Console Emulation - Page 61 — Parallax Forums
Console Emulation
1585961636476
  • Wuerfel_21Wuerfel_21 Posts: 5,851
    edited 2024-09-08 23:14
    @rogloh said:
    @Wuerfel_21 said:
    It's not like I need to look at more than a few packets. They all seem to come out just fine.
    Did you end up capturing the actual data to solve the issue you found (couldn't exactly tell by your 2nd post if you did), or did you figure it out by examining the logic of the decoder software etc...?
    I added a DEBUG line next to the WRLUT that writes the encoded data. Then i wrote a script to convert that to binary data and fed it into your program.
    Looks something like this (I think this is the regen test branch, after the fix):
    Decoding TMDS bits on 10b triplets per int:
        sample   bits      Type                             Red(ch2)    Green(ch1)  Blue(ch0)       Clock
             1     10 :->  TERC4 0001_0000_0010 +V  H-      1001100011  1010011100  1011100100      0000011111
             2     10 :->  TERC4 0001_0001_1110 +V  H-      1001100011  1001100011  0101100011      0000011111
             3     10 :->  TERC4 0000_0001_1010 +V  H-      1010011100  1001100011  0110011100      0000011111
             4     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
             5     10 :->  TERC4 0000_0001_1010 +V  H-      1010011100  1001100011  0110011100      0000011111
             6     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
             7     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
             8     10 :->  TERC4 0000_0001_1110 +V  H-      1010011100  1001100011  0101100011      0000011111
             9     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            10     10 :->  TERC4 0001_0000_1110 +V  H-      1001100011  1010011100  0101100011      0000011111
            11     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            12     10 :->  TERC4 0001_0000_1010 +V  H-      1001100011  1010011100  0110011100      0000011111
            13     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            14     10 :->  TERC4 0001_0000_1010 +V  H-      1001100011  1010011100  0110011100      0000011111
            15     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            16     10 :->  TERC4 0001_0000_1010 +V  H-      1001100011  1010011100  0110011100      0000011111
            17     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            18     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            19     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            20     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            21     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            22     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            23     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            24     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            25     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            26     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            27     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            28     10 :->  TERC4 0000_0000_1010 +V  H-      1010011100  1010011100  0110011100      0000011111
            29     10 :->  TERC4 0000_0001_1010 +V  H-      1010011100  1001100011  0110011100      0000011111
            30     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            31     10 :->  TERC4 0000_0000_1110 +V  H-      1010011100  1010011100  0101100011      0000011111
            32     10 :->  TERC4 0000_0001_1110 +V  H-      1010011100  1001100011  0101100011      0000011111
    TERC4 Packet Decoded:
    Pkthdr:           0D0282  ECC=E4  ComputedECC=E4
    Subpkt0:  0000008888411E  ECC=41  ComputedECC=41
    Subpkt1:  00000000000000  ECC=00  ComputedECC=00
    Subpkt2:  00000000000000  ECC=00  ComputedECC=00
    Subpkt3:  00000000000000  ECC=00  ComputedECC=00
    Video Infoframe packet
      Version:2
      Length :13
      Chksum :1E
      Data: (LSB First) 41 88 88 00 00 00 00 00 00 00 00 00 00
            33     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
            34     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            35     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            36     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            37     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            38     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            39     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            40     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            41     10 :->  TERC4 0000_1111_1001 V-  +H      1010011100  1011000011  0100111001      0000011111
            42     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            43     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            44     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            45     10 :->  TERC4 0000_1111_1001 V-  +H      1010011100  1011000011  0100111001      0000011111
            46     10 :->  TERC4 1111_1111_1001 V-  +H      1011000011  1011000011  0100111001      0000011111
            47     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            48     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            49     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            50     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            51     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            52     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            53     10 :->  TERC4 0000_1111_1001 V-  +H      1010011100  1011000011  0100111001      0000011111
            54     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            55     10 :->  TERC4 0000_1111_1001 V-  +H      1010011100  1011000011  0100111001      0000011111
