Visual Studio Code supports P2 development on Windows, Mac, Linux (yes, RPi) - Page 8 — Parallax Forums
1234568
    Stephen,
    Just read your development over the past 18 months.
    What you have achieved is nothing short of remarkable.
    Congratulations!
  • @Cluso99 said:
    Congratulations!
    Thank you! It's been fun to work on.
  • @jrullan said:
    @"Stephen Moraco" ,
    I haven't revisited my P2 programs for almost a year now, but recently I wanted to do check on the code and after updating the extensions in VSC, I suddenly have lots of syntax errors, mostly on object methods, in a code that compiles ok. I tested in latest version of Spin Tools for comparison and it doesn't show any syntax errors there. I am using the latest version of flexspin as compiler. Did I miss some change I need to do with the new version of the Spin2 extension? Here's a screenshot for reference:
    Thanks Stephen!!!
    2.2.16 fixed my issue in Windows:
  • Stephen MoracoStephen Moraco Posts: 384
    edited 2024-04-15 00:13
    @"Stephen Moraco" said:
    @jrullan said:
    I haven't revisited my P2 programs for almost a year now, ..... Did I miss some change I need to do with the new version of the Spin2 extension?
    For those of you reading this. I could not identify the cause but could not recreate the issue with the v2.2.15 as I was working on it before release. I then reviewed all the code, found and fixed 3 more issues I was able to find, and then pushed the new release.
    Ok, I worked with @jrullan and found a defect in the handling of files on windows that was causing all of the object references to not be found.
    I've just release v2.2.16 to address this issue.
    Here's what's new in v2.2.16
    v2.2.16
    Update P2 Only
    • BUGFIX: Syntax: add missing bytefit/wordfit recognition in DAT blocks (#6)
    • BUGFIX: Semantic: repair handling of {Spin2_v??} built-in method name support
    • BUGFIX: File access issues on Windows (11?) repaired
    • Cleaned up the code-fold detection... now handling ORG* forms better (#6)
    • Adjusted report key chords for Windows:
      • Ctrl+Win+r - Generate Object Hierarchy Report
      • Ctrl+Win+d - Generate OBject Public Interface Report
      • Ctrl+Win+c - (When cursor on PUB or PRI line) Insert Doc comment below the PUB or PRI line
    If you see any issues with these new features please let us know by filing new issues at our code repo. (or email me directly.)
    edited 2024-12-12 00:29
    NEWS
    I've just released version 2.3.0 of our spin2 extension. This is the first cut of a new compiler-independent build system.
    Users of VSCode get automatic updates, so you all have these updates already!
    Here's a recap of what's new in v2.2.17, v2.2.18, and v2.3.0
    v2.2.18
    • Quick repackage and release to pull cruft out of distribution package (oops!)
    v2.2.17
    Update P2 Only
    • BUGFIX: parsing repair detection of alignl/alignw in VAR. Issue(#9)
    Update P1 and P2
    • BUGFIX: FlexSpin support: implement new understanding. #include includes spin code but no longer needs spin/spin2 file extension. Issue(#11)
    • BUGFIX: FlexSpin support: fix highlighting for #include lines
    v2.3.0
    This update improves/simplifies the ability to compile and download code for Spin2 projects
    • NEW Automatic Toolchain discovery (paths for FlexProp, PNut, and pnut_ts are now automatically determined)
    • NEW Automatic PropPlug discovery
    • NEW statusBar control for switching between compile with debug() and without
    • NEW statusBar control for switching between download to FLASH / RAM
    • NEW statusBar control for selecting amongst available USB-attached PropPlugs
    • NEW Setting to select preferred compiler for all projects
    • NEW This setting can be overridden for each specific workspace (project)
    • NEW Setting to enable all this new spin2 toolchain support (disabled by default)
    • NEW Replacement User Tasks file is now universal (all supported compilers)
    NOTE This release uses loadp2 from the flexspin installation to download code compiled by pnut_ts.
    General Repairs
    • BUGFIX Repair crash when system-settings documents are open at startup
    • BUGFIX Spin2 Semantic Highlighting: fixed VAR section index coloring
    Plan a time when you want to move to this new build support. Leave yourself an hour or two so you can do this setup carefully. Once set up, this will be fun to use!
    Help with migration to this new mechanism is found at Migrate to v2.3.0 checklist with additional info found at Build System Notes.
    This is our first release of this new build system. Please be sensitive to things being different. My goal is to make building and downloading much more simple than it previously was. But, since it is the first release, If you see any issues with these new features, please let us know by filing new issues at our code repo. (or email me directly.)
    Upcoming With this finally being released, we can now move to adding highlighting support for Spin2 V45, v46, and v47... language features.
  • NEWS
    I've just released v2.3.1 followed by v2.3.2 of our spin2 extension. These fix the compiler detection code, in general, and additionally, path chasing on Windows.
    Here's a recap of what's new:
    v2.3.1 and v2.3.2
    • Repair parsing of PATH on windows and how expected location paths are created
    • Present Error if multiple installations are found for a given tool
    • Reduce search to unique paths (no dupes from PATH values)
    • Extension logging is enabled for now to help us diagnose new-user installations (it will be turned off once again in a later release)
    I'll add a section on "How to verify the compiler search by using the newly exposed log" to our "Build System Notes" shortly...
