P2 - SD Boot Code (rev 2 silicon)
Cluso99
Update 16-Jan-2021: fix "_BOOT_P2.BIX" & "_BOOT_P2.BIY" was "BOOT_P2.BIX" & "BOOT_P2.BIY"
Thought I would start a new thread for the docs I just sent Chip in case there are suggestions/questions (to the docs, not the code).
The Monitor/Debugger will be in a separate thread.
P2 BOOT PROCESS
After power-up or hardware reset, the P2 loads 16KB of P2 Boot Code from an internal serial ROM into the top 16KB of HUB RAM ($FC000-$FFFFF) ?? or maybe slightly less ??
COG #0 then executes this “booter program code”. This code has been published, and contains the following code sections:
• Boot code (ROM_Booter.spin2):
This code sets RC FAST ??? clock mode and then tests for external pullup and/or pulldown resistors on Pins P59, P60 & P61 (see table). This code uses the resistor settings to determine which section of code will execute next.
• Serial code with autobaud:
This section waits for the two character sequence “> “ on the serial input pin P63, and utilised this sequence to determine the current baud, and sets the SmartPins for Asynchronous Serial mode (P63 input & P62 output). Timeouts to try FLASH or SD ???
• FLASH Boot Code:
This code uses P61=#CS, P60=CLK, P59=DI(out), P58=DO(in).
Note: these pins are shared with the SD Card if present.
?? Description of checksum/load/run sequence ??
• SD Card Boot Code:
This code uses P61=CLK, P60=#CS, P59=DI(out), P58=DO(in).
Note: these pins are shared with the FLASH if present.
The conditions for SD booting are described in more detail below.
• Monitor/Debug Code:
This code provides a Monitor and a number of support routines for debugging COG/LUT/HUB memory.
This code can be called in a number of ways…
o From the Boot code with the sequence ?? “ >Ctl-D”
o From TAQOZ with “Ctl-D” ?? Does this still work ??
o From the user’s program. These routines execute in HUBEXEC mode using COG register space $1E0-$1EF for parameters and variables. The Monitor and its’ routines can be called as subroutines from the user’s program.
The Monitor/Debug operation is described in more detail below.
• TAQOZ:
This code provides a standalone Forth test environment for the P2.
o From the Monitor/Debugger prompt by the 2 character sequence “Ctl-D<cr>”.
TAQOZ is described in more detail below.
SD Boot Code
Provided a pull-up is sensed on P61=#CS (provided by the SD Card itself) and the other conditions are met, then the Booter code will pass control to the SD Boot Code. The SD code performs the following steps…
• Initialise the SD Card (in SPI mode). This is often referred to as “Mounting” the card.
• If successful, read the MBR Sector $0000_0000 (512 bytes) into HUB RAM starting at HUB $00000.
• Check if the 4 signature bytes at MBR offset $17C (now in HUB) contain “Prop” ($706F7250). If valid, then the MBR sector now residing at HUB $00000-$001FF (128 longs) is copied into COG RAM $000 and then a JMP $020 is executed. This has the effect of COG #0 executing the code loaded from the MBR starting at byte offset $080. Note the whole 512 byte (128 longs) sector is loaded into COG, so while the code starts at $080 (COG $020), this code can use code below this address if that code is valid and executable. Note that certain parts of the MBR are required by FAT32, etc. Any P2 code written into the MBR must maintain any required fields that the SD card format requires.
• If the MBR does not contain “Prop” at $17C, then this location is checked for the signature “ProP” ($506F7250). If this is found, then $174 (4 bytes) is used as the raw SD Sector to start loading from, and $178 (4 bytes) is used as the length (in bytes). The program then reads code from the card beginning at the start sector for the length into HUB RAM beginning at HUB $00000. Upon completion of the load, 496 longs from HUB $00000 are copied into COG $0 and a JMP #$000 is executed to run the loaded code in COG.
• If the MBR does not contain either signature, then the MBR is validated as follows:
o $1BE[16] is the Ptn0 Table
o $1BE+0[1] AND $7F must equal $00
o $1BE+4[1] must be $0C or $0B
o $1BE+8[4] is used as the Vol_Begin sector
o $1BE+C[4] is used at the Ptn Size
o $1FE[2] must be $55AA
If these checks are met, then continue, else go back to Serial boot code.