            56     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            57     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            58     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
            59     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            60     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
            61     10 :->  TERC4 1111_0000_1001 V-  +H      1011000011  1010011100  0100111001      0000011111
            62     10 :->  TERC4 1111_1111_1001 V-  +H      1011000011  1011000011  0100111001      0000011111
            63     10 :->  TERC4 1111_1111_1101 V-  +H      1011000011  1011000011  1001110001      0000011111
            64     10 :->  TERC4 1111_1111_1001 V-  +H      1011000011  1011000011  0100111001      0000011111
    Pkthdr:           000001  ECC=4A  ComputedECC=4A
    Subpkt0:  001900AD890000  ECC=FE  ComputedECC=FE
    Subpkt1:  001900AD890000  ECC=FE  ComputedECC=FE
    Subpkt2:  001900AD890000  ECC=FE  ComputedECC=FE
    Subpkt3:  001900AD890000  ECC=FE  ComputedECC=FE
    Clock regen packet
      SubPkt0    N = 6400     CTS = 35245
      SubPkt1    N = 6400     CTS = 35245
      SubPkt2    N = 6400     CTS = 35245
      SubPkt3    N = 6400     CTS = 35245
            65     10 :->  TERC4 0000_0000_1111 +V  +H      1010011100  1010011100  1011000011      0000011111
            66     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            67     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            68     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            69     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            70     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            71     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            72     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            73     10 :->  TERC4 0000_1111_1011 +V  +H      1010011100  1011000011  1011000110      0000011111
            74     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            75     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            76     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            77     10 :->  TERC4 0000_1111_1011 +V  +H      1010011100  1011000011  1011000110      0000011111
            78     10 :->  TERC4 1111_1111_1011 +V  +H      1011000011  1011000011  1011000110      0000011111
            79     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            80     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            81     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            82     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            83     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            84     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            85     10 :->  TERC4 0000_1111_1011 +V  +H      1010011100  1011000011  1011000110      0000011111
            86     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            87     10 :->  TERC4 0000_1111_1011 +V  +H      1010011100  1011000011  1011000110      0000011111
            88     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            89     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            90     10 :->  TERC4 0000_0000_1111 +V  +H      1010011100  1010011100  1011000011      0000011111
            91     10 :->  TERC4 0000_0000_1011 +V  +H      1010011100  1010011100  1011000110      0000011111
            92     10 :->  TERC4 0000_0000_1111 +V  +H      1010011100  1010011100  1011000011      0000011111
            93     10 :->  TERC4 1111_0000_1011 +V  +H      1011000011  1010011100  1011000110      0000011111
            94     10 :->  TERC4 1111_1111_1011 +V  +H      1011000011  1011000011  1011000110      0000011111
            95     10 :->  TERC4 1111_1111_1111 +V  +H      1011000011  1011000011  1011000011      0000011111
            96     10 :->  TERC4 1111_1111_1011 +V  +H      1011000011  1011000011  1011000110      0000011111
    Clock regen packet
            97     10 :->  TERC4 0000_0000_0001 V-  +H      1010011100  1010011100  1001100011      0000011111
            98     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
            99     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           100     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           101     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           102     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           103     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           104     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           105     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           106     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           107     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           108     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           109     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           110     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           111     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           112     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           113     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           114     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           115     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           116     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           117     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           118     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           119     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           120     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           121     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           122     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           123     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           124     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           125     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           126     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           127     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           128     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
