Definitions p2 — Parallax Forums
Definitions p2
I have been struggling to read through all of the documentation about the P2.
First is there a more defined "dictionary" of the commands and what do they do in a more simple explanation of what they really mean and what they do?
Example:
WRPIN # D # S SP
WXPIN # D # S SP
WYPIN # D # S SP
SETDACS # D
What is the X and the Y? I know that they are acronyms but what are the long version of the acronyms mean.
Thank you in advance.
Martin
  • RaymanRayman Posts: 16,460
    The smartpins are very flexible but also a bit complex...
    Maybe the Hardware Manual describes them best?
    https://www.parallax.com/propeller-2/documentation/
    Anyway, the main command is "WRPIN" for Write Pin, which sets the main mode.
    X and Y are parameters of the main mode, set by WXPIN and WYPIN.
    SETDACS is to set the Digital to Analog Converters (DACS).
    This is a normally unrelated thing, but probably connected in some cases...
  • evanhevanh Posts: 17,318
    The three instructions load the smartpin's three write-only registers:
    • WRPIN for setting the mode word. The mode register isn't named.
    • WXPIN and WYPIN for X and Y data/parameter registers. X and Y are just short names, no particular meaning.
    There is also one read-only data register in each smartpin. RDPIN is used to get its data. This one is named Z.
    SETDACS is a little oddball. Thrown in as a bonus because it was easy to add I suspect. SETDACS writes to the streamer's four DAC data pipes when the streamer isn't doing so. But it's generally easier to just use a WRPIN instead for simple setting of a DAC.
    edited 2022-09-10 01:22
    There can be naming confusion in the docs also with the low level pin A/B verses smartpin A/B inputs. I've personally been separating the naming with SmartA/SmartB and PinA/PinB (or APin/BPin). This helps me keep them distinct in my source code.
    Rayman uses my naming here - https://forums.parallax.com/discussion/171420/smartpin-diagram-now-with-p-p-bit-mode-table/p1
    He updated the chart again on last page - https://forums.parallax.com/discussion/comment/1530931/#Comment_1530931
    edited 2022-09-10 03:07
    WRPIN's mode register performs many jobs:
    • Selecting a smartpin mode with %SSSSS bit-field. %00000 = OFF (Not a smartpin)
    • Modifying pin control with %TT bit-field. Affected by %SSSSS and DAC output mode below.
    • Selecting SmartA/B input sources with %AAAA/%BBBB bit-fields. SmartA is passed to IN when not used by smartpin.
    • Debounce/logic of SmartA/B with %FFF bit-field.
    • Set low-level pin control mode with %MMMMMMMMMMMMM bit-field. This is further subdivided in an encoded form:
    %0MMM_CIOHHHLLL for Logic I/O modes.  Includes pinA vs pinB comparator.
    %100MMM_OHHHLLL for ADC input modes.  Includes Logic output modes.
    %101MM_DDDDDDDD for DAC output modes.  Includes one preset ADC mode.
    %11MM_CDDDDDDDD for CompDAC input modes.
    The low-level %DDDDDDDD bit-field acts as a DAC databus and is optionally piped from any streamer/cog without using the smartpin.
    PS: There is a number of possible combinations that are not available due to limit of 32 mode bits in WRPIN.
  • pilot0315pilot0315 Posts: 1,014
    edited 2022-09-10 12:50
    @evanh
    @Rayman
    Thanks I will study these and try to tease out the examples. I am presently trying to understand the pwm routines.
    Martin
  • JonnyMacJonnyMac Posts: 9,851
    edited 2022-09-10 20:45
    Keep in mind that the PWM smart pins sub-divide the X register into two elements. I think it's easier to start with the sawtooth version. Sawtooth and Triangle have to do with the behavior of an internal counter, and nothing to do with the shape of the output waveform. Both will give a variable duty-cycle, fixed-frequency square wave. This is from the docs
    %01001 = PWM sawtooth
    This mode overrides OUT to control the pin output state.
    X[15:0] establishes a base period in clock cycles which forms the empirical high-time and low-time units.
    X[31:16] establishes a PWM frame period in terms of base periods.
    Y[15:0] establishes the PWM output value which gets captured at each frame start and used for its duration. It should range from zero to the frame period.
    A counter, updating at each base period, counts from one up to the frame period. Then, Y[15:0] is captured, IN is raised, and the process repeats.
    At each base period, the captured output value is compared to the counter. If it is equal or greater, a high is output. If it is less, a low is output. Therefore, a zero will always output a low and the frame period value will always output a high.
    During reset (DIR=0), IN is low, the output is low, and Y[15:0] is captured.