• The VOL sector is now read into HUB $00000, and it is checked for the signature “Prop” or “ProP” at offset $17C. If either is found, then the operation will continue the same as described above for the signature found in the MBR sector.
• If the VOL does not contain either signature, then the VOL is validated as follows:
o $00B[2] must be 512
o $00D[1] is used at the clustershift
o $00E[1] used to calculate FAT begin
o $010[1] must be 2 (number of FAT tables)
o $020[4] used to calculate PTN size (not checked)
o $024[4] used to calculate DIR begin
o $030[2] used to calculate FSI begin
• The FSI sector is read and validated as follows:
o $000[4] must be $RRaA
o $1E4[4] must be $rrAa
• The FAT DIRectory is now searched for the file “_BOOT_P2.BIX”. If it is found, it is read into HUB $00000 for a maximum length of (512-16)*1024 which is 512-16KB such that it will not overwrite the top 16KB of HUB RAM. Then the first 496 longs will be copied into COG $000 and a JMP #$000 will execute.
WARNING: This file must be contiguous on the SD Card! This is not checked!!
• If the above file is not found, then the FAT DIRectory is searched for the file “_BOOT_P2.BIY”. If it is found, then it will be read and executed in the same process as the previous step.
• If neither file is found, the code returns to the Serial boot code.
Cluso99
Why the option to boot from the MBR or VOL sectors?
If the card is not formatted with FAT32 (eg exFAT) then the boot code is unable to search the DIRectory to find a file. This is limited because of ROM space and the exFAT license from Microsoft). To overcome this limitation, the MBR is used to store either
* P2 boot code (max 512 bytes = 128 longs)
* Raw SD sector start and Length in bytes (trimmed max 496KB).
The first option loads this sector (512 bytes = 128 longs) into COG at $000 and jumps to COG $020 (ie offset byte $080 in the sector data). Formatting on SD requires the use of some of this space on MBR/VOL. The middle section seems to be available on most (all?) unformatted/formatted SD cards these days. This is the best option for future proofing the P2 ROM SD boot code. Anything on this sector that is free can be used - you are only limited to the code start being at byte $080, and the signature "Prop" at bytes $17C-$17F. The code stored here could be a tiny booter that uses the SD ROM routines in HUB to load more code at fixed locations, or to support exFAT and locate a file. It's use is entirely up to you.
This second option uses the signature "Prop" at bytes $17C-$17F, plus a sector start pointer at bytes $174-$177 and a length at bytes $178-$17B. The max length is trimmed to 496KB in order to not overwrite the top 16KB in HUB that currently stores the ROM Boot Code, and which is actually doing this loading. The sector(s) used must be contiguous as no checks are done. This sector+length may be a pointer to a file residing on the SD, or it could be in the reserved sectors, or even in its' own partition. It's all up to you. Again, this provides the most flexibility into the future.
FAT32 Files
If the SD card is formatted with FAT32, then the boot code looks for the files "_BOOT_P2.BIX" and if not found, then "_BOOT_P2.BIY". Note the uppercase. If either of these are found, then they will be read into HUB starting at $00000, for the length of the file which is trimmed to a maximum of 496KB to prevent overwriting the HUB ROM code currently executing. Note the file sectors must be contiguous as no checks are done.
SD Cards
SD, SDHC and SDXC cards are supported in the boot code. BUT you should use the later SDHC or SDXC cards that use sector addressing as sectors which permits cards up to 1TB. The older SD and SDHC cards used sector addressing in bytes which limited their maximum to 2GB or 4GB? (seem to think they were limited to 31 bits). They haven't been produced in many years.
Note: I will be releasing an SD Driver shortly for use in a separate COG and it will not support these older SD cards. I should have removed it from the ROM to save some valuable space. Ain't hindsight wonderful
Using the SD ROM Routines
Firstly, note that there is no Write routine as it was removed due to limited ROM space.
These routines may be called to Initialise (mount) the card, read the CSD/CID, read a sector(s), search the DIRectory for a filename, and optionally read that file into your designated HUB location. These routines require the use of COG $1C0-$1DF for variables.
WARNING: There are code differences between Rev 1 silicon and Rev 2 silicon !!!