    Pkthdr:           000000  ECC=00  ComputedECC=00
    Subpkt0:  00000000000000  ECC=00  ComputedECC=00
           129     10 :->  TERC4 0000_0000_0001 V-  +H      1010011100  1010011100  1001100011      0000011111
           130     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
           131     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           132     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           133     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           134     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           135     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           136     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           137     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
           138     10 :->  TERC4 0000_0000_1101 V-  +H      1010011100  1010011100  1001110001      0000011111
           139     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           140     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           141     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           142     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           143     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           144     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           145     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           146     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           147     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           148     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           149     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           150     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           151     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           152     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           153     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           154     10 :->  TERC4 0010_0010_1001 V-  +H      1011100100  1011100100  0100111001      0000011111
           155     10 :->  TERC4 0000_0000_1001 V-  +H      1010011100  1010011100  0100111001      0000011111
           156     10 :->  TERC4 0010_0010_1001 V-  +H      1011100100  1011100100  0100111001      0000011111
           157     10 :->  TERC4 0010_0000_1001 V-  +H      1011100100  1010011100  0100111001      0000011111
           158     10 :->  TERC4 0000_0010_1001 V-  +H      1010011100  1011100100  0100111001      0000011111
           159     10 :->  TERC4 0010_0010_1001 V-  +H      1011100100  1011100100  0100111001      0000011111
           160     10 :->  TERC4 0010_0010_1101 V-  +H      1011100100  1011100100  1001110001      0000011111
    Pkthdr:           000302  ECC=80  ComputedECC=80
    Subpkt1:  CC000000000000  ECC=F6  ComputedECC=F6
    Audio packet
      Sample 0  right = 000000, left = 000000, flags=00  Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=0
      Sample 1  right = 000000, left = 000000, flags=CC  Pr=1 Cr=1, Pl=1 Cl=1 ParityR=0 ParityL=0 Channel status count=1
    Channel status also seems to read OK (very far into the file).
    Also, attached my hastily 64 bit fixed version of your program.
    c
    c
    15K
    tm.c 14.6K
  • roglohrogloh Posts: 6,385
    edited 2024-09-09 01:04
    Ugg, still same RGB colors with your latest build and this one line change to NeoVGA.spin2. Are you sure this is the correct bit pattern for the YUV change?
    ' mov packet_data0,##%1_000_10_00___10_00_1000___0_10_0_00_01 << 8'
    EDIT: YUV select bit position seems okay but I just read this:
    "When the IT content bit is set to 1 and the Graphics type is indicated, downstream processors should pass Pixel Data unfiltered and without analog reconstruction."
    You seem to be setting this bit and graphics type is 00 in data byte 5 if that is zeroed. So it may be preventing the conversion into YUV. I'll try to set this IT bit to 0 to see if that helps.
    EDIT2: Nope no help. Still same RGB colours being presented.
    EDIT3: Also tested on the projector and it didn't switch into YUV mode either.
  • Can you build vgatest with listing enabled(-l)? Just to make sure we're actually running the same thing.
    edited 2024-09-09 07:28
    Ok, do you want the listing file posted somehow?
    Which file do you want? I modified the ./build.sh to add -l to each step.
  • Yea, just attach it
    edited 2024-09-09 07:33
    Here were the output files...
    Actually I just built that with MODE_DVI_VGA , because I was messing with that, but normally I do set it to HDMI. I will update the above in a sec. Done.
  • Here's the vgatest listing file too. Sorry did full NeoYume first.
  • ??? Yeah this is what I wanted(?) to see, random 1 bit difference in output.
  • What the hell is that?
  • I think that's the branch offset for the callpa being off by one. How does that happen?
  • Different compiler version? I'm using:
    Version 7.0.0-beta-v6.9.7-31-g7643e936 Compiled on: May 18 2024
  • I've got Version 7.0.0-alpha-v6.9.7-52-gada40c8f Compiled on: Jul 2 2024 or Version 6.9.8-HEAD-v6.9.8 Compiled on: Aug 7 2024
    Though if your machine has 32 bit longs, this might also be one of our favorite platform dependent oopsies.