    The X register setup is tricky at first. X.word[1] (high 16 bits) is the number of units in your PWM period. I do a lot of LED control and use 255 here because DMX lighting control uses 0 to 255 for 0 to 100%. You could make things easy and have 1% resolution by setting X.word[1] to 100. The lower 16 bits of X tell the P2 how many system ticks are in one of your units at your desired PWM frequency. This is calculated by dividing your system clock frequency by your desired PWM frequency (e.g., 20kHz), and then dividing that by the units in 100%. Once you have that sorted and the smart pin is running, changing the Y register will change the PWM duty cycle. Keep in mind that your ticks/unit value (X.word[1]) must fit into 16 bits, so this can have an affect on your low side of your PWM frequency. For very low frequencies you'll want to use high ticks/units and high units values.
    In Spin, I do this:
      x.word[0] := 1 #> ((clkfreq / hz) / units) <# $FFFF           ' ticks per unit @ target hz
      x.word[1] := units                                            ' units in 100%
      pinstart(pin, P_OE | P_PWM_SAWTOOTH, x, duty)                 ' start pwm smart pin
    ...where hz is my target PWM frequency, units is the 100% value, and duty is the initial PWM setting. The PWM smart pin has an internal counter that goes from 1 to your 100% setting. If your duty value is at or above this counter, the output is high. As soon as the counter value goes past your duty setting, the output goes low. Graphically, it looks like this:
    In Triangle mode, the counter counts down and then back up, which will cut your PWM frequency in half with the same X register settings. In my Spin driver when Triangle mode is specified, I make this adjustment to keep the PWM frequency matched to the value passed to the start method:
      x.word[0] >>= 1
      pinstart(pin, P_OE | P_PWM_TRIANGLE, x, duty)
    Dividing the ticks/unit value by 2 would double the frequency in Sawtooth mode; in Triangle mode (witch doubles the output) this adjustment keeps the target PWM frequency.
    edited 2022-09-10 18:05
    Here's a dirt-simple example of making a slow (0.5Hz) LED blinker with a duty cycle of 0 (off) to 100%. Note how I had to scale the units and duty (x 100) to get the ticks/unit value to fit into 16 bits while running a 200MHz.
    pub slow_blink(pin, duty) | x
    '' Blink LED slowly (0.5Hz) at duty cycle (0% to 100%)
      x.word[0] := 1 #> (clkfreq << 1) / 100_00 <# $FFFF
      x.word[1] := 100_00
      duty := (0 #> duty <# 100) * 100
    Remember, if you want to use wypin() to set the duty cycle of this blinker, that value must be scaled into the range of 0..100_00 to get the expected results.
    This exercise got me thinking about how slow one could go. The highest ticks/unit setting is $FFFF, and the highest units setting is $FFFF. For me, the PWM frequency works out to be 200_000_000 / ($FFFF * $FFFF) which is 0.04656Hz, which is a period of 21.474 seconds. I knocked together this bit of code to verify:
      wrpin(55, P_PLUS1_A)                                          ' use P55 to watch P56
      state := pinread(55)                                          ' get initial state
      pinstart(56, P_OE | P_PWM_SAWTOOTH, $FFFF_FFFF, $7FFF)        ' very slow pwm on P56
      t0 := getms()                                                 ' start timing
      repeat                                                        ' report ms between states
        if (pinread(55) <> state)
          t1 := getms()
          term.fstr1(@"State change at: %dms\r", t1-t0)
          t0 := t1
          state := state ^ 1
    Confirmed. Time between state changes is 10.737 seconds.
    A few minutes later...
    Changing the PWM mode to triangle doubles the PWM period.
  • @JonTitus
    Howdy.
    Rayman sent me to this document.
    This is a line from it:
    You may download all software examples in this section from the URL here...
    On page one. :) Where is "here". The link does not work for me. Maybe it is me.
    Thanks in advance.
    Martin.
  • I still have a question about PWM/DAC 16bit via dithering.
    Right now I have a trade-off between PWM frequency and resolution (normal).
    Is dithering some form of trickery where I can achieve 16 bit resolution at a higher frequency?
    Craig
  • ElectrodudeElectrodude Posts: 1,687
    edited 2022-10-07 13:28
    Craig
    Yes - you get higher frequencies at the expense of more noise, even somewhat at lower frequencies.
    Random mode does what's called noise shaping: instead of all the frequency content above the Nyquist rate being a 1/256 triangle wave (noise), plus maybe a little bit of your signal with aliasing if you try feeding it samples too quickly, it "spreads out" the Nyquist rate, letting you control the frequency content at higher frequencies in a meaningful, but still noisy, way, at the expense of more noise in frequencies below the original Nyquist rate.
  • @Electrodude
    Not sure if that is a yes/no/maybe :lol:
    Craig
    edited 2022-10-07 13:36
    @Mickster said:
    @Electrodude
    Craig
    If you need the higher frequencies and don't mind reduced resolution at the extra frequencies and more noise in frequencies near the previous limit, it's a yes. Read up on "noise shaping" - this should be the first-order kind. I edited my previous post a few times - sorry.
  • @JohnnyMac,
    Thank you! I thought I understood these, but your walkthrough made the details much clearer. (Especially the functions of the words in X) I haven't needed PWM from the P2 yet, But now I MUST go try it..