  • NEWS
    I've just released v2.3.4 of our spin2 extension.
    v2.3.4
    Bugfixes and Spin2 Lanugage support upgrades
    • Repair parser crashes #17
    • Prevent some toolChain-related actions when toolChain support is not enabled #16
    • Add language support for Spin2 v44, v45, v46, and v47 (Except highlighting of new structure types.)
    Upcoming: The new types created with structure support are not yet highlighted. This is up next along with v48, v49, v50, etc. support.
  • NEWS
    I've just released v2.4.0 of our spin2 extension.
    Well, normally, Users of VSCode get automatic updates, but I'm not able to publish this before my trip to Rocklin!
    However, I've attached the .vsix file to the Release Page (See: Assets)so you can download it right away if you don't want to wait until next week.
    v2.4.0
    Spin2 Language support upgrade through Spin2_v51
    • Add language support for {Spin2_v48}, through {Spin2_v51}
    • Highlight new STRUCT types
    • BUGFIX: corrected Syntax coloring of smart-pin constant 'P_REG_UP_DOWN' constant (spelled badly in prior versions)
    Upcoming: I've got a small list of things i want to complete relative to this work... so there should be another point release with more pretty highlighting in the next two weeks or so. Of course, if you find issues between now and then I'll try to get to fixing them, too!
  • NEWS
    I've just released v2.4.1 of our spin2 extension.
    v2.4.1
    Spin2 Language upgrades
    • Highlight %"...." packed character constants as numeric constants
    • BUGFIX: dial-in various coloring faux pas - small corner cases fixed
    Upcoming: Enable preprocessor highlight support found in v48. Of course, if you find issues between now and then I'll try to get to fixing them, too!
  • NEWS
    I've just released v2.4.2 of our spin2 extension.
    v2.4.2
    • Add preprocessor highlight support (preprocessor added in v48)
    • Add highlighting of escape sequences within escaped strings (added in v50)
    • BUGFIX: repair some missed coloring of object overrides
    • BUGFIX: repair missed coloring within some types of debug() statements
    Upcoming: See follow-on work reported in Change Log. Of course, if you find issues between now and then, I'll try to get to fixing them, too!
  • wummiwummi Posts: 108
    Hi Stephen,
    I working with MacOS 15 and installed pnut_ts.
    I can use pnut_ts in the terminal and ist works.
    I want to start the compiler in VSC, I install the spinExtension Version 2.4.2 and generate task.json from Doku: TASKS-User-macOS.md
    When ist i type command/shift/B and compileTopP2 I get the Error: command 'spinExtension.getCompArguments' not found
    Where can i define "getCompArguments" and what are the Arguments?
    Where can I define "getCompArguments" and what are the Arguments?
    OK, great question! I somehow left older values in the tasks.json file content.
    The value spinExtension.getCompArguments should be spinExtension.getCompilerArguments.
    Make this change, and it should work much better for you.
    I'm updating the repository doc's as I'm posting this!
  • Just gonna post it here instead of going through the issue templare rigmarole.
    Opening the mikogpu.spin2 file from my Tempest 2000 source port reliably crashes the LSP: https://github.com/Wuerfel21/tempest2k/blob/video-nextgen/src/mikogpu.spin2
    with this tasteful error message
    TypeError: Cannot read properties of undefined (reading 'length')
        at We.appendLastLine (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:55:27296)
        at Ws._parseText (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:97:4459)
        at Ws.reportDocumentSemanticTokens (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:97:766)
        at Li._parseDocument (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:106:10601)
        at Li.process (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:106:9457)
        at async Mi.handleOpenTextDocument (/home/ada/.vscode-oss/extensions/ironsheepproductionsllc.spin2-2.4.2/server/out/server.js:106:11178)
    Ah yes, line twenty-seven thousand, two hundred and ninety-six. That one.
  • (Maybe errors should be cought on some level to stop the entire server coming down from one malformed file)
  • @Wuerfel_21 said:
    Just gonna post it here instead of going through the issue templare rigmarole…
    Keep letting me know of these. It’s been code weaknesses that’s crashing. Insufficient defenses.
    Every time i find a new class of these i wipe them all out.
    I get a fix out hopefully tomorrow.
    If i can find a means to not crash the server i’ll put it in place. No luck so far.
    Thanks Stephen, VSC now find the pnut_ts and compiles my Projects.
    But VSC do not find the PropPlugs and can't download the .bin files under MacOS 15.
    Is there a build in P2-Loader or need I an external Programm?
  • I'm also noticing a bunch of inexplicable errors in this one: https://github.com/IRQsome/MisoYume/blob/master/padmap_parser.spin2
    I think the parser is confused by the attribute on parse_rule
    Hi Stephen, I found 2 compiler Errors and some syntax highlighting Errors.
    In SPIN V49 CON STRUCT declarations are now exported to parent objects.
    The highlighter is confused with the exported structs.