DAT ''################################################################################################ ''## SD Card - HUBEXEC code... ## ''################################################################################################ fc560 orgh '+-------[ SD: Initialise/Locate/Load/Run a file from SD ]---------------------+ <--- SD: init/locate/load/run a file ---> '+ On Entry: + '+ fname[3]: filename[11] 8+3 without "." (will be $0 terminated) + '+ Call Format: + '+ CALL #@_Run_SDfile ' + < call: init/locate/load/run a file > '+ On Return: + '+ "NZ" if error, else does not return + '+-----------------------------------------------------------------------------+ '+-----------------------------------------------------------------------------+ fc560 f6079a00 _Start_SDcard mov skiprun, #0 ' load/run MBR/VOL code \ --tweek2-- fc564 fdb00050 call #@_SDcard_Init0 ' Init/CSD/CID/MBR/VOL/FSI/FAT (skiprun=0) | --tweek2-- fc568 adb00290 if_e call #@_readDIR ' read directory for filenames '' mov skiprun, #0 ' load/run <file> (already 0) fc56c adb00378 if_e call #@_readFILE ' read/load/run the file fc570 fdb004ec call #@_releaseDO ' /CS=1, send CLKs, tristate CS/CK/DI/DO | --tweek2-- fc574 fd800100 JMP #try_serial ' failed: so go back and try serial '+-----------------------------------------------------------------------------+ fc578 fdb00020 _Run_SDfile call #@_SDcard_Init1 ' Init/CSD/CID/MBR/VOL/FSI/FAT (skiprun=1) | --tweek2-- fc57c adb002ac if_e call #@_searchDIR ' search dir for <fname> fc580 f6079a00 mov skiprun, #0 ' load/run <file> (skiprun=0) fc584 _Loadit ' \ {{ tweek }} fc584 adb00360 if_e call #@_readFILE ' read/load/[run] the file / {{ tweek }} fc588 fdb004d4 call #@_releaseDO ' /CS=1, send CLKs, tristate CS/CK/DI/DO | --tweek2-- fc58c fd64002d RET ' return "NZ" = failed, "Z" if loaded ok '+-----------------------------------------------------------------------------+ fc590 fdb00008 _Load_SDfile call #@_SDcard_Init1 ' Init/CSD/CID/MBR/VOL/FSI/FAT (skiprun=1) | --tweek2-- fc594 adb00294 if_e call #@_searchDIR ' search dir for <fname> '' mov skiprun, #1 ' load, do not run <file> (already 1) fc598 fd9fffe8 jmp #@_Loadit ' if Z go read/load file ] {{ tweek }} '+-----------------------------------------------------------------------------+SD Boot Code - SD Routines (HUBEXEC) Rev 1 silicon
'' +--------------------------------------------------------------------------+ '' P2 ROM SD ROUTINES (HUBEXEC) Rev 1 silicon '' +--------------------------------------------------------------------------+ _Start_SDcard = $fc560 ' initialise & read CSD/CID _Run_SDfile = $fc578 ' initialise & read CSD/CID _Load_SDfile = $fc590 ' initialise & read CSD/CID _SDcard_Init = $fc5a4 ' init hub data ptr=$0 _readMBR1 = $fc6dc ' do not load/run MBR/VOL code _readMBR = $fc6e0 ' VBR/MBR = SECTOR 0 _readDIR = $fc810 ' copy _fname1 -> fname _searchDIR = $fc840 ' 12th char must be $00 _readFILE = $fc900 ' DAT SECTOR# _readnxtSECTOR = $fc944 ' next sector# _readnxtSLOT = $fc948 ' next data slot _readSECTOR = $fc950 ' sector# _readREG = $fc974 ' CMD9,10: CSD,CID register _readBLOCK = $fc97c ' CMD17: PAR=sector, 512 bytes '' +--------------------------------------------------------------------------+ '' HUB ADDRESSES '' +--------------------------------------------------------------------------+ _HUBROM = $FC000 ' ROM $FC000 _HUBBUF = $FC000 ' overwrite Booter _HUBBUFSIZE = 80 ' RxString default size for _HUBBUF '' +--------------------------------------------------------------------------+SD Boot Code - SD Routines (HUBEXEC) Rev 2 silicon