    After my recent experience using the "Duty Mode" in the Prop1 counters, which is also known as Pulse Density Modulation, I get the feeling Chip probably should have used that instead of PWM dithering in the Prop2.
    I hadn't twigged just how much better PDM is for DACs until I saw it in action. The modulation frequency ramps up in mid voltage thereby keeping the ripple very low. PWM gets noisy in this region - needing larger smoothing capacitor which slows response.
  • Wuerfel_21Wuerfel_21 Posts: 5,864
    edited 2022-10-07 15:28
    Now that you say it, yeah. PDM also has the advantage that it doesn't have a sample period. The target value can be changed at any time without glitches. PWM-dithered DAC only works quite right if the period is a multiple of 256 cycles.
    On P1 I think the DAC quality is limited by the fact that the modulator is behind all these gates (OR with OUTA/other counter/video, AND with DIRA, OR with up to 7 other cogs), which seem to distort the signal (rise/fall time difference?). There are noticable artifacts when the cog running the DAC is behind more of these. I guess if they were clocked gates that wouldn't be an issue, but they aren't (PLL/video hardware says hello).
  • This is for my multi-axis motion controller and admittedly, from a practical standpoint, I'm being a bit silly but I have the data sheets on all of the "big player" products and darn-it, I want to meet or exceed their specifications just to prove that the P2 is the ultimate solution.
    The only stickler is that one product has a 16-bit, filtered PWM, 10v / -10v at something in excess of 30KHz.
    Kinda moot, actually because AFAIK, The ADC input of pretty much every servo amplifier resolves to 12-bit.
    This is a PID output that is constantly updated @ 1/2/4/8 KHz to regulate motor velocity....even a "real" DAC appears crazy noisy in this application.
    I guess, when all's said and done, we're dealing with a LPF that is the motor itself.
    Craig
  • Would someone please tell me what the DIR means. Is this similar to DIRA?
    Thanks.
    INSTART(PinField, Mode, Xval, Yval) Start PinField smart pin(s): DIR=0, then WRPIN=Mode, WXPIN=Xval, WYPIN=Yval, then DIR=1
    PINCLEAR(PinField) Clear PinField smart pin(s): DIR=0, then WRPIN=0
    edited 2022-10-31 12:53
    Each logic level pin has three internal logic signals: An IN signal, an OUT signal, and a DIR signal.
    IN always shows the level of the pin.
    When DIR is high, the pin is driven with the level of OUT.
    INA contains 32 bits for the first 32 of those pins.
    OUTA contains 32 bits for the same 32 pins.
    DIRA contains 32 bits for the same 32 pins.
    Yes, in normal mode. But in smart mode the three signals have diferent meanings. Please refer to the section "Smart pins" in the silicon docs:
    Each I/O pin has a 'smart pin' circuit which, when enabled, performs some autonomous function on the pin. Smart pins free the cogs from needing to micro-manage many I/O operations by providing high-bandwidth concurrent hardware functions which cogs could not perform as well on their own by manipulating I/O pins via instructions.
    Normally, an I/O pin's output enable is controlled by its DIR bit and its output state is controlled by its OUT bit, while the IN bit returns the pin's read state. In smart pin modes, the DIR bit is used as an active-low reset signal to the smart pin circuitry, while the output enable state is controlled by a configuration bit. In some modes, the smart pin takes over driving the output state, in which case the OUT bit gets ignored. The IN bit serves as a flag to indicate to the cog(s) that the smart pin has completed some function or an event has occurred, and acknowledgment is perhaps needed.
    Smart pins have four 32-bit registers inside of them:
    mode - smart pin mode, as well as low-level I/O pin mode (write-only)
    X - mode-specific parameter (write-only)
    Y - mode-specific parameter (write-only)
    Z - mode-specific result (read-only)
    These four registers are written and read via the following 2-clock instructions, in which S/# is used to select the pin number (0..63) and D/# is the 32-bit data conduit:
    WRPIN   D/#,S/#         - Set smart pin S/# mode to D/#, ack pin
    WXPIN   D/#,S/#         - Set smart pin S/# parameter X to D/#, ack pin
    WYPIN   D/#,S/#         - Set smart pin S/# parameter Y to D/#, ack pin
    RDPIN   D,S/# {WC}      - Get smart pin S/# result Z into D, flag into C, ack pin
    RQPIN   D,S/# {WC}      - Get smart pin S/# result Z into D, flag into C, don't ack pin
    edited 2022-10-31 23:14
    DIR enables the smartpin. When DIR is low, the smartpin (Dark-red box in attached diagram) is held in reset state. Further reading - https://forums.parallax.com/discussion/171420/smartpin-diagram/p1
    When smartpin is configured, then P_OE bit (%TT=01) of pin mode performs the DIR control for the pin itself.
    1998 x 1800 - 251K
