Console Emulation - Page 68 — Parallax Forums
Console Emulation
1656668707176
  • RaymanRayman Posts: 15,880
    edited 2024-11-22 21:58
    Changed this line in NeoVGA and appear to have changed clock freq to 350 MHz:
    VIDEO_CLKFREQ = 350_000_000 'MASTER_CLK*CLK_MULTIPLIER
    Monitor says 61.4 Hz refresh
    Gone a bit with no errors. Think this means that MisoYume should work.
    Hmm. Won't do 355 MHz. Not 100% sure if it's the monitor or the P2 giving up...
  • @Rayman Yea you can change the frequency like that, but the video will go faster. i guess most monitors should sync up to 70Hz, so that should be fine. Your monitor should say something like "OUT OF RANGE" if it isn't taking the video signal.
    With those dummy cogs running, it's way more stressful than NeoYume. Try it on one of those older boards. They just can't handle it at all. Also, the memory test is exacting. A single bit error anywhere will trip it, whereas the actual emulator can often shake it off.
    Tested again today and did eventually fail (no fan).
    Board was pretty warm though.
    Think fan would fix it...
    2016 x 1512 - 679K
    Tried with Vdd = 1.9 V. Works at 338 MHz, but not 350 MHz...
    MisoYume runs for a few seconds at Vdd=1.9, but then crashes...
  • New finding: Running MXX board off a 12V wall brick results in VBUS = 4.99V. A lot better.
    Probably more interesting would be how this affects the RAM VIO rail.
    Still need to measure a bunch of different boards and power methods.
  • Despite the better VBUS voltage, the overall stability seems to be reduced running from the 12V supply. Very strange failure modes.
  • To illustrate:
    Like what?
  • Might be a noiser power supply brick somehow coupling through to the VIO rails of the P2 or other PSRAM signals. You could scope it to see different amounts of noise on the voltage rails with different supplies, although it's not that that accurate and hard to find transients unless it's grossly different from other supplies or you have a good high bandwidth scope.
    edited 2024-11-27 22:04
    This makes me like the idea USB-C power more and more...
    Is the 12V used for anything there? If needed, guess need a USB-C PD chip for that...
    I think this is the core giving out though, notice how there's ERRs and OKs outside of the intended grid. I've also had hard crashes and other screen corruptions happen.
  • To belabour the point:
  • Back to USB input and suddenly it works again
  • Or maybe not
    I feel like I may have cooked the board too much.
  • evanhevanh Posts: 16,968
    This is the point where I would wire up the oscilloscope to get some sanity back.
  • Wuerfel_21Wuerfel_21 Posts: 5,739
    edited 2025-02-11 16:08
    FYI, building NeoYume on latest flexspin is busted, if you get something cool like
    neoyume_upper.p2asm:2126: error: ## is not legal with loc
    neoyume_upper.p2asm:2164: error: ## is not legal with loc
    downgrade to a 6.x.x version
  • .. and it turns out MegaYume was also broken (due to default FCache size changing), but I fixed that one on my end.
  • ersmithersmith Posts: 6,228
    edited 2025-02-11 16:47
    I think that error message is legit: loc pb, #any_addr is legal, but why would you ever want loc pb, ##any_addr (which would insert a superflous ALTS)?
    EDIT: ah, I see, it's the compiler generating that. That is wrong, yes, I'll try to get it fixed soon.
    edited 2025-02-12 00:20
    @ersmith thanks for fixing it so quickly.
    Now I can get to what I actually wanted to do, which is finally fix the analog video code in the new video driver.
    As mentioned earlier it's missing serrated sync and interlacing still, so it's only mainlined in NeoYume. Except I just noticed that when I connect it to my actual TV, it really flips out and doesn't show a stable image at all (EDIT: after another try it does, but the video is too far down the tube). Very interesting.
    EDIT 2: okay I think I isolated two issues: VSYNC is too long (should only be 3 lines, but the old driver counted its serration pulses towards sync, so I had 9 sync lines), causing video too far down the screen. Also something is wrong with PAL mode that causes the picture to shake violently. (EDIT 3: Apparently that's my TV's reaction to the "PA" in PAL getting out of sync. Quick fix!)
    edited 2025-02-12 00:43
    Finally, interlaced sync for the new video driver. Currently code is clunky. Need to shuffle around a bit so native res YPbPr also uses this (and test it!).
