic[4]
    PUB start()
        CompileErrors1(@Topic[1])   'Runtime Error
        CompileErrors2(@Topic[1])   'Runtime Error
        CompileErrors3(@Topic[1])   'Runtime Error
        CompileErrors4(@Topic[1])   'no Runtime Error
        Topic~                      'Compile Error
    PRI CompileErrors1 ( adr ): ^sTOPIC p | x 'local Var x is decl but not used
        [p] := adr
        debug("L17 ",uhex([p]))
        if [p]~
            debug("L19 ",uhex([p]))         'this line is not executing, but shoud be
        debug("End CompileErrors1")
    PRI CompileErrors2 ( adr ): ^sTOPIC p   'no local Vars
        [p] := adr
        debug("L24 ",uhex([p]))
        if [p]~
            debug("L26 ",uhex([p]))         'this line is now executing, but [p] shoud be 0
        debug("End CompileErrors2")
    PRI CompileErrors3 ( adr ) | ^sTOPIC p  'p is now a local Var
        [p] := adr
        debug("L31 ",uhex([p]))
        if [p]~
            debug("L33 ",uhex([p]))         'this line is not executing, but shoud be
        debug("End CompileErrors3")
    PRI CompileErrors4 ( adr )              'no Runtime Errors
        debug("L37 ",uhex(adr))
        if adr~
            debug("L39 ",uhex(adr))         'OK
        debug("End CompileErrors4")
  • @macca
    Just downloaded spin tools again. Got the following error please see attached. Sent same to your website.
    Martin
    1747 x 1020 - 152K
    1546 x 1191 - 328K
    2.jpg 152.5K
    1.jpg 328.2K
    One of the files opened in the editor has an extension other than .spin .spin2 or .c ?
    Because seems that it opened an unknow file (the editor should prevent that but for some reasons it failed).
  • @macca
    How do I fix this.
    This occurs when I double click on the icon to open the ide.
    Right, delete the preferences file .spin-tools (note the leading dot) in the user's home directory.
    Alternatively, open the .spin-tools file and delete the "openTabs" property (if you are familiar with json file format) but may be better to delete the file.
    Released version 0.47.4
    Another bunch of bugfixes for pointers and other things I discovered in the meantime.
    Hope that pointers are done with these fixes.
    • Fixed address of pointer variables @[ptr]
    • Fixed pointer pre/post-inc/dec operators parsing (also fixes the buffer[[++]ptr] syntax)
    • Use optimized bytecode for packed characters constants %"1234"
    • Fixed debug stack calculation with structures
    • Fixed hot keys ALT+num to launch external tools
    • PASM: Fixed case-sensitive effect check
    • PASM: Relative jump instructions cleanup, fixed long-immediate offset
    • PASM: Fixed calld instruction variants selection
    • PASM: Fixed asmclk expanded instructions conditions
  • Thanks, Marco!
  • JonnyMacJonnyMac Posts: 9,693
    edited 2025-05-15 03:53
    One of the things I appreciate about Propeller Tool is the color-coded folder icons. Could we have that in Spin Tools? It's helpful on big projects where I use libraries that are local and in my master library folder. Yellow indicates a local file, blue indicates something in another folder. So it looks something like this:
    320 x 590 - 1M
  • Found a small gotcha: The error indicator at the very top of the strip allows hover (and shows the error), but clicking results in an error dialog.
    Would it be possible to add the line # of the error to the hover hint?
  • @macca
    Howdy, I deleted the .spin-tools file. This is also after downloading your newest version of 0.47.4. Got the same error.
    Not familiar with the json format. Got the same error. Any other suggestions?
    It does appear to work even after I "ok" out the error message.
    Yes, I think it can be done, I have a small number of color variants (two actually, the current white-ish and a blue-ish alternative), here how it may look :
    I think the left image may be better, need to also change the icons in the file explorer to be consistent.
    Forgot to tell, make sure you exited the program before deleting the file or it will be recreated.
    It if works, you should have a tab with the incriminated file open, you may just close that tab and it should not appear again.
    Anyway, I would like to know what file caused that error, AFAIK it should be a file without a known extension (.spin .spin2 or .c) but I don't know how it was opened, the editor should prevent that.
    I tried but can't reproduce, can you show the details ? It should report the exact error and location in the source.
    Yes, I'll add it.
  • I think the left image may be better, need to also change the icons in the file explorer to be consistent.
    If it matters, I prefer the image on the right where the external files (not in the project folder) are shown in blue. And I don't think you need to change the file explorer.
    I tried to reproduce, too, but couldn't -- even if I created errors on the first and last lines of code. If an error pops up again I'll open the dialog and post the details.
    Yes, I'll add it.
    Thank you.
    Any chance you're going to the race at Imola this weekend? :)
