Charitable donation for memory and display boards - Page 2 — Parallax Forums
2»
  • RaymanRayman Posts: 15,799
    Tried a bit with 24 MB on P8, no luck.
    Need a faster way to test...
  • Wuerfel_21Wuerfel_21 Posts: 5,690
    edited 2022-09-10 21:45
    Should try with the 96MB board (or just USE_PSRAM_SLOW in general, though 4bit/slow will make NeoYume unhappy).
    I don't think anyone has gotten external RAM to work on an Edge board. (I only have a Rev.A regular Edge and the big JohnnyMac breadboard, which is a nonstarter anyways). Then again, the 32MB Edge exists.
    24 MB works on rev.c edge board. See pics from a few posts ago
  • I meant "work reliably"
    Tried to get this P2 board made with 3 oz copper. But, they wouldn’t do it because pads ( on P2 I presume) are too close together.
    Have to settle for 2 oz. May or may not do NeoYume.. will be interesting to see.
    They wouldn’t give me 2 oz on top and 3 oz on bottom either. Has to be same on both sides…
  • evanhevanh Posts: 16,861
    edited 2022-09-14 23:53
    Larger diameter vias should help. They'll have more copper per via and the added solder fill will increase heatsinking too. EDIT: And if you are getting them assembled for you then lead-free solder will be better heat conductor as well.
    Lead free better heat conductor?
    Didn’t know that.
    By how much?
    edited 2022-09-15 13:31
    It was a guess but Lead is not great at conducting anything, while Silver is going to be good since it's the best electrical conductor.
    Looking them up - https://en.wikipedia.org/wiki/List_of_thermal_conductivities I find lead-free-solder listed as 60. Disappointingly a long way short of its component metals. And with leaded solder at 50 they're not far apart.
    EDIT: Personal experience tells me that stated figure might not be correct. My impression of soldering with lead-free is the heat travels much quicker than with leaded solder.
  • VonSzarvasVonSzarvas Posts: 3,617
    edited 2022-09-15 17:28
    Maybe related to the hotter iron / air ?
    edited 2022-09-16 02:27
    hmm, possibly. I dunno where my roll of lead-free is these days. It might be 20 years since I last used it.
