MULDIV64 implementation
RossH
in Propeller 2
I am trying to understand the SPIN function MULDIV64 and implement it in PASM. It seems from the description that the following PASM should implement it, but it does not. Can someone tell me if my interpretation of MULDIV64 is incorrect, and/or provide some PASM source code for its correct implementation?
' r4 = mult1 ' r3 = mult2 ' r2 = divisor qmul r3, r4 ' mult1 * mult2 getqx r0 ' get lower 32 bits of product getqy r1 ' get upper 32 bits of product setq r1 ' set upper 32 bits of product qdiv r0, r2 ' divide product by divisor getqx r0 ' get quotient of division ' r0 = quotient ???
Thanks!
Maybe this ? see BIG MULTIPLIER BIG DIVIDER
[deleted link, see #4]
Ross,
What you've written seems about right, for unsigned at least. I haven't actually used MULDIV64() though. I made my own with improved rounding here - https://forums.parallax.com/discussion/173567/muldiv64-appears-to-have-2-error and they've since held up well to a number of use cases, eg: https://forums.parallax.com/discussion/comment/1525977/#Comment_1525977
Oh, wow! What topic was that attachment from? The details are ancient. It must be prop2-hot.
Yes, MULDIV64 is unsigned. The code I posted looks right to me too - but it doesn't actually work. Hence my post
Here's Chip's source code:
Yep, removing the skipped instructions, it's as you've guessed. Only thing extra is the IRQ shielding.
@RossH : your implementation looks correct to me. What makes you think there's an issue? Perhaps there's a problem with the surrounding code?
For reference, here's the implementation of muldiv64 in flexspin (from sys/p2_code.spin):
This code (which looks to be the same as my code) gives the wrong answer on my Propeller - I just tried it. Worse, it gives the same answer even if you comment out the 'setq' instruction. However, I have retrieved the Q register after the setq and checked that it has the right value, but the result of the qdiv is just wrong. It is as if the instruction is not using the Q register at all, and is instead always using zero for the upper 32 bits.
I don't understand what's going on.
What revision Propeller are you using, and can you tell me what answer your code on your Propeller gives for a typical example that needs to use the Q register? - say _muldiv64(0x11111,0x22222,0x3333)?
rossh
Same story with spin2. Flexspin and Pnut give same results as above.
And that's using the built-in muldiv64() too. Eg:
Everything looking good to me.
I'm using revB chips. RevC is no change. Even revA should be the same here.
D'oh! I had forgotten you cannot use the setq instruction in LMM or COMPACT mode. All versions of the code work fine in NATIVE mode. I'll have to rewrite the LMM and COMPACT versions of my implementation of MULDIV64!!!
It's clearly too long since I did any Propeller programming - I've forgotten all the Propeller 2 'gotchas'!
Thanks to all those who helped!
rossh
Hmm, all those combos must be an issue in those modes. What about ##immediate ?
Yep, but the LMM and COMPACT code generator don't generate those (nor do they generate setq!). But I had forgotten this limitation when writing new library routines.
CMM is easy (I can use FCACHE) but the Catalina LMM Kernel never implemented FCACHE (the P1 had no room, and I decided no to bother on the P2 because LMM is not really useful once you have NATIVE execution!) but I had forgotten that this meant I have to custom code anything that requires instructions be executed strictly sequentially (never a problem on the P1, but on the P2 this means anything that requires setq, augs, augd etc).
Does it even make sense to use LMM on P2? Isn't it strictly worse than NATIVE, both in speed and code size? I'd be tempted to just drop that mode for the P2.
Perhaps not. But since it was fully implemented for the P1, it cost almost nothing to keep it implemented on the P2. Except, of course, when I forget the limitations of the LMM library code on the P2!