'' +--------------------------------------------------------------------------+ '' P2 ROM SD ROUTINES (HUBEXEC) Rev 2 silicon '' +--------------------------------------------------------------------------+ _Start_SDcard = $fc560 ' initialise & read CSD/CID _Run_SDfile = $fc578 ' initialise & read CSD/CID _Load_SDfile = $fc590 ' initialise & read CSD/CID _SDcard_Init = $fc59c ' init hub data ptr=$0 _searchDIR = $fc82c ' 12th char must be $00 _readFILE = $fc8e8 ' DAT SECTOR# _readnxtSECTOR = $fc930 ' next sector# _readnxtSLOT = $fc934 ' next data slot _readSECTOR = $fc93c ' sector# _readREG = $fc960 ' CMD9,10: CSD,CID register _readBLOCK = $fc968 ' CMD17: PAR=sector, 512 bytes _releaseDO = $fca60 ' sends $FF (8 clocks) to SD card with /CS=1, tristates P58-61 '' +--------------------------------------------------------------------------+ '' HUB ADDRESSES '' +--------------------------------------------------------------------------+ _HUBROM = $FC000 ' ROM $FC000 _HUBBUF = $FC000 ' overwrite Booter _HUBBUFSIZE = 80 ' RxString default size for _HUBBUF '' +--------------------------------------------------------------------------+SD Boot Code - COG Variables
''============[ COG VARIABLES - SD BOOT]======================================== org $1C0 ' place the variables in cog $1C0-$1DF cmdout res 1 ' The 8b CMDxx | $40 cmdpar res 1 ' The 32b parameters cmdcrc res 1 ' The 8b CRC (must be valid for CMD0 & CMD8) cmdpar2 res 1 ' SDV1=$0, SDV2=$40000000 cmdtype res 1 ' reply is R1=1, R3=3, R7=7, else 0 reply res 1 ' R1 reply (moved to replyR1 when R3/R7 32b reply here) replyR1 res 1 ' R1 reply (8b saved when R3/R7 32b reply follows) dataout res 1 ' 8/32 bit data being shifted out bytescnt res 1 ' #bytes to send/recv bitscnt res 1 ' #bits to be shifted in/out ctr1 res 1 timeout res 1 ' = starttime + delay _AA55 res 1 ' used to store $AA55 to validate MBR/VOL/FSI skiprun res 1 ' 1= skip load/run mbr/vol & load/no-run fname '\ 1=SDV1, 2=SDV2(byte address), 3=SDHC/SDV2(block address) blocksh res 1 '/ block shift 0/9 bits clustersh res 1 ' sectors/cluster SHL 'n' bits vol_begin res 1 '$0000_2000 ' Ptn0: first sector of PTN fsi_begin res 1 '$0000_2001 ' Ptn0: sector of file system info fat_begin res 1 '$0000_3122 ' Ptn0: first sector of FAT table dir_begin res 1 '$0000_4000 ' Ptn0: first sector of DATA is DIR table dat_begin res 1 '$0000_4580 ' Ptn0: first sector of file's DATA ptn_size res 1 '$0008_0000 ' file-size 32KB = 64<<9 sectors _bufad res 1 _blocknr res 1 _sectors res 1 _entries res 1 bufad res 1 ' ptr sector buffer blocknr res 1 ' sector# fname res 3 ' 8+3+1 _hubdata res 1 fit $1E0-OR-''============[ COG VARIABLES $1CO-$1DF - SD BOOT]============================= cmdout = $1c0 ' The 8b CMDxx | $40 cmdpar = $1c1 ' The 32b parameters cmdcrc = $1c2 ' The 8b CRC (must be valid for CMD0 & CMD8) cmdpar2 = $1c3 ' SDV1=$0, SDV2=$40000000 cmdtype = $1c4 ' reply is R1=1, R3=3, R7=7, else 0 reply = $1c5 ' R1 reply (moved to replyR1 when R3/R7 32b reply here) replyR1 = $1c6 ' R1 reply (8b saved when R3/R7 32b reply follows) dataout = $1c7 ' 8/32 bit data being shifted out bytescnt = $1c8 ' #bytes to send/recv bitscnt = $1c9 ' #bits to be shifted in/out ctr1 = $1ca timeout = $1cb ' = starttime + delay spare = $1cc skiprun = $1cd ' 1= skip load/run mbr/vol & load/no-run fname '\ 1=SDV1, 2=SDV2(byte address), 3=SDHC/SDV2(block address) blocksh = $1ce '/ block shift 0/9 bits clustersh = $1cf ' sectors/cluster SHL 'n' bits vol_begin = $1d0 ' Ptn0: first sector of PTN fsi_begin = $1d1 ' Ptn0: sector of file system info fat_begin = $1d2 ' Ptn0: first sector of FAT table dir_begin = $1d3 ' Ptn0: first sector of DATA is DIR table dat_begin = $1d4 ' Ptn0: first sector of file's DATA ptn_size = $1d5 ' file-size 32KB = 64<<9 sectors _bufad = $1d6 _blocknr = $1d7 _sectors = $1d8 _entries = $1d9 bufad = $1da ' ptr sector buffer blocknr = $1db ' sector# fname = $1dc'[3] ' 8+3+1 _hubdata = $1df '' +--------------------------------------------------------------------------+readCSDCID
readSector
TAQOZ# $170 $10 SD DUMPW --- 00170: 0000 0000 0001 0000 F000 0000 7250 506F '............ProP' okTAQOZ in RAM includes a proper SD formatter and reporting tool that can format cards >32GB to FAT32. Here is the report for an 8GB SanDisk.