    References to structs in objects also confused the highlighter.
    Here are a short Prog that shows the compiler Errors:
    {Spin2_v51}
        #define testing             'compile Err: VSC.spin2:2:error:Expected "," or end of line
    CON struct sFG1 ( byte A, byte B[3])
    VAR sFG1 FG1[8]
    PUB start ( ) | i, adr
        repeat 8 with i
            XYZ(-i)             'compile Err: VSC.spin2:12:error:NumberStack: attempted pop from empty stack
            adr :=  @FG1[i].A   'A is decl.
    #ifdef testing
            debug(uhex(adr))
    #endif
    PRI XYZ ( val )
        debug(sdec(val))
    Thank you for reporting this! I'll get this fixed and also add this to our regression suite!
    edited 2025-05-18 21:46
    @wummi can you please show me the PUB/PRI signature for XYZ() (I'll test with the same that you are using.)
    AUGH! Nevermind. The example you provided has what I was missing below the edge of the visible part of the window. I found it when I scrolled!
  • @wummi, both highlighter problems are fixed and will appear in the next release, hopefully, later today. (Found control structure problems in the colorizer)
    edited 2025-05-18 20:59
    @Wuerfel_21, that's a good example! You were correct in the parser being confused by the directive; it's fixed.
    Also, I found an incomplete parser for local variables; it's fixed.
    There was also some incomplete case-statement parsing (caused by multiple "..." strings on the same line), which has also been fixed.
    These fixes will appear in the next release, hopefully, later today.
    edited 2025-05-18 21:15
    @Wuerfel_21 said:
    Just gonna post it here ...
    Ok. Yep, that was a good find. There is only one instance of this type of failure in the entire extension code base. I found and fixed it. Fix will appear in the next release, which I'm wrapping up now.
    FWIW, you reported this in the way that best helps me find and fix these rapidly. That is, you provided the source that was causing the crash. When I rebuild the extension in a manner that facilitates debugging, I actually do get an excellent indication of exactly where in the source and which method call in the line of source is causing the failure. This means I can get a precise understanding of the cause and get an accurate fix in place. Thank you for reporting this the way you did!
    Good morning Stephen,
    I found more highlighter problems.
    In your Programm flash_fs.spin2 in Line 308 ins one.
    The Pin2 Extension on MacOS 15 don't find any PropPlug, so I can't download the binary's to the P2.
    The PropPlugs are ok and SpinTools can find them and download can be done under MacOS 15.
    What can I do to fix this, or is an external P2Loader necessary?
    More highlighter problems in this code:
    {Spin2_v51}
    VAR sFG1 FG1[8]
        repeat 8 with i
            adr :=  @FG1[i].A   'OK now
            XYZ(@FG1[i].A)      'more hightligting Errors
            FG1[i].A++
            ++FG1[i].A          'pre inc works
            FG1[i].A += 3
            FG1[i].A -= 3
            FG1[i].B[1]--
            --FG1[i].B[1]       'pre dec works
            FG1[i].B[1]~
            FG1[i].B[1]~~
    #ifdef testing
            debug(uhex(adr))
    #endif
    PRI XYZ ( val )
        debug(sdec(val))
  • @wummi I fixed the highlighter problems in this 2nd report, and released a fix to the pnut-ts compiler (your first report)
    • Released Spin2 v2.4.4 - pushed a new release for us all.
    • Released PNut_TS v1.51.2 with the fixes you reported. I filed Issue #8 for you, citing the problems, and posted a new release.
    edited 2025-05-20 06:22
    I have to check, you probably already did this... ;-) Did you enable the new toolchain support?
    What symptoms are you seeing that the prop plug is not being found?
    When you have a .spin2 file open in the current editor window, do you see the new statusbar controls?
    VSCode Spin2 StatusBar
    (sorry, I had no idea that image would be so "in our face" ;-)
    Hi Stephen,
    I do enable Advanced toolchain features.
    But no Prop Plug: Devices Found
    Enter the associated Serial Number manualy don't work.
    Toolbar:
    The usb devices in dev:
    I have an LA at P2 Pin 62, 63 and RES, and all are hight all the time.
    i habe a look at usb.serial.ts and found that you only accept an FTDI FT231X.
    I use most FT232R USB UART: Produkt-ID: 6001.
    But when I plug in an FT231X USB UART: Produkt-ID: 6015, it is also not found.
    In usb.serial.ts Line 78: const ports = await SerialPort.list(); you get a list of ports.
    Can you log the ports, and we can see where the problems are?
    As a former (retired) HP employee, we had a term, "Excellent Question," which was asked in meetings where we already had an answer. ;-)
    This is one of those. Yes I can do two things. There is a newer version of the underlying UsbSerial package I'm using. I can upgrade to that hoping there is better device support, and secondly i already have a built-in report you can activate showing which devices are being seen. I will update that report to show PID/VID if it doesn't already, so it can also help us diagnose.
    Go to settings keybindings, look for how to activate "Generate USB Findings Report," and see if that tells you anything currently.
    I'll release an update with the newer UsbSerial as soon as I prove it still works in my test environment.