    EDIT: Also the RetroScaler seems to not like the signal much - need to check what the old code did different
  • roglohrogloh Posts: 6,205
    Yeah getting the sync combo's perfected can be tricky. I still need to finish adding interlaced to my own driver's VGA mode, which is only partly done as I needed to free some space for it by more overlay use. The other interlaced analog modes should already work. Are you planning interlaced for HDMI? I think that needs extra pixel doubling (so pixel quadrupling in 320x240 modes).
  • No, for HDMI I'm just bobbing the image to "convert" interlace to progressive, same as 480p VGA. (The VDP emulation scanline-renders natively interlaced video when in high-res mode!)
    Generally I don't think there's much point to 480i over HDMI... And the next standard resolution is 1920x1080i, which is too much.
    Yeah for "proper" HDMI from the P2 we are probably kinda stuck to doing progressive 640 and 720 wide screens IMO with software pixel doubling halving that resolution on screen. DVI is a bit more forgiving and allows a bit more leeway.
  • You can do actually-wide 854x480 just fine, too.
  • I have infact somehow fixed the interlace timing, by doing something that I swear didn't work before but now does. Cool. Interesting how the CRT TV does not care that much (even though it's a late-era one that ends up going through a full ADC->memory->DAC thing). I always wondered if you could do a "720i" signal where there are 3 fields per frame instead of 2 and have it work on standard TVs. Maybe something to try one of those days.
    edited 2025-02-12 18:40
    Ok, I think I finally fixed EVERYTHING. Interlaced sync, NTSC/PAL, composite/svideo/ypbpr, correct scanline counting, etc.
    The only missing piece is how serrated sync should look like on RGBHV/VGA (for composite sync it's obviously just the same as the NTSC sync pattern). I guess it ought to maintain the property that CSync = HSync XOR VSync. Doesn't help that I have nothing that takes 15kHz RGBHV (except the VisionRGB card). Didn't @Rayman have an arcade monitor laying around?
    EDIT: actually, fixing the line counter for megayume broke it for neoyume. cool. I think it never worked properly to begin with, so maybe time to fix it properly? EDIT 2: YES YES YES
  • ColeyColey Posts: 1,130
    Hey @Wuerfel_21
    I want to get my P2 back up and running now that I'm redesigning the P2 Arc8de cabinets, what hardware do I need to get these emulators up and running, is P2 Edge Module with 32MB sufficient?
    One of the things I want to try this with is a 9.7 inch iPad screen with HDMI control board that I'm thinking of using in the new cab.
    Coley
    edited 2025-02-14 12:08
    @Coley Yes, EC32MB is good. Very stable, non-fussy board. Just make sure you give it enough juice and don't let it overheat. The NeoGeo emulator is limited in game compatibility by the smaller RAM size (see https://github.com/irqsome/neoyume?tab=readme-ov-file#game-compatibility ), but otherwise it's great.
    Other notes:
    • Always read the README.MD and other .MD files
    • At some point I re-wrote the video code (mainly to add HDMI audio, but this also added more flexible resolution support). This is currently only mainlined in NeoYume (though that should change soon), for the other projects you may need to check the video-nextgen branch (where available) to get the dev version with the new video code.
    • Make sure your LCD can actually re-scale the image in a non-awful way; the HDMI output is fixed to 480p. With the newer video code, you can choose the active width to match the display aspect ratio (old code is fixed to 800x480...)
    • I only ever test USB controls. If you want to connect buttons directly to pins, the option for it is there, but you may need to complain if it doesn't work.
    • All the repositories are here:
    • There are a few other projects that need to be brought up to speed, such as the P2 Spin Hexagon port. I also have a few unfinished ports of P1 classics to P2 laying around.
    • There currently isn't an IRQsome-approved "bootloader/IPL" type program to allow selection of multiple programs installed at once. @pik33 had one, but I never tested it.
