SimpleFOC (careful when you say it) — Parallax Forums
  • OMG, the vision sensing is gross overkill! One of these would've sufficed with no extra microcontroller required:
    https://www.parallax.com/product/tsl1401-linescan-sensor-daughterboard/
  • @"Phil Pilgrim (PhiPi)"
    No doubt that line scanner response blows the vision system out of the water. :+1:
    Craig
  • Hi
    Hey- that line scanner (tsl1401) looks interesting- didn't know they were available.
    The bare chips aren't too expensive may have to get a couple to play with. Sadly they are analog output so that complicates things a bit.
    Dave
    edited 2022-10-25 23:49
    You won't be able to, unless you want to buy 51 or more. The bare sensor chips have been out of production for quite some time. Fortunately, there are a thousand or so of the Parallax product in stock or in the queue. :)
    Even if you could get the chips, you'd have to come up with a circuit board and provide a lens to focus an image.
    By adjusting the exposure time and making sure the visual contrast is adequate, the analog output can serve as a digital input, where the digital threshold corresponds to the desired optical threshold.
    edited 2022-10-26 03:50
    You could use ultrasound and make it way simpler, too.
    The approach the designer took on that project was kind of like putting together parts of a human.
  • Different accuracy requirements but I have one of these on the slow-boat right now.
    https://aliexpress.com/item/1005002971009848.html
    If it works out, I'll have 6 or 8 of them, talking to a P1.
    Craig
  • Hi
    ams, TSL1401CL Visible Light 128-Element Photodetector, 1000nm, Surface Mount CL package
    RS Stock No.:785-7692
    Mfr. Part No.:TSL1401CL
    Brand:ams
    1 off £7;40 each
    250+ off £4.24
    So surface mount still available- dil package discontinued
    8 pads total- only 6 used
    2 columns of pads, with a space of 0.8 mm between columns. Pads are on 2.5mm centres
    How hard can it be? :*
    Dave
  • pik33pik33 Posts: 2,419
    Either visible or 1000 nm :) Maybe there are animals that can see 1000 nm, but a human can not, this is infrared.
  • Like all the TSL1401 variants, the TSL1401CL has been discontinued by AMS. Here is its spectral response, extending from violet to near infrared, peaking around red:
    The lens on the Parallax product, which uses the "CL" version, includes an IR-cut filter so it responds only to visible light.
  • ErNaErNa Posts: 1,862
    When it comes to the detection of the ball, wouldn't that be a nice application for the Goertzel sensor?