TAQOZ# .DISK --- CARD: SANDISK SD SL08G REV$80 #1561170528 DATE:2016/2 *** OCR *** VALUE........................... $C0FF_8000 RANGE........................... 2.7V to 3.6V *** CSD *** CARD TYPE....................... SDHC LATENCY......................... 1ms+1400 clocks SPEED........................... 50Mbps CLASSES......................... 010110110101 BLKLEN.......................... 512 SIZE............................ 7,761MB Iread Vmin...................... 100ma Iread Vmax...................... 25ma Iwrite Vmin..................... 1ma Iwrite Vmax..................... 45ma *** SPEEDS *** SECTOR.......................... 478us,624us,555us,552us,552us,554us,588us,559us, BLOCKS.......................... 2,015kB/s @192MHz *** MBR *** PARTITION....................... 0 00 INACTIVE FILE SYSTEM..................... FAT32 LBA CHS START....................... 1023,254,63 CHS END......................... 0,0,0 FIRST SECTOR.................... $0000_2000 TOTAL SECTORS................... 15,515,648 = 7,944MB 00170: 0000_0000 0000_0001 0000_F000 506F_7250 '............ProP' *** FAT32 *** OEM............................. TAQOZ P2 Byte/Sect....................... 512 Sect/Clust...................... 64 = 32kB FATs............................ 2 Media........................... F8 Sect/Track...................... $003F Heads........................... $00FF Hidden Sectors.................. 8,192 = 4MB Sect/Part....................... 15,515,648 = 7,944MB Sect/FAT........................ 1,894 = 969kB Flags........................... 0 Ver............................. 00 00 ROOT Cluster.................... $0000_0002 SECTOR: $0000_2EEC INFO Sector..................... $0001 = $0000_2001 Backup Sector................... $0006 = $0000_2006 res............................. 00 00 00 00 00 00 00 00 00 00 00 00 Drive#.......................... 128 Ext sig......................... $29 OK! Part Serial#.................... $50AD_0021 #1353515041 Volume Name..................... P2 CARD FAT32 okBut "_BOOT_P2.BIX" did.
(and TAQOZ '.DISK' does not show any output)
About TAQOZ '.DISK' issue: It seems that the original TAQOZ .DISK does not work with my card.
I loaded a new TAQOZ program (from http://forums.parallax.com/discussion/comment/1509204/#Comment_1509204) using P2-Monitor (Ctrl-D) and then I was able to see the SD Card .DISK information.
You need to use filenames with uppercase and in 8.3 format Files ending with .DISK will not be found.