  • pik33pik33 Posts: 2,416
    edited 2025-02-14 13:21
    https://gitlab.com/pik33/P2-retromachine/-/tree/main/Propeller/microdos
    https://forums.parallax.com/discussion/174645/microdos-a-simple-loader-for-psram-based-system-now-with-usb-keyboard/p1
    However I don't know if the code from the repository actually works as I didn't do anything with it for a long time. The main reason for it is the Basic interpreter that I have flashed. Its "brun" command loads and runs P2 binaries from SD card files so I have the loader ready and can do
    cd /neoyume
    brun neoyume.bin
    The command code in the interpreter looks like this:
    sub do_brun
    dim t1 as expr_result
    dim pos,r,psramptr as integer
    dim filename, fullfilename as string
    t1=pop()
    if t1.result_type=result_string2 then t1.result.sresult=convertstring(t1.result.uresult): t1.result_type=result_string
    if t1.result_type=result_string then
      filename=t1.result.sresult
      if left$(filename,1)="/" then
        fullfilename=filename
      else
        fullfilename="/sd/bin/"+filename
      endif
      open fullfilename for input as #9
      r=geterr() : if r then print "System error ";r;": ";strerror$(r) :close #9 : return
      let pos=1: let r=0 : let psramptr=0
      do
        get #9,pos,block(0),1024,r : pos+=r
        psram.write(varptr(block(0)),psramptr,1024)
        psramptr+=r                                     ' move the buffer to the RAM and update RAM position. Todo: this can be done all at once
      loop until r<>1024  orelse psramptr>=$7C000                           ' do until eof or memory full
      cpustop(audiocog)                                 ' stop all driver cogs except PSRAM
      cpustop(videocog)
      cpustop(usbcog)
      cpustop(housekeeper_cog)
      let loadingcog=cpu(@loadcog,@pslock)                          ' start loading cog
      cpustop(cpuid())                                  ' stop itself
      endif
    end sub
    It gets parameters from the interpreter's stack and then copies the file to the PSRAM. After this, it stops all cogs except PSRAM driver and inits the loader.
    The loader code:
    '' ------------------------------- the loader cog for BRUN
            asm shared
                    org
    loadcog         cogid   t11                     ' get a cogid
                    mul     t11, #12                        ' compute the offset to PSRAM mailbox
                    add     mailbox, t11                     ' add offset to find this COG's mailbox
                    mov     psramaddr,#0
    p101            mov     buf1,psramaddr          ' psramaddr=hubaddr
                    mov     buf2,##16384            ' loading size
                    mov     cmd,psramaddr                   ' set the address for reading
                    setnib  cmd, #%1011, #7                 ' attach the command - read burst
                    setq    #2              ' write 3 longs to the mailbox
                    wrlong  cmd, mailbox            ' read the PSRAM
    p102            rdlong  cmd, mailbox                    ' poll mailbox for result
                    tjs     cmd, #p102                  ' retry until valid
                    add     psramaddr,##16384
            cmp     psramaddr,##$7C000 wcz
        if_lt   jmp     #p101               ' loop until full hub loaded
                    cogstop #7              ' stop psram driver
                    cogid   t11             ' get id
                    coginit #0,#0               ' start the new program
                    cogstop t11             ' stop the loader
    t11         long    0
    mailbox     long    $7FF00
    psramaddr   long    0
    pslockval   long    0
    cmd             long    0
    buf1            long    0
    buf2            long    16384
            end asm
    is simple. It loads the binary from the PSRAM to the memory. However, the PSRAM driver had to be patched to do this, so its mailbox always starts at $7FF00. This makes conflicts with the BRK debug, but it's almost useless in FlexBasic. However I added a #define DEBUG in the current version of the patched drive (and have yet to do the same in the interpreter code)
  • @pik33 Thanks for posting it. I think you could do the loader part in inline ASM. That wouldn't really be a benefit, just a thought.
    I just added a README to the misoyume github and am re-doing some compatibility testing.
    Interesting finding: In Breath of Fire 2, there's a sort of cloud/fog effect that uses pseudo-hires mode and color math. It looked odd to me and bsnes-plus (possibly old branch) and Mesen2 render it differently. But guess what, someone has a playthrough captured from real hardware on YT and it matches what MisoYume does. I guess that means I really have understood the pixel pipeline.
  • I also just released MegaYume V1.4-RC1
    Changes since the 1.3 tag are similar to NeoYume 1.4:
    • New video driver with HDMI audio (and other improvements!), same as NeoYume
    • Improved audio due to PWM DAC mode
    • Menu cursor position is now remembered
    • Change to in-house IESLv1 license
    • Remove some old cruft from project directory
    • Minor fixes
    Current versions of NeoYume and MegaYume have also been posted to OBEX (now as ZIP files)!
    That's one item off the TODO list...
    That now means the HDMI Audio enablement progress is as follows
    • MegaYume: done, mainlined
    • NeoYume: done, mainlined
    • MisoYume: no work done yet (need to adapt driver for 512x224 video)
    • Tempest 2000: video-nextgen branch (need to adapt driver to restore widescreen modes)
    • Spin Hexagon: blocked (uses @rogloh video driver)