  • No this is a newer 64 bit machine, MacMini M2 Pro
  • Maybe I should take another full clean update from your regen branch to make sure it is fully up to date? I've mainly been updating NeoVGA.spin2 and vgatest.spin2 in the last two days since they seem to be the only files you are committing recently. Will do that and then re-diff the listing files of both builds of vgatest.spin2 locally.
    edited 2024-09-09 08:03
    No, only difference in the build is this single line which is the YUV change vs fresh tree. Ugh can't format it nicely.
    ❯ diff vgatest.lst ../NeoYume-hdmi-clock-regen-test
    2347,2348c2347,2348
    < 01a00 00 44 44 FF
    < 01a04 00 69 07 F6 | mov packet_data0,##%1_000_10_00___10_00_1000___0_00_0_00_01 << 8
    01a00 20 44 44 FF
    01a04 00 69 07 F6 | mov packet_data0,##%1_000_10_00___10_00_1000___0_10_0_00_01 << 8
  • Update flexspin. Bug was fixed in b08d41bee0581a7b0b2a67eb36e27f746b371b21
  • Okay, pulled in latest spin2cpp and made flexspin again:
    Version 7.0.0-beta-v6.9.7-65-g3914edfd Compiled on: Sep 9 2024
    Here's the listing of vgatest.lst with the YUV change back in.
    lst.zip 28.6K
  • Yes, code now matches.
    edited 2024-09-09 08:16
    Ok, this is what the YUV change seems to be showing on the plasma. EDIT: Still no audio though disappointingly.
  • Yea that's about right for that.
    Can you try the plain video-nextgen branch again? That has a lot more of those CALLPAs
    Yeah that branch also works in the video test, without audio. Here it is running in RGB mode this time.
  • Well that's back to square one.
  • It also works okay in YUV mode on the next-gen branch when I patched that in just now.
  • Try this (in either branch, but the regen test one has a slightly higher chance of working ig):
    Add this just before call #util_infoframe_chksum
                ' HACK: No, actually do an Audio Infoframe
                mov packet_header,##$0A_01_84
                mov packet_data0,##%00000000___0000_00_00___0000_0_001 << 8
    Apparently most of the values need to be zero, anyways.
    edited 2024-09-09 08:45
    I've made progress in the capture to PSRAM code but seem to be having a problem with the IO pins and the streamer. For some reason I can't seem to read back the upper nibble of the HDMI pins with the streamer (with or without readback remapping). Just coded it all up today and its not working correctly if I read the HDMI pins but at one point it seemed to sample pins ok if I chose another uncommitted IO nibble on pins 0..3 which has some incrementing numbers being written to them as a test pattern, so I know the overall capture logic should be working. I also modified your NeoVGA code to ensure it only setup the Repo mode mailbox on the bottom pin of the 8 pin group (DIGITAL_BASEPIN) in case that had any effect, no help.
    I'm starting to wonder if you can't read back correctly the input pin states of pins being streamed to in another COG and I'm trying to remember what @cgracey said about this.
    Hacked code attached. You might have more luck than me @Wuerfel_21 . It's very close to working IMO. Right now it messes with P0-P3 so disable that spew() routine if you have boards fitted on those pins.
    Serial port console controls capture @115200.
    Enter starts capture - it automatically stops after 2MB is captured to PSRAM.
    Space reads a screenful of nibble data from the capture start buffer and increments read address by 64 samples.
    ESC resets read pointer back to 0 in PSRAM
    Obviously still needs a file writer to SD or bulk upload of data to serial port.
  • You probably want to use these modes:
        TMDS_DRIVE_MODE = P_REPOSITORY|P_OE|P_LOW_FAST|P_HIGH_FAST|P_SYNC_IO
        TMDS_DRIVE_MODE2 = P_LOW_FAST|P_HIGH_FAST|P_SYNC_IO
    (I think P_OE is nonsense in non-smart modes?)
  • Tried. Didn't help. Something weird is going on, maybe with the streamer or FIFO, can't tell.
    Did you run this yet?
    Hadn't but just tried it now. No improvement on sound on Plasma. :(