@Cluso99 - .DISK is the print disk information function in TAQOZ reloaded. You oughta try it some time mate
TAQOZ# .DISK --- CARD: SANDISK SD SC64G REV$80 #35190404 DATE:2018/10 *** OCR *** VALUE........................... $C0FF_8000 RANGE........................... 2.7V to 3.6V *** CSD *** CARD TYPE....................... SDHC LATENCY......................... 1ms+1400 clocks SPEED........................... 50MHz CLASSES......................... 0 1 0 1 1 0 1 1 0 1 0 1 BLKLEN.......................... 512 SIZE............................ 62,367MB Iread Vmin...................... 10ma Iread Vmax...................... 25ma Iwrite Vmin..................... 60ma Iwrite Vmax..................... 35ma *** SPEEDS *** LATENCY......................... 478us,278us,255us,312us,327us,254us,3 15us,328us, SECTOR.......................... 286us,337us,315us,316us,337us,315us,3 20us,336us, BLOCKS.......................... 7,382kB/s @320MHz *** MBR *** PARTITION....................... 0 00 INACTIVE FILE SYSTEM..................... FAT32 LBA CHS START....................... 1023,254,63 CHS END......................... 0,0,0 FIRST SECTOR.................... $0000_8000 TOTAL SECTORS................... 124,702,720 = 63,847MB 00170: 0000_0000 0000_0001 0002_0000 506F_7250 '............ProP' *** FAT32 *** OEM............................. TAQOZ P2 Byte/Sect....................... 512 Sect/Clust...................... 128 = 65KB FATs............................ 2 Media........................... F8 Sect/Track...................... 63 Heads........................... 255 Hidden Sectors.................. 32,768 = 16MB Sect/Part....................... 124,702,720 = 63,847MB Sect/FAT........................ 7,611 = 3MB Flags........................... 0 Ver............................. 00 00 ROOT Cluster.................... $0000_0002 SECTOR: $0000_BB96 INFO Sector..................... $0001 = $0000_8001 Backup Sector................... $0006 = $0000_8006 res............................. 00 00 00 00 00 00 00 00 00 00 00 00 Drive#.......................... 128 Ext sig......................... $29 OK! Part Serial#.................... $6269_0201 #1651048961 Volume Name..................... P2 CARD FAT32 okThanks Peter.
I misinterpreted Ramon's post as looking for a ***.DISK file.
I do use your 1 liners but I have to confess I've not tried the full TAQOZ. Shame it didn't all fit in the ROM
I'm still looking for that elusive time-shifting so I can get more than 24 hours in a day
@Cluso99 I hope you don't mind me resurrecting this old thread. I have an SD card that I was prototyping remote updates code on. I have probably moved and deleted the _BOOT_P2.BIX file two dozen times on it. It quit booting. I reformatted it, and it still will not boot _BOOT_P2.BIX. Any pointers as to what the issue may be? Anything I should be looking at on the SD card?
Terry
Couple things to consider...
Have you tested with another SD card, so you can be certain it's an SD problem and not a dipswitch setting or some other problem.
Grab an SD card lowlevel formatter and reformat again. Windows doesn't always format optimally. Most major SD card suppliers have tools you can download for free.
Reason for no.2 is that the P2 boot code relies on the filename being early in the index sector on the card. Each resave could have been pushing your index entries down the sector, and finally beyond reach. Lowlevel format will reset the boot sector back to zero (-ish).
Try this:
https://www.sdcard.org/downloads/formatter/
The extended Taqoz (serial loaded, non the smaller rom taqoz) also has a FAT formatter built-in, that works well
This one has caught me out a few times, particularly if you are using SD cards larger than 8GB (and 8GB cards are in fact difficult to purchase now).
Is this limitation documented somewhere?
Ross.
100% confident this isn't it. Other SD cards boot no problem. The SD card works just fine.
I would like to know the specifics around this. A booting stub may be able to get around this issue, especially since I am replacing the boot image. I could keep the stub in the same place and replace the actual boot image.
I am going to capture filesystem info with HxD, then reformat using TAQOZ. If that doesn't work, then I will low level the SD card.
As I recall, the filename needs to be indexed within the first X bytes of the MBR. Possibly within the first sector- memory a little dusty.
A stub could totally solve it - boot the same
_BOOT_P2.BIXor_BOOT_P2.BIYfile, which has your own boot-from-SD routine to load your code from anywhere on the SD card - or from anywhere in the universe if you have an internet connectionThe requirement certainly isn't to be within the first sector, because then it'd have to be within the first 16 files (each entry is 32 bytes, plus some extra dummy entries if VFAT long names are used). More likely it needs to be within the first root directory cluster, which is usually 32k (and thus holds 1024 file entries). If that's the issue then one should be more concerned that the filesystem code isn't re-using deleted slots for new files over growing the directory. Any formatting should completely clear the directory though and dragging a new file on from a PC should certainly re-use deleted slots.
The interesting thing is, the filename entry that didn't work was in a FAT at Sector 8,192/Offset ($400000). All of the other ones I have (that work) were above Sector 16,000.
It was within the first dozen or so files listed, so I don't think that is the issue. I am not an expert and nothing jumped out at me as being wrong. The "deleted slots" was working properly. There were no deleted files in the FAT that I saw (First character set to $E5)
I formatted that card several times with Windows 10, to no avail. I couldn't find the version of TAQOZ with the formatter easily (it's not the one in the ROM) so I just used the Tuxera SD Card Formater and it fixed it. It also wiped the MBR and I wonder if that plays into this.
While we are at it, do we know how the P2 determines if a valid MBR exists? I don't think that is documented.
I thought had an issue with deleted long filenames causing a boot fail a couple of times. But, sadly, I wasn't able to replicate the conditions later. Maybe it was moves to the trashcan ... dunno, never quite got to the bottom of it.
Ah, I wonder if you've ended up with EFI partitioning? The first MBR entry would then point to the EFI reserved space instead of a FAT32 partition.
Just another SD card quirk ...
I bought an 8Gb SD card from Parallax. Got it yesterday, copied some files to it, inserted it into the SD slot on the Propeller and it booted first time! Yay!
But this morning - problemo! Power up the Propeller and it won't boot from the new SD card. Huh?
I tried some old SD cards - Propeller boots ok. Disk checked the new card on Windows and checked the files against the originals - all ok, but won't boot. Reformat the new card using Windows format and copy the same files to it again - still won't boot. Reformat the new card using the official SD Card formatting program from the SD Association and copy the same files to it again - still won't boot.
To cut a long story short, it took a format with full overwrite (i.e. not a quick format) using the official SD Association formatter before the card could be booted by the Propeller again. I have no idea what I did that made it stop working - and of course it's now too late to find out - or why a low-level format fixed it. But at every step along the way, both the card itself and the files on it all checked out fine under Windows.
I'd been spending a lot of time reformatting SD cards because the Propeller is so goldarned picky, which is why I bought the 8Gb card from Parallax - I thought it might prove to be more reliable than the cards I had been using. It didn't.
Can the next revision of the Propeller chip please include some more reliable SD card boot code?
Ross.
And of course repeatedly zeroing of the whole card is a bit rough on the write endurance figures. Or potentially at least. Hard to say how the drive treats a blank write when a block is already erased.
Ross: I have a SD card that is completely gronked too. The P2-ES killed it. Want to play with it? Happy to send it to you if interested. PM me.
@RossH One thing that can make the SD card boot unreliable is if you have the programming cable plugged in. It sounds stupid, but it can cause problems. Of the dozens I have worked with, the one above is the only one I had issues with. I have had the card nuke itself with some of the versions of sdspi floating around, but a format always fixed it.
Thanks for that. But I am using a P2 EVAL board and the USB programming cable is providing both power and serial interface so I can't unplug it. However, you have just reminded me that someone recommended to always power the P2 EVAL using both USB ports. If it is a power-related problem, that would make sense. I'll try that and see if I have any further problems.
A quick format usually does fix the problem if it is the one caused by the boot program having to be in the first few directory table entries (but I know the symptoms of that one - i.e. the Propeller can read and write the SD card ok but cannot boot from it). This one was different, and a quick format did not make the SD card bootable. In this case the Propeller could not read the SD card at all (but Windows still could) until I did a complete low-level write of all sectors.
Ross.
Thanks, but no thanks. I have a box full of unreliable SD cards (or so I thought - now, I am increasingly thinking it is the Propeller that is the problem, not the SD cards).
I certainly don't want another one!
Yes, but perhaps it might be a good idea to do this process once with each new SD card. Perhaps the manufacturing process can leave the card in an indeterminate state. I don't know enough about SD cards to know if this might be a possibility.
Did you access the flash memory from your program while the SD inserted? It can (and it did for me several times) unformat the SD card by erasing sector 0 on it. Normal format doesn't help if doable at all. The card has to be initialized again using a partition manager (gparted in Linux or anything equivalent in Windows) to write the proper content to the sector 0 again.
The problem is: the SPI mode zero can not be used in P2 systems. Use only mode 3. This prevents the card for being accidentally selected and written to while accessing the flash. All P2 flash libraries used mode 0 until I discover this bad behavior. After this jm_flash was updated and now it uses mode 3, while I wrote my own bitbanging (no smart pin used) flash procedures also using mode 3. No unformatting now.
No. Just the SD card.
